Question about Lexmark X5470 All-In-One InkJet Printer
Lexmark x5470, alignment error
Just says remove tape from cartridges and check paper help please i have 4 with same problem
  • 7 more comments
  • Compown Feb 22, 2008
    Printer prints slightly blurred image on right side of paper.
    I've purchased new cartridges color/black,... cleaned contacts in the carrier and ran the alignment program, still blurry.
    Thanks for a response.
  • rgardner11 Mar 05, 2008
    I had an alignment error and now I can no longer connect to the PC. Treid powering off disconnect USB and rebooting to no avail.
  • Anthea Gilkinson
    Anthea Gilkinson Apr 09, 2008
    same here no matter which cartridge i use, can print without or could until yesterday now just get blank pages & i'm not out of ink
  • saljacko Jul 14, 2008
    same prob as above!!
  • creyn71 Aug 14, 2008
    Anyone have a fix for this? I have one I just bought $50 in ink and I am getting the same error
  • homefinder Aug 21, 2008
    Put in new cart., now says remove tape, won't come to center so I can remove.
  • joannelj Oct 17, 2008
    Same thing. Brand new cartridges, no tape anywhere, but the same message. It will let me print, but the prints don't look too good. I mostly get this error when I try to align the new cartridges.
  • Anonymous Mar 30, 2009
    I have the same problem, but when I hit cancel it will only print in black. I cannot get it to print in color, and there is no tape anywhere on the cartridge.
  • Anonymous May 05, 2009
    All I had to do was hit cancel!??? Ahhhhhhh stupid printer!!
    Problem Solver:
  • 7 Answers
Fiend your solution direct from Lexmark. Here is your solution
http://www.lexmark.com/printer/prob676ijt65/solution
934
Posted on Mar 03, 2009
I had this same problem, I just cancelled the alignment by pressing the cancel button and everything works fine and prints well. Don't know what was wrong!
Posted on Nov 10, 2008
2 Suggested Answers
johnyu_05
  • 141 Answers
SOURCE: lexmark x5470, alignment error
hi alyciaadamo;
im not sure but i think uninstalling and reinstalling will not get the printer set back to default settings. can you navigate through the menu even if you see the error? press the cancel or something? if you can,look for reset factory settings.
also try to remove all the ink cartridge, and power cable from the printer, wait for 30mins and try it back.
I just want to know if your using genuine lexmark ink for you printer. :)
Posted on Jun 06, 2008
Just got a X5470 printer from a friend of the families. Said he was not sure what was wrong with it. I didn't have the cd so i installed it offline. It says that I have colored and black ink, have...
Make sure you are inserting the correct cartridges for your model. The Lexmark X5470 uses 32 or 34 black cartridge and the 33 or 35 color cartridge.
Try to follow the steps below to identify and fix the problem:
  1. Open the printer cover and remove the cartridges. Check the encoder strip (transparent strip usually found behind the cartridge carrier) and make sure it has not gotten unseated from its position.
  2. Close the cover. Unplug and re-plug the printer into the power source to reset it.
  3. When the printer turns on, check for any errors on the printer display screen. If "alignment problem" error appears, please contact Lexmark Technical Support Center for additional assistance.
  4. If no error appears, reinsert one cartridge first. Close the cover and check for errors.
  5. Reinsert the other cartridge.
  6. Replace whichever cartridge is causing the error to appear. It may be faulty. You may also try to insert a different known working cartridge to determine if the cartridge you're currently using is defective.
If the problem continues, please contact Lexmark Technical Support Center for additional assistance.
Aug 14, 2011 | Lexmark X5470 All-In-One InkJet Printer
I have a X5470 Lexmark printer and it keeps telling me there is an alignment problem and is asking me to remove tape from the cartridges. There is no tape there that I can see.
