Question about Xerox DocuPrint N17 Laser Printer
N17 printing "black" pages
This Xerox N17 is printing completely black pages. Initially thought it was a toner cartridge problem but changing it did not resolve the problem. After power cycle it printed a few good pages, but quickly started with the black pages again. My company no longer pays for outside maintenance, so I have to figure it out myself!!! any ideas??? thanks.
  • doitjxr Feb 04, 2008
    tried updating firmware, but no fix. still printing black pages. Maybe fuser assembly needs replacing.
    President:
  • 2,072 Answers
If it prints fine at times, I would go to the Xerox.com site and dlwnload the latest firmware, and install that.
The problem really sounds like corrupted software in the printer.
Posted on Jan 30, 2008
  • Rick Kasper Feb 04, 2008
    If its totally black pages I can't see the fuser being the issue.
    Since you reloaded the software, the next area to look at are the cartridges. One of them could be arching, black prints can be caused by bad connections, mostly the ground contacts on the cartridge.
    A cartridge arching internally can also give you black pages.
    That woud be the next steps to pursue. I would strongly suspect one of the connections on the print cartridge to be a problem.
    Remove the cartridge, look at all the connections on the cartridge and trace them to the connections in the machine. See if one is bent or very dirty.
Everything prints on left half of page
First, are you using a factory Xerox cartridge and Xerox toner?
As to the document, are you getting the entire document printed or is the document simply cut off as if the printer cartridge is out of position?
Oct 19, 2009 | Xerox Phaser 6180N Laser Printer
Black Prints
The toner might be bad, because the old cartridge is working fine.
Jul 31, 2009 | Xerox DocuPrint P12 Laser Printer
Magenta (yellow) unit is PAST end of life... (I have changed cartridges I still have this message. I tried to read instruction, and I got following message: Install P/N 108R00649 following the instalation)
Hi armaskopljak:
You have replaced the toner cartridge but you still have to replace the imaging unit which is the drom that the toner cartridge attaches to.
Toner Cartridge OK, Low, Empty When 15,000
(high-capacity cartridge) or
7,500 (standard-capacity
cartridge) pages are
printed (5% print density).
Imaging Units At/Near end-of-life When 30,000 pages are
printed out or when the
pixel counts are
exceeded.
A fuse in the new
imaging unit will blow
upon installation,
resetting the counter.
Verify color calibration. Clean lenses.
Xerox Part Numbers
Toner Cartridges:
Standard Capacity Yellow 016-1975-00
Standard Capacity Magenta 016-1974-00
‘ Standard Capacity Cyan 016-1973-00
Standard Capacity Black 016-1976-00
High Capacity Yellow 016-1979-00
High Capacity Magenta 016-1978-00
High Capacity Cyan 016-1977-00
High Capacity Black 016-1980-00
Imaging Units
Cyan 016-1993-00
Magenta 016-1994-00
Yellow 016-1995-00
Black 016-1996-00
Hope this helps
Jul 10, 2009 | Xerox Phaser 7300DN Laser Printer
Invalid Black Toner Xerox Phaser 6110 MFP
reload the driver again and if it persists, change the toner
Jun 23, 2009 | Xerox Phaser 6110MFP All-In-One Laser...
Is there a override function to keep printing when toner alerts are on?Wondering since black still shows 30%.
These printers will still print when any or all of the toners are LOW, but if any one of them is EMPTY (according to the chip on the toner cartridge) printing stops.
Standard capacity toners ere 2000 page for the colours, and 3000 page for the black, so they can soon be used up.
Much cheaper per page printed, if you use the high capacity cartridges (6000 page for the colours, and 8000 page black).
There are high quality remanufactured cartridges available now, as good as OEM, and typically you'll get a Hi Capacity Remanufactured cartridge for the same sort of price as a Std Capacity OEM cartridge.
As a short term solution at a lower cost than replacement cartridges, you could just replace the cartridge CHIP. The printer would then think the toner was full (there'll likely to still be some toner in it), so you'll be able to print. Don't run the printer like this for ever though, as the toner has some lubricant properties, and with a TRULY EMPTY cartridge, you'll eventually do some damage to the cartridge, and then possibly the transfer belt (and you don't want to be changing that until it's rated 100,000 page life is up.
May 01, 2009 | Xerox Phaser™ 6180DN Laser Printer
Dell 3110cn color laser prints with black "haze" on all pages
You probably used a "GENERIC" toner cartridge on one of your toners.
This caused the developers to get contaminated, now they need to be replaced (probably Black & Blue)
Jan 12, 2009 | Dell 5100cn Laser Printer
Print writimg ok,but very dusty black on both sides of paper
the supplier of the toner cartridge told me the drum must be cracked and he will supply me a new one.I appreciate your service and I recomment you for your assistant,thank you.
Dec 30, 2008 | Xerox Black Toner Cartridge 25000 Page...
Xerox Phaser 6180 uses too much toner
In all honesty, its not that they use to much toner. Xerox does NOT put nearly enough toner in their cartridges to get the proper yield.
I have gotten as low as 200 pages out of those cartridges.
I do service on them and they do not give 1/5th the yield they advertise.
Nothing you can do to be honest. But they are hugely inefficient.
Aug 13, 2008 | Xerox Office Equipment & Supplies
Printing grey pages
First did you use a third party toner ?
If that isn't the case, try taking out the cartridges and looking for all the contacts. Clean them with a cloth dampened with a little alcohol. An improperly seated cartridge, with in particular a bad ground contact will cause that.
Less likely is the housing has gone bad. But still possible.
Either third party ink or a poor connection on one of the cartridges is the most likely issue.
Mar 01, 2008 | Xerox DocuPrint N17 Laser Printer
Xerox DocuPrint N17 Laser Printer Logo
110 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
