Question about Pioneer Car DVD AVH-P6600DVD Car Video Player
Black screen When playing dvd's, I only see a black screen. I can hear sound, but I can't see the dvd video. However, I can scroll thru the different screensavers.
  • BigKB Jan 30, 2008
    thanks. i will try it as soon as i get my car out the shop
  • BigKB Jan 31, 2008
    do you know how to adjust the video output?
  • 871 Answers
try to check if your using pal or ntsc...try adjusting the video output and you'll probably get the picture eventually.
hope this helps.
fixya!
Posted on Jan 30, 2008
My lg dvd player doesn't show images (except the black and white diplay on the screen) but i can hear the sound playing, the kids might have changed some thing in the setup. please help if there a
Hello
You haven't given the exact model number ot your LG DVD, so I can only give you a general solution to this problem.
Get into its meny, surf through, come to SYSTEM adjust window, change the system. If a NTSC system recorded disc played with PAL system adjustment with DVD, there will be only black/white pciture, and vice versa.
Adjust it to the color system thathave been adopted your country. this must solve the problem. OK.
Jan 31, 2012 | LG Televison & Video
Why does my x ovision indash dvd player says caution do not watch while driving when I play I dvd? And is doesn't play the video it just stays frozen on the caution sign but I can hear the sound but...
i had this same exact radio installed in my avalanche before switching over to a different brand, there is a ground wire that should be labled parking brake, that you can just ground to the frame, and then you will be able to see your videos and not just hear them. I believe its a black or black and grey wire. but i know this will fix your problem. just carefully ground out your wires one by one till the video plays and you will have found the culprit wire.
Aug 08, 2010 | Car Audio & Video
Black screen, hear voices , but no picture playing?
check your screen back Light or get a working screen and test it or your screen flax is bad
Mar 31, 2017 | Mitsubishi WD-73C9 73" DLP TV
My ps3 will play disk but i have no home start up screen. it appears black although you can hear the sounds as you scroll through the menu
First thing you should try is a manual video reset.
While the PS3 is off (red led) hold down the power button until you hear the SECOND beep, QUICKLY release.
That will reset the video.
Let me know if that works.
Nov 27, 2009 | Sony Playstation 3 (PS3) Console
Toshiba tv screen goes black every 5 minutes with sound still on
Is it ok when you watch regular TV thru the cable or sat?
Jun 16, 2009 | Toshiba 46HM95 46" HDTV
I can only record and play back in black and white.
siri,
for the black and white screen output of your DVD and VCR.
1) for DVD player: using remote control locate "setup" button and click.a dialogue box should appear indicating " audio setup" video setup" etc.....
2) select and scroll to "video setup". in video setup there should be an option to choose "AUTO" "PAL" or "NTSC"
3) choose "auto" then check if any change in screen color.
for VCR, locate a switch or button indicating "PAL" "Auto""PAL SECAM" "NTSC". same with the dvd choose and select "auto"
note: if you still have the manual for both VCR and DVD check the instruction with regards to video color setting.
cheers,
mark
Jan 15, 2009 | Philips Magnavox DVD/VCR Dual Player
Freeway indash DVD
u need to switch function screen to dvd screen. Button is on front of unit to scroll through screens.
Dec 14, 2008 | Kenwood KVT-817DVD DVD/CD/MP3/WMA 7"...
No picture on tv when i turn on dvd. get split screen black & whi
Give this a try. Using your user's manual, locate the "Configuring your recorder" section. Under this section there will be "System setup - general" subsection. Being that you are unable to see anything on your tv display you will need to use your manual as your display. Press the "SETUP" key on your remote. Once again using your manual as your display, scroll down to "Restore factory settings" and press "ENTER" As long as you are located in North or Central America and using interlaced video outputs you should have your normal display back.
Hope this helps.
Nov 24, 2008 | Protron PD-DVR100 DVD Recorder
Black and white picture
Try going into player's menu, and set video out or TV type to NTSC.
It might have switched to PAL, or disc is PAL and player is set to any.
Dec 13, 2007 | Cyberhome CH-DVD 300 DVD Player
Pioneer Car DVD AVH-P6600DVD Car Video Player Logo
160 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
