Question about Sharp AR-M237 Copier
H5-01 I have gotten advise to enter the fuser reset code, but where do i access that code??
  • kvanmeter Jan 30, 2008
    ?asdf
  • preach Feb 15, 2008
    Sharp Ar 337 copier showing H5 01 Service Code.
    How do I reset?
  • 61 Answers
Hi, to reset H5-01 press these buttons: #, *, C, *, 14, start 'are you sure'- yes
regards
Andy
Posted on Feb 04, 2008
3 Suggested Answers
SOURCE: Sharp service code H5-01
To enter simulation mode to reset errors enter this sequence on keypad.
P, * , CA , P then enter sim # 14 to reset code.
press " custom settings" button to return to previous menu and CA to exit sim mode.
Posted on Dec 11, 2008
  • 3 Answers
SOURCE: H5-01
what kind of machine is, i know it is a sharp from the code butwhat model.
Posted on Aug 19, 2008
Fuser code reset
i do not know what machine you wait to reset the fuser code and the service code it has S.C but to enter the servie mode you press (star-107-#) then mode enter then check where scrol you find where its says error reset
Jul 12, 2014 | Gestetner 2 Pack 3222, 3227, P7027, P7032,...
Call service c
your fuser tripped an error flag. Try power cycling the machine. If that does not work then press the button to check job status and enter 10871087. You might be able to enter that code from the copy screen. In any case lets continue, you enter that code and then screen changes. You then enter 906... That is a general reset. You could also try 163 that is a fuser reset. If neither one works then you need a new fuser unit
in many cases, the cause of fuser failure is not using oem toner.
kyocera task alfa 180 oem toner
Sep 13, 2012 | Kyocera TASKalfa 180 Copier
KYOCERA ECOSYS FS-1118 ERROR-C-6400
Error code relates to the fuser unit.Suggest that it is replaced.
Nov 16, 2011 | Kyocera FS-1118MFP Laser Printer
Service Light keeps coming on with Code C440. Please advise why?
This is a fuser heat error. Have you performed the reset procedure? If not just turn off the main power, hold the 0 and 8 keys WHILE turning the power back on. Type in 400 then press Start. Set the displayed number to 0 (zero) then hit set or enter.
Power off then back on and the code should be cleared. If it keeps coming back then the fuser unit will need service. Most common fault is the thermistors which are small electonic parts that monitor the temperature of the fuser unit. Pretty in-expensive parts.
Good Luck and Thank You for using Fixya.
Jan 04, 2011 | Toshiba e-studio 455 Copier
Panasonic dp 2000 pm error code e04-01 need help
this is fixing error
enter the service mode
f9
enter
Apr 02, 2010 | Panasonic Workio DP-2000P Copier
H5-01
Hello sir;That code means, fuser jam, fuser not installed or pcu main board/sub board, seem like fuser unit not installed.
Mar 22, 2009 | Sharp Office Equipment & Supplies
Dec 10, 2008 | Office Equipment & Supplies
H5-01
Aug 19, 2008 | Office Equipment & Supplies
Sharp AR 5320 error h200
H4 indicates there is a fuser error.
Try resetting it by the pressing the following buttons on the display in sequence,
#, interrupt, Clear, interrupt,
display should go dead,
enter 14,
then press print, This will clear the error code
press CA to get out and return to normal.
However if there is still a problem with the fuser, the code will return. Then you may need to have a tech look at what is the problem.
Hope that helps...
Lbcoaster
Aug 05, 2008 | Sharp AR-5320 Black and White Copier
Error message on screen E000001-0002
E000001-0002 refers to the fuser assy either getting to hot or not hot enough. Fuser error codes cannot be reset by power cycling the machine even though that is what the display tells you to do. In order to reset the fuser error code you must enter the service mode & reset the code. To enter the service mode: press"Additional Functions" button (looks like a picture of a head with a star inside) press the #2 and #8 at the same time (simultaneousley) press "additional functions" again The display should show a choice of copier,feeder,sorter,fax,or board service modes Select copier select clear select ERR press OK Turn power off & back on. ****IMPORTANT**** After clearing error stay at the machine to see if it comes to ready. The fuser assy can reach 139 degrees C.(Water boils @ 100C) The error can only be cleared through the service mode because a technician should inspect the fuser to verify there is nothing faulty that could possibly start a fire. If you enter the service mode & clear the error, power cycle the machine & during warm up the machine throws a code again- turn it off, unplug it & call a tech for fuser repair. Good Luck!! I can be reached @ bspier@carlsonsupplies.com if you have any questions.
Sep 21, 2007 | Canon imageRUNNER 2200
Sharp AR-M237 Copier Logo
1,274 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
