Speed up your computer by:
-- cleaning system junk
-- optimizing computer services
-- optimizing internet
-- repairing registry
-- defraging registry
-- clearing browsers junk
do these things with some secure tool such as Intel Software Partner Reginout.
Thanks
1. stop those unnecessary start-up programs which will affect computer boot time a lot.
2.do a disk defrag or a free registry defrag.the former will free up your disk space, and the latter will give a clean registry.
3. notice that just cleaning up registry is not enough. you should fix registry errors.Registry is so important to a computer, so if you are unfamiliar with it ,do not delete anything by yourself, or your computer will collapse.
4. remove all junk files and history.
5.fully scan your computer. Virus always cause a computer slow down. At the same time, you should also know that using more than 1 antivirus software is harm to your computer. They will make a big confliction by uncompatible with each other.
6. Add some RAM, which is helpful to computer speed. Do not put programs on C driver, for it store all system information.
7. if all above do not work, you may consider to do a reinstall of Windows. Before you do it , please remember to back up all your important files.
Good luck to you.
I would install Microsoft Security Essentials and run a scan after downloading all the updates. If you are running Windows XP, you can also run Combofix before installing Microsoft Security Essentials.
If you have Norton, Mcafee, or any other antivirus software, ad scanners, etc., it would be a good idea to uninstall them before installing Microsoft Security Essentials.
If you don't use System Restore,
it is a good idea to disable it by right clicking My Computer, click
properties. On the System Restore tab, check the Turn off system
restore option, and click Ok.
If this doesn't speed things up tremendously, try installing more RAM, or replacing your RAM with larger sized sticks.
Combofix and Microsoft Security Essentials can be found using Google.
A good, free firewall replacement that uses very little resources is Comodo Firewall. This can also be found using Google.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Oh you need to provide more details like the RAM...
Clean ur registry....
use Tuneup Utility
get it from my site Download page
www.sureshayyar.110mb.com
