Question about Meade LX200R 8 in. (600 x 203mm) Telescope
LX200 EMC MEADE 8 INCH
I am trying to set this telescope up inside, so only have a small view of the sky, how do i align the telescope when all i have is a small part of the sky and the standard stars are not in view, i have an aligment star library of about 30 stars but i dont know how to find them in the sky. can some one please help
  • 3,186 Answers
By doing this trick--
Do a FAKE alignment-- (I assume that the scope is trained and has the proper date, time, and site)-- just push the buttons for the alignment stars that you cannot see. Then do a GOTO to a star that is in your field of view--- center the star and SYNC. Your gotos will now be OK in your limited field of view.
Posted on Dec 28, 2008
Alinealo primero con la estrella polar, y despues con aldebaran que es la estrella mas brillante del cielo. Utiliza el buscador que es el telescopio chiquito que tiene en un costado. pero mejor ve a un curso. bye
Posted on Feb 24, 2008
10"LX200 EMC that will not
This model LX200 classic has weak capacitors that blow out with age. Go to the Yahoo LX200 group-- post a message with the problem for "Ron Sampson" he can repair the board if it is broken. Also Dr. Clay and Andrew also post to this web site--- they know a lot about LX200 electronics.
www.telescopeman.org
www.telescopeman.us
www.telescopeman.info
Jul 14, 2011 | Meade LX200GPS 10 in. Telescope
Hi do you know were i can get the electronics for the left fork arm or electrical schematics so i can make my own version. thanks steve
Contact the folks on the Yahoo LX200 group-- they have board pictures and knowledge of the electronics on LX200 scopes.
http://tech.groups.yahoo.com/group/LX200GPS/
Mar 17, 2011 | Meade LX200GPS-SMT 8 inch Telescope
I just purchased a B.L model 4000 telescope. I do not have the owners manual. It has the feature that allows you to program the unit so it stayes on a object by compansating the earths rotation. How do...
You will not find a manual. This scope has been out of production for several DECADES!
The small wedge must be polar aligned in order to track the sky. The legs must be adjusted for your latitude.
It has a motor inside that rotates the scope to compensate for the motion of the sky once the scope is polar aligned.
Read these:
http://starizona.com/acb/basics/using_polar.aspx
http://www.meade.com/manuals/lx200/apxb.html
Oct 14, 2010 | Bushnell Optics
Recently acquired a used Meade 8" LX200 EMC. The unit presents very well cared for by previous owner. Upon receiving it, I followed the manual's instructions in assembly and then operation. Upon turning...
I have a LX200 EMC 10". I had a similar software problem and solved it by downloading AstroFinder, bypassed the onboard software of the telescope, and controlled the telescope via my laptop. This was a more user frriendly method and allowed easy alignment of the telescope.
Apr 21, 2010 | Optics
Bolt holding dec drive motor on 16 loosens.
You have a LARGE Meade telescope. This should be an easy fix if you can disassemble the fork arm and get inside.
First I would contact Meade customer service to see if they have a manual that shows disassemble instructions. If not I would join the Yahoo LX200 forum and look for help there with an owner of the 16 inch model.
http://www.meade.com/support/index.html
Just search in Yahoo Groups for the LX200 forum.
On smaller scopes the DEC motor is held on by two spring loaded bolts, probably one has become loose?
Nov 04, 2009 | Meade LX200GPS Telescope
Fist time alignment issues.
Did you calibrate the motors and TRAIN the drives? If not do these first--
During alignment the "alignment" stars may or may NOT be visible in the eyepiece-- CENTER the star. Once you do this with two stars your gotos should be good.
Mar 11, 2009 | Meade Optics
Problem with start up on telescope
Most probably, flat batteries. Autostars go berserk when batteries are even a little low. Try it with a mains power adaptor instead.
Otherwise, maybe its a dodgy curly cable, broken Autostar, broken control panel or Autostar firmware needs reloaded
Jan 29, 2009 | Meade LX200R 8 in. (600 x 203mm) Telescope
Calibrating & Aligning the Meade 10" LX200 GPS Telescope in the Southern Hemisphere
  1. Do a Calibrate Sensors
  2. Do a Train Drive in RA and also DEC
This makes sure that the scope is calibrated properly.
  1. Do an AUTOMATIC ALIGN
  2. when asked to center star, look for the BRIGHTEST star that is close to the scopes field of view. It will be that star you need to used the arrow keys on to centre it in the scope eyepiece and press enter.
  3. This star can be as much as a HANDS distance away from the centre of view
  4. If you cannot identify the star it is asking you to use, press the SCROLL DOWN key to choose another star, keep doing this until you see a star you recognise.
That's it!
You can also hold down the MODE key for about 4 seconds and scroll through the scope info. Make sure you have the correct location coordinates ( Lat/Long) and the correct time set.
Select a bright object first such as a planet and GOTO it. Once you have manually centered it in the eyepiece, press ENTER and hold it for 6 seconds, the handset will say " Press ENTER to sync", press enter and you have updated the scope with the coordinates of that object.
Oct 20, 2008 | Meade LX200GPS Telescope
GOTO ERRORS MEADE LX200 10" CLASSIC
Most problems tend to be mechanical. Have you 'trained' the drive and set the backlash values? Those 2 can have dramatic effects on pointing accuracy. Also, if the optical tube is not in alignment with the mount, then nothing will work correctly. To check that, have the telescope in Alt-Az configuration, inside the house, loosen the RA lock, and shine a laser pointer on the corrector plate. as the telescope is rotated about the RA, the reflected spot should be steady. Adjust the DEC to minimize the diameter of the circle that is drawn. What is left, is the out-of-true on the DEC axis. That can be adjusted with the tube cradle alignment bolts.
Oct 17, 2008 | Meade Optics
Meade LX200R 8 in. (600 x 203mm) Telescope Logo
453 people viewed this question
Top Meade Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Experi
Level 1 Expert
Greg Cann
Greg Cann
Are you a Meade Optic Expert? Answer questions, earn points and help others
