Saitek Aviator AV8R Joystick Logo
Posted on Dec 31, 2009
I am trying to use an AV8R-02 with IL2 Birds of Prey on the Xbox 360 console. Most of the controls are compatable, but I can't find a control for my rudder. The control menu only offers gamepad controls with no customization. The buttons on the AV8R are not preforming the same functions as ones displaied in the game control menu, but the tutorial covered most controls.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 05, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
548
Points
Simply twist the joystick grp left or right to use the rudder.
How to link a xbox one controler to a xbox 360
Can I use my Xbox 360 controllers or accessories with Xbox One (or vice versa)?
No. Controllers and accessories that work with Xbox 360 won't work with Xbox One (or vice versa).
http://support.xbox.com/en-US/xbox-one/system/compatibility-with-xbox-360
Ho w to fix x box from controller to x box is really slow how to make it normal
Learn how to connect a wireless or wired controller to your Xbox 360 console.
Connect a wireless Xbox controller
  1. Turn on your console.
  2. Press and hold the Guide button on the controller until the controller turns on.
  1. Press and release the connect button on the console.
Xbox 360 E console fbbfb609-f7ed-4e6e-bd35-7543b1c20d61.png?n=xbox360-connect-m-s.png Xbox 360 S console Original Xbox 360 console 342c6e70-9e56-43d8-bb3a-05f5411040bd.png?v=1#xbox360s-connect-m-m.png 170df81e-0a79-49be-8236-a0fb68eec37b.png?v=1#xbox360-connect-m-m.png
  1. Within 20 seconds, press and release the connect button on the controller.
  1. When the lights surrounding the power button on the console stop flashing, the controller is connected.
On the Xbox 360 S console, each connected controller is assigned to one of four positions. Each position corresponds to a lighted section around the console power button and the controller Guide button. On the 360 E console, a solid green light on the front of the console indicates that the controller is connected. To determine the player position associated with your accessory, look at the ring of light that surrounds the Guide button on the controller.
c9341988-8ed5-4217-9b87-353de50efbec.png?v=1#connect-xbox-controller-m-m.png 5e4ab6ab-8cb0-41e6-a037-b88221a430c7.png?n=connect-xbox-controller-360-m-s.png
71add0b7-ddf2-4439-b4b4-f50f156d92b7.png?v=1#controller-batteries-m-m.png If the controller does not turn on, check the batteries. Insert fresh AA batteries, making sure they are correctly positioned in the battery case.
You can also use the Xbox 360 Play & Charge Kit or the Xbox 360 Quick Charge Kit to power the controller. Learn more about Xbox controllers and chargers.
To connect additional controllers, follow these same steps again. You can connect up to four controllers to the console. Each connected controller is assigned a position that corresponds with the lighted sections that appear around the console's power button and around the Guide button located in the middle of each controller.
  • To disconnect a wireless controller, press and hold the Guide button for three seconds, and then choose to turn the controller off.
  • When you turn off the console, the controller will reconnect the next time you turn on the console.
  • The controller can be connected to only one console at a time. You can connect the controller to a different console, but the connection to the previously connected console will be lost.
Connect a wired Xbox controller
5fb17f50-7448-45d5-a294-9ea90994f55b.png?v=1#controller-wired-m-m.png Plug the Xbox 360 Wired Controller into a USB port on the Xbox 360 console. There are two USB ports on the front of the console. To disconnect the controller, pull on the connector, not the cable.
cbe46bf0-3a46-4d53-9d8c-6697aa57622a.png?v=1#controller-cable-release-m-m.png The cable on the Xbox 360 Wired Controller has an inline release. The inline release on the controller cable is a safety feature designed to reduce the chance of the Xbox 360 console falling if the cable is pulled.
Wireless controller troubleshooting
If your wireless controller disconnects or cannot connect to your console, see Xbox 360 Wireless Controller disconnects or can't connect.
If your wireless controller does not turn on or loses power, try the following solutions:
Solution 1: Replace the batteries
Insert a new set of AA alkaline batteries into the Xbox 360 Wireless Controller, and then try to turn it on.
Solution 2: Try a different battery pack
If you have another Xbox 360 Wireless Controller, take the battery pack off that controller and attach it to your controller. Then try to turn your controller on.
