Question about JVC AV-48WP30 48" Rear Projection Television
I BROKE THE COAX CABLE THAT GOES INSIDE THE TV TO CONNECT TO CABLE
THE metal piece popped off..WHat do I do? It will not go back on?
  • vickanie Feb 01, 2008
    repair
  • Vista Electronics May 11, 2010
    You can bypass the problem = 0 $$.............Or repair...
    Which would you like to do ?................T.
  • 77 Answers
You can run the cable signal into your vcr, and then use composite cables from the vcr to your tv (red, white and yellow). You will have to use your VCR to change channels though.
Posted on Jan 30, 2008
Popping noise when I turn.
cv joint is broken needs new axle
Mar 13, 2013 | 1998 Jeep Grand Cherokee
2002 1.3 Kia Rio. Pushed in clutch pedal, heard metallic pop, half a piece of a metal ring + half a clip sitting in driver's footwell. Pedal will depress and release but clutch wont engage
I had this same problem the cable is fine its a clip on outer cable to stop it mooving when you press clutch mine poped when I tightened the clutch cable still don't have solution though waiting to payday to take it to garage
Mar 22, 2012 | 2002 Kia Rio
Rear view mirror fell off the glass, how do I take the plate off the mirror so I can glue it to the windsheld
Loosen the the tiny allen set screw if it has one, OR it just pops/slides out, and it is hard to get it to do that. Hold the mirror like it was on the glass, the metal piece comes out the bottom or towards the dash. Also, when glued you will have to slide the mirror back onto the metal piece starting at the top and push it down until it locks....you'll know!! You might think your going to pop the metal off the glass but keep firm steady pressure and it'll go.
Aug 20, 2011 | Chevrolet Lumina Cars & Trucks
I bought a watch and we can't get it to work. We think the battery needs to be changed.
If you take a look at the back of the watch, look for screws holding on the back plate. If there are screws (usually, if they are there there is one in each corner -- unscrew them. If there are no screws in the back of the watch, look VERY carefully at where the backing for the watch connects to the front piece of the watch. There should be a small indentation somewhere along the rim -- use a knife or a small screwdriver in that groove and pop the watch backing off.
Once you have the back of the watch off, you will see the battery right there. Sometimes they just pop out (held in by the watch back) ... sometimes there is a small piece of metal holding it in (in which case you should try to rotate the metal piece off the battery -- don't bend it).
Once the battery is out, take it to a store that sells watch batteries and match the battery type exactly (a lot of watch batteries look the same, but you need an exact match). Put the new battery in, cover it with the metal tab (if there was one) by rotating the tab back over the battery like you found it. Put the watch backing back on (and replace the screws if there were any).
Hopefully, that will kick start your watch for you, and you should be all set :-)
May 24, 2011 | Cars & Co Disney Pixar Cars Mcqueen Analog...
Agitator will not spin
check the lid switch first,lift the lid a couple of inches and close it down,if it clicks the lid switch is good and you most likely broke the motor coupling.remove the twoscrews that hold down the top console,lift it up and with a screw driver pop the metal clips and disconnect the lid switch wires in the middle,it's a white platic connector,now remove the whole cover of the washer,down the bottom you'll see the pump.with a screw driver pop the two metal clips and remove the pump,next remove the tow screws and clips holding the motor in place and pull out the motor,on the back you'll find the coupling,there should be two pieces of white plastic with three arms on each piece and a black piece of rubber that goes in between the two white pieces,remove the old coupling and tap on the new pieces one on the motor shaft and the other on the tranny shaft,slide the rubber piece on the tranny part of coupling and then line up the other piece that's on the motor shaft slide it together and put everything back,it's easier than it sounds,let me know how you make out,if you sent the model number i could of gave you the part number,i think it's PL337
Aug 13, 2010 | Kenmore 22422 Top Load Washer
Get the top off a front load dryer?
there should be 2 screws connected to a small piece of metal on the back. Take the screws off (the metal piece holds the top and bottom together). The front should swing up and back after you pop the front off with a screwdriver.
Feb 27, 2010 | GE Dryers
How do you change front headlight bulb in 1999 vw cabrio
Raise hood (of course), behind the headlights you'll see a black rectangular shaped lid with a (I don't know what to call this) piece of metal strapping it down. This metal piece is about is comparable to a metal clothing hanger from the dry cleaner. Pop that metal piece up and then you can remove the back of the headlight casing. I hope I'm not out of line to assume once you look into the casing you'll find it's pretty self explanatory.
Dec 08, 2009 | Volkswagen Cabrio Cars & Trucks
2003 trailblzer head light bulb replacement
on a 2003 Chevy Trailblazer, you have to remove the grill to access the back of the head lights. It takes a good pull (don't be afraid to use a little force). Pop the hood and there 4 metal pieces that slide up and several plastic pieces that pop up. You will see the lips on the metal slides (about an inch in width) and you pull those up to loosen the grill. There are 2 of these slides (one on each far side, almost hidden) that are hard to get your hand into that you might need a screwdriver or something for leverage to slide them up. Then pop up the plastic pieces holding the headlamps in place and with a little force pull the grill off.
Then you can access the back side of the headlamps to replace the bulbs.
Jan 08, 2009 | 2003 Chevrolet TrailBlazer
Key popped off keyboard
On the Keyboard, There should be a small little clamp housing. On the back of the key you should see a piece of metal that is sort of Staple shaped (A non bent staple) Just try and put the ends of the metal into the housing, Then apply a little amount of force onto the key to pop it back in.
Before applying pressure, Make sure that both ends are properly in place.
Hope this helps!
Jan 05, 2009 | Sony VAIO VGN-FS640W Notebook
JVC AV-48WP30 48" Rear Projection Television Logo
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