It could be the cartridges in the carrier. Open the printer cover. Remove both cartridges. While the cover is open, check for any obstructions in the cartridge carrier's path. If all is well, close the cover. Unplug and replug the printer into the power source to reset it. When the printer turns on, reinsert one cartridge first then close the cover. Check for any errors. Then, open the printer cover again and reinsert the other cartridge. Replace whichever cartridge is causing the error to appear. Or you can try to insert a different known working cartridge to determine if the other is faulty.
May 20, 2011 | Lexmark X5470 All-In-One InkJet Printer
I don't see a paper jam, but that is the error i keep getting. it will let me print or copy anything. the printer i have is a lexmark x5470
Leading cause of paper jams is debris/foreign objects that have accidentally fallen into the paper feed area.
1. Remove the sheets of paper from the feeder.
2. Grab a flashlight and look inside for any debris.
3. If you're willing and physically able, you may also turn the printer over. Any debris should just freely roll out from the feeder.
4. If feeder is clear, open the printer cover and remove the cartridges.
5. Check the cartridge area for any obstructions/debris that could cause this error or problem.
6. If cartridge area is clear, close the cover.
7. Unplug and re-plug the printer into the power outlet to reset it.
8. When the printer turns on, reinsert the cartridges and load some paper. Try to print again.
Apr 26, 2011 | Lexmark X5470 All-In-One InkJet Printer
My printer error message indicates- Alignment problem.(1) Remove tape from cartridges.(2) Check Paper.(3) Press Ok to retry. I do not see it being easy to remove tape from cartridge,but my allignment paper...
Make sure you are using the correct cartridges for your model. Try to remove both the cartridges. Close the cover. Unplug and replug the printer into the power outlet to reset itself. When the printer turns on, reinsert the cartridges when prompted. Close the cover and check for any error. If none, try to print again.
Apr 11, 2011 | Lexmark X5650 ALL-IN-ONE PRINTER
I installed a new cartridge and I keep getting an error message to remove the tape, which I did before the install. The alignment test fails.
Printer normally does the alignment printing whenever you do something on the cartridges (removing, reseating or replacing). Try to remove the cartridges from the printer. Clean the nozzles using a damp paper towel, if necessary. Close the cover. Unplug the printer from the power source. Plug it back in after 10-15 seconds. When it's ready, insert the cartridges. Let the printer print the alignment page again. Let it finish the whole page without cancelling it.
Check if the problem persists.
Apr 01, 2010 | Lexmark X5470 All-In-One InkJet Printer
When I turn on my Lexmark printer X5470 it always says to align Cartriges ins this normal?
Hello. Printer normally does the alignment printing whenever you do something on the cartridges (removing, reseating or replacing). Try to remove the cartridges from the printer. Clean the nozzles using a damp paper towel, if necessary. Close the cover. Unplug the printer from the power source. Plug it back in after 10-15 seconds. When it's ready, insert the cartridges. Let the printer print the alignment page again. Let it finish the whole page without cancelling it. Check if the problem persists. Hope this helps.
Mar 19, 2010 | Lexmark X5470 All-In-One InkJet Printer
Lexmark X7675 error: Paper Jam (on printer control panel). Have turned off/unplugged several times, occasionally clears error, but it comes back. Sometimes just as paper has fed about 2 inches, sometimes...
Remove the cartridges. see any bits of paper left behind. Replace the cartridges. You will be asked to align again. Do this.
Hopefully, this will work
Good luck
luciana44
Jan 25, 2010 | Lexmark X5470 All-In-One InkJet Printer
Alignment problem
Disconnect from computer - remove cartridges - wipe the bottom of them - not the side - reinsert - reconnect - try again - should ask to realign cartridges... cheers
Jul 30, 2009 | Lexmark X5470 All-In-One InkJet Printer
hi alyciaadamo;
Jun 06, 2008 | Lexmark X4270 All-In-One InkJet Printer
Lexmark X5470 All-In-One InkJet Printer Logo
5,992 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