If your controller works with the different battery pack, your original battery pack might be defective. If your controller is under warranty, you can order a replacement battery pack from Xbox Support . See the Assistance section at the bottom of this page for more information.
If your controller is out of warranty, you can buy a new battery pack from a retail store.
Solution 3: Try a rechargeable battery packIf you or a friend has an Xbox 360 Rechargeable Battery Pack, attach that battery pack to your controller and try to use your controller. If your controller works with the rechargeable battery pack attached, you can buy a new battery pack from a retail store or order a replacement battery pack from Xbox Support. See the Assistance section at the bottom of this page for more information.
Can I use this on the xbox 360 or the playstation3?
http://www.amazon.com/Saitek-PS41-Aviator-Joystick-Console/dp/B001EYU1W8
The white wireless contoller from an older white x box 360 does not connect with the black kinnect x box 360 we just purchased.. i was told they were compatible why doesnt the white controller work with...
There is a sync button next to the Play and Charge port on the controller, all you have to do is press both the sync button on the Xbox and the controller and it should connect. On the nonslim Xbox 360's the sync button is right next to the infared sensor and the memory card slots. On the slim Xbox 360 the sync button will be right next to the usb ports on the front of the Xbox 360 console. When you successfully start the sync the led's for the controller's and console's lights will spin and be ready for you to press the sync button on the other device.
(PS, you have to have both the console and the controller on for this to work; PPS, By controller on I mean having it searching)
Xbox 360 Wireless Controllers Not Working
Have your Xbox 360 controllers replaced, it still has warranty, i presume. Any type of batteries would work, especially energizer, but you can try the original Xbox 360 controller batteries (rechargeable ones). Xbox 360 Tech Support....
11helpful
7answers
How do you turn on an xbox 360?
Simply press the big button that has green lights around in front of your console
1helpful
2answers
Is xbox 360 controller compatible with laptops woth vista? Also can I play FIFA with it?
The Xbox 360 controllers are compatible with Windows Vista, you need to connect it either using the cable or you would need to purchase a "Xbox 360 Wireless Gaming Receiver for Windows"
http://www.amazon.com/Xbox-Wireless-Gaming-Receiver-Windows-Pc/dp/B000HZFCT2
Once you have connected the controller it should work with FIFA
2answers
How to setup two wireless controlers to an xbox
  1. Press and hold the Xbox Guide button until the controller turns on. The Xbox Guide button is the round button with the green "X" near the center of the controller.
  2. Make sure that your Xbox 360 console is turned on. If your Xbox 360 console is not turned on, press the power button. The power button is the large round button on your Xbox 360 console.
  3. On the Xbox 360 console, press and release the Connect button. The Connect button is the small round button on the Xbox 360 console.
  4. On the controller, press and release the Connect button. The Connect button is the small button on the front edge of the controller, between the left bumper button and the charging port.
  5. After the Ring of Light spins and flashes one time on the controller and on the console, the controller is connected. The quadrant on the Ring of Light that remains lit indicates the position in which the controller is connected.
  6. Note If you want help connecting an Xbox 360 Wireless Controller to your Xbox 360 console, you can contact Xbox Customer Support. For more information about how to contact Xbox Customer Support, please visit the Xbox Support (http://www.xbox.com/support/) Web site.
  • The controller remains connected to the Xbox console even when you turn off the Xbox console.
  • The controller is connected to only one Xbox console at a time. You can connect the controller to a different Xbox console at any time, but your connection to the previously connected console is lost. You must repeat these steps to reconnect the controller to the original console after your connection to the console is lost.
  • The controller works within 33 feet (10 meters) of your Xbox 360 console. However, objects between the controller and the console may reduce this range.
  • If the controller does not turn on, the batteries may have to be replaced.
Joystick av8r software installed but but profile editor is not wo
go look up the .dll and download it and try to open the profile editor again
if it doesn't work msg me on youtube
http://youtube.com/iHelpp
Top Saitek Video Game Consoles & Games Experts
MegaByteMe
MegaByteMe
Aron
Are you a Saitek Video Game Console and Game Expert? Answer questions, earn points and help others
