Space heater One of the 2 quartz elements had burnt out. Is there a replacement available.??
  • 625 Answers
Try this site for replacement quartz heater elements.
www.infraredheaters.com/quartz.htm
Posted on Feb 02, 2008
Can I buy a heating element for this heater?
On google
Patton replace heating element Heaters Questions ... - Fixya
www.fixya.com > Forum > Tags > replace heating element > Heaters
Patton heaters replace heating element related questions and answers. Ask yourPatton ... I can't seem to find a phone number for the manufacturer to call for parts. Any help? ... Question about PQH307UM Electric Utility Heater. 1 Answer ...
Patton PQH307UM Electric Utility Heater Quartz elements ...
www.fixya.com > ... > Patton > Patton PQH307UM Electric Utility Heater
Patton PQH307UM Electric Utility Heater, quartz elements replacement related ...Element. Where can I find replacement quartz tube heating. Element Infrared ...
Patton PQH307UM Electric Utility Heater Element ... - Fixya
Patton PQH307UM Electric Utility Heater, element related issues. Get free help, solutions & advice from top Patton experts. ... The heating element is above the thermostat, and all you will see is a round disc with two wires attaching to. Ad.
Patton PUH680-U Utility Heater Replacement fan motor ...
Jan 19, 2016 | Patton PQH307UM Electric Utility Heater
Bulbs burnt out
i would check with the manual to see if it can be replaced it look like heating elements not bulbs
Mar 16, 2013 | Pool & Spa
My fostoria spacer stop producing heat model 1520 3A. Smell a burn odor fan still works. Sounds different too. can you help? Dennis
Your electric space heater works by using a quartz infrared element, something that can eventually burn out due to use/defects. To fix your space heater, you will have to get another element specific to your model fostoria. While I did a quick search online, I could not find any matches to a replacement, but you can still call the company for one. Before calling, though, check to see if your heater is still under warranty, probably 1 to 2 years. The number for fostoria is 1-800-495-4525. Best of luck.
Mar 03, 2011 | Fostoria FES - 1520 - 3A Heat Wave Utility...
Need Marvin quartz tubes
Marvin Replacement elements are available from Quartz Infrared Inc for $17.95. You can order them directly here:
http://www.quartzinfrared.com/Merchant2/merchant.mvc?Screen=CTGY&Category_Code=Marvin
Dec 12, 2009 | Marvin 2060 Compact Heater
How do you change the heating elements
Marvin replacement elements are available from Quartz Infrared, Inc for $17.95.
There are links to the instruction manuals there as well. They include information of how to replace the elements.
Nov 22, 2009 | Marvin W.B. 7260 Quartz Heat N Light...
I need the replactment elements for a Marvin 2060 heater, where can I find them?"
Marvin replacement elements are available from Quartz Infrared, Inc for $17.95. You can order them directly here:
Nov 16, 2009 | Marvin 2060 Compact Heater
The heating elements are burnt out. where can I
try this web link look for quartz tubes.
http://www.infraredheaters.com/quartz1.htm
Oct 14, 2009 | Marvin Quartz Radiant Heater
Need Marvin Heater replacement element (model 2060)
Marvin replacement elements are available from Quartz Infrared for $17.95.
Nov 23, 2008 | Marvin 2060 Compact Heater
Marvin Quartz heater element
Very simple to install the replacement element. Insert one end of the element into the bottom receptacle on either side, press the element down (it's spring-loaded), then slide the top of the element into the center opening of the top receptacle, push to appropriate side (the side of receptacle, same as the bottom), then release. Then do the same with the other element (if both are out).
Mar 03, 2008 | Marvin 2060 Compact Heater
Presto Quartz Heater element 1500 watts
Hi, you can find it on amazon for sure, here take a look: Amazon com Quartz Heater element 1500w. I hope this was helpful. have a nice day
Dec 07, 2007 | Heating & Cooling
Heating & Cooling Logo
337 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
