Question about Hitachi 43UWX10B 43" Rear Projection Television
Hitachi tv problem
Not all the time but at the most inconvenient time the tv will go off and immediately start chirping and try to come back on continuously over and over. sometimes it will not come back on for an hour, sometimes it comes back on in 5 minutes. it also had rainbows around faces and objects. i had a repair tech come out and he replaced (2) conv. drivers and (6) rgs. i am still having the same problem. can you help.
thank you,
karl
    Sergeant:
  • 261 Answers
It sounds like a capacitor is going or is bad in the powersupply section of the tv. If your lucky it could be a bad solder connection on the power supply board. Let me know if you have any other questions. Also where are u located. I am in Louisville, Kentucky.
Posted on Mar 04, 2008
No chirp when arming vehicle
Either your siren is broken, not properly grounded, the system is in valet or, the chirps were deleted. To add chirps, turn the key on then off, immediately press and release the valet switch three times. If the chirps were off you will hear one chirp from the siren.
Feb 14, 2014 | Prestige Remote Start
I have a Hitachi 43UWX10B that won't turn on. When I try, the red power light flashes, and I hear intermittent chirping. Any way to verify the problem and estimate repair costs?
Your convergence chips have failed.
Sometimes when they fail the TV will look 3D or distorted and sometimes it will just loose video and audio and chirp.
This is a common problem. Your convergence has gone out.
Common symptoms are...
1) 3D Video
2) Warped Video
3) Convergence menu does not adjust the red or blue correctly. 4) TV Chirps
Go here for a solution...
http://www.fixya.com/support/r2861627-updated_convergence_problems_amp
Sep 05, 2009 | Hitachi 43UWX10B 43" Rear Projection...
Hitachi rear projection tv wont power on makes a chirp
You could have a bad HV Transformer causing it to shut down.
Jun 19, 2009 | Hitachi 43UWX10B 43" Rear Projection...
Hitachi 50fx18b 50" projection no power
Does it chirp? If so you need convergence chips replaced.
Read the link below.
Yes - You will need to either remove the circuit board or lift up the tray. If you are not sure how to do it yourself read the link below.
  • This is a very common failure on Projection TV sets.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV Makes Chirping Sound
You can see some example photos and find a solution here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 07, 2009 | Hitachi 50FX18B/19K 50" Rear Projection...
Hitachi 53UDX10B power button flashes, chirping noise, LEDs flash
The convergence issue might not affect the TV to the point of not turning ON.
The chirping noise you hear, it means there is a short circuit in the circuitry, possible the HOT or power supply assembly.
Apr 22, 2008 | Hitachi 53UDX10B 53" Rear Projection...
No picture, no sound, and a chirp
Look up Hitachi home page on the net. Go to their support, and enquire where you can purchase the service manual for your set.
I can tell you in advance that you will need the proper test instruments and knowledge and training to troubleshoot the TV set. Failed components are not visible by eye unless there was a big burn-up.
Many of these models are normaly serviced by board exchange.
Jerry G.
Apr 20, 2008 | Hitachi 43FDX01B TV
Hitachi 27AX1B immediately shuts off at startup
you are going into shut down check regulator check for bad solder connections get back to me
Nov 02, 2007 | Hitachi 27CX01B 27" TV
Flashin power light - wont come on
The "green light flashing to the chirping" circuit may be defective.
Not a basic diagnosis--service literature and/or knowledge of each green light circuit will be needed.Possible shop repair.
Oct 05, 2006 | Hitachi 43UWX10B 43" Rear Projection...
Chirping noise and flashing front power light.
Theres a short somewhere in the set. Most likly the HOT is shorted or the vertical IC has caused this in the past. In one case I had shorted convergence IC cause this symptom.. This set is solid state and there are no user serviceable parts inside so please call a trained tech to assist you with this problem Good Luck
Aug 17, 2006 | Hitachi FDX Series 43FDX10B 43" Rear...
Hitachi 43UWX10B 43" Rear Projection Television Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
