Benq 7220 display wrong color
The display suddenly loss yellow color, there's a white bar at the bottom of the display. What should be green shows magenta and what should be yellow shows blue.
  • 3 more comments
  • Milburn50 Feb 28, 2008
    My Toshiba ET1 has gone yellow!
    I can change the levels of green and red in the image, but not blue. Blue appears colourless or grey. I have just changed the lamp in the last 24 hours and I have changed all the cables and tried different input sources (PS2 and PC)
  • jbbartley Jun 26, 2008
    same roblem except no white bar on screen
    same problem, except no white bar on screen
  • vgy007 Jan 12, 2009
    I have exactely the same problem: no more bleu color on my screen and a yellow band on the top of the screen!
  • Anonymous Mar 19, 2014
    when I go to presentation mode it shows my tool bar at the bottom and the file name accross the top. how do I not have it show
    Sergeant:
  • 261 Answers
It sounds a lot like a bad color wheel if it was a DLP. IF it is a LCD then i would say one of the LCD panels is bad or possibly a connection problem that drives the panel or the connection that hooks up to the projector is suspect. Let me know if that helped you at all.It is strange that the bottom shows white though. Jay
Posted on Jan 31, 2008
Display shows lines and color not displayed properly
A line vertically down the screen (usually bright green) is a failed column strobe. This can be caused by the connections at the top of the screen failing or the strobe chip starting to die.
Random colours can be caused by a cracked screen or a failed video card.
Best to take it to a repair shop for it to be assessed.
Jun 23, 2014 | Toshiba Satellite C850-BT2N11 Laptop
Panasonic cinemavision
we can only suggest a TV repair service for a free estimate
Dec 05, 2017 | Televison & Video
I own a toshiba 19dv500 and am having trouble viewing a dvd, the system is working but only in black and white, no colour\???
Hello there,
A black and white picture is most often due to a faulty or incorrect RGB (red/green/blue) connection or cable.
If you are using a composite connection (red/white/yellow RCA jacks), you have probably connected the yellow plug to a socket labelled Pr/Pb, Cr/Cb, or Y - on either the DVD player or the TV - most probably the TV. The yellow needs to be connected to a socket labelled "VIDEO". If you connect this to any socket labelled Pr/Pb, Cr/Cb, or Y, you will get a black and white picture.
If you are using a component connection (red/green/blue RCA jacks), one of the plugs is either not fully inserted into the socket or is in the wrong socket. If you remove any one of the R/G/B plugs, you will get a black and white picture.
If you are using a SCART cable (UK / AUS), you may have a bent, damaged or disconnected pin.
I suggest you check and correct the connections between your DVD player and TV. If you are unable to locate the problem, please try another cable as the one you are using may be damaged. If you are still unable to locate the fault, please let me know the brand and model number of the DVD player and how it is connected to the TV. If required, I can also draw a diagram showing the correct connections.
It would also be useful to know whether this "fault" suddenly occured, or whether you have just connected the player to the TV.
Hope this helps - please let me know if you need further assistance.
Regards,
BElectric
Mar 03, 2011 | Toshiba Televison & Video
Caravan tow bar electrics
not knowing your color coding switch the r/ turn wires around
national code is yellow green for turn and stop brown for tail white for ground. if national yellow and green backward.
Jul 19, 2009 | 2000 Ford Focus
Replacing front turn signal socket on 1990 dodge shadow
Okay. Hook black to black.
Green to green with white stripe.
Yellow to red with white stripe.
That should work. Nothing is going to blow up if it's wrong. It just won't work.
May 15, 2009 | 1990 Dodge Shadow
Sudden lost of color gamma - "discoloration"
GO ON LINE AND SEE IF ANYONE ELSE HAS BEEN HAVING THE SAME OR SIMERLY PROBLEMS OR MAYBE A RECALL ON THAT CERTAIN ITEM.
ADDRESS BAR:
BENQ G2110W GAMMA ISSUES,
GAMMA FAILURE,
LOST GAMMA.
ENTER...................... AFTER EACH COMA
ANYTYPE OF PROBLEMS WITH BENQ G2110W
ENTER
GO ON TO ABOUT.COM, ASK.COM, INFO.COM
ROD
Feb 17, 2009 | BenQ G2110W 21" Monitor
RCA Pearl TH1100A backlight colors
Pp. 16-17 of your user's manual:
http://www.rcapearl.com/pdf/TH11xx_IB.pdf
Settings
Press forward to enter the Settings menu and then
press plus or minus or to highlight an item. Press play
repeatedly to change settings.
Backlight:
• to adjust the time before the display light
turns off (On/10s/20s/30s).
• to adjust the color of the display light
(Red/Blue/Green/Yellow/Cyan/Purple/White).
-Tha Mp3 Doctor
Dec 13, 2008 | RCA TH1101 MP3 Player
Benq v772 CRT show only Blue and Green color
It has to be either a cable or an IC issue. Get your cable checked first (VGA cable)
Oct 01, 2007 | BenQ Value V772 17" CRT Monitor
LCD display has a yellowish tint
This is a defective CCD problem known to Sony. They will replace it free of charge and even pay for the shipping. For more details go here for the link: http://www.imaging-resource.com/badccds.html
Dec 04, 2006 | Sony Cyber-Shot DSC-F717 Digital Camera
645 people viewed this question
k24674
jasbo
jasbo
