Question about Dell Inspiron 8500 Notebook
Laptop won't boot..
My Dell Inspiron 8500 won't boot to the Hitachi Travelstar 40GB drive.
Error message is "Primary Hard Disk Drive 0 Not Found". No bootable devices.
Any suggestions? Thanks!
    Genius:
  • 1,067 Answers
Try new hard drive 1st ok
Posted on Jan 30, 2008
Operating system not found
do you have dual hard disk? check if your hard disk where OS installed is the boot drive/primary drive. press f2 during boot sequence then choose the proper hard disk
Dec 02, 2013 | Dell INSPIRON 1300 Celeron 1.4GHZ,256MB...
I want to upgrade the hard drive on my Advent 6001 laptop to a 250gb one. How do I then copy Windows onto the new hard drive as the laptop doesn`t recognise the CDROM as a boot device, not even in the
Running under the assumption that the CD is actually working, have you checked the BIOS settings to indicate that you want the CD to be the first boot device?
Alternatively, some if not most systems will accept an F12 during boot up to query the user where to boot from.
Jan 06, 2018 | Hitachi Travelstar 5K100 HTS541040G9SA00...
I have a message rebooting computer dell inspiron 8500 with DK23EA-30 "Warning: Dell's Disk Monitoring System has detected that drive 0 on the primary EIDE controller is operating outside of normal...
This is a SMART hard disk monitor Warning. You should probably make a backup on an external drive just in case the drive decides to fail completely.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Feb 27, 2011 | Hitachi TravelStar DK23EA Series DK23EA-30...
Dell Inspiron 8500 started boot error message ?primary hard disk drive 0 failure, no boot device available?strike F1 to retry reboot, F2 for setup. Ran express diagnostics and it shows two errors: Error...
Call Dell if under warranty. Start shopping for a replacement hdd if outside of warranty. You'll need
your OS disks that came with computer (hopefully). If you don't have OS/recovery disks, you can get
them from Dell or even using somebody elses (match version with sticker on your laptop).
Check the hdd connection underneath laptop - make sure cable is not loose, etc.
Probably safe to say your data is gone unless you're willing to spend $$.
Jul 12, 2009 | Dell Inspiron 8500, Latitude D800...
Dell inspiron 5150 primary hard drive disk 0 not found
You may find that either the cable is not connected properly or is faulty, or the worse case the mother board has problems (driver, chips, breakages)
May even be a power supply problem, as the power supply has many output points and different voltages that the HDD power out may have blown. If it has then the rest of the system will appear to be ok.
So first off, check the cables connections on the motherboard, and look for any breaks in the cables, and if you have a power meter of some sort check the power connection, or plug in another power connector, the ones with the same end are generally the same power outputs. The ribbon cable for the HDD should have 2 sockets for HDDs and you must connect your HDD to the end one.
May 14, 2009 | Dell (U0614) for Inspiron 5150 60 GB Hard...
Dell Latitude C600 Laptop
Did you try to boot into the BIOS and load the default settings?
Pls check if the hard drive is recognized in the BIOS first.
Sep 02, 2008 | Dell Latitude Cp, Cpi, Cpx, C600, C800,...
Erased hard drive, now nothing will load
Check to make sure that your Inspiron is set to boot from the CD-ROM drive.
It sounds like your laptop is trying to boot from the (now erased) hard drive first, finds that it can't, then stops without ever checking the CD-ROM drive for boot media.
At startup, hit F2 to go into the BIOS settings. Look for the "Boot Order" section. Make sure that your CD drive is listed first, then your hard drive.
Save your changes, and reboot with the WinXP installation CD in your drive. Now your laptop should boot from the CD and begin installation.
Good Luck!
*If you find the solution helpful, please rate it!*
Jun 04, 2008 | Hitachi TravelStar DK23EB Series DK23EB-40...
Backing up the Hard Drive
I take it your hard drive is IDE. Most enclosures only support 3,5" inch harddrives with either SATA or IDE interfaces. A notebook's HDD can have the IDE interface but it's way smaller than the standard.
There is an option however, it isn't necessarily an enclosure. You can look for the A.C. Ryan uDrive. It's a USB device which allows you to connect harddisks or optical drives from three different interfaces without the hassle of building in the drive in an enclosure.
If this is what you need, check this page:
[A.C. Ryan uDrive]
You'll need to connect your harddrive to the 2,5 inch drive connector on the device.
I hope this is what you were looking for.
Let me know if this solved your problem.
Greetings,
DarkNeogen
Jan 24, 2008 | IBM TravelStar 40GNX 40 GB Hard Drive
Open Questions:
Dell Inspiron 8500 Notebook Logo
259 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
