Question about Panasonic NN-S960WA Microwave Oven
Panasonic Microwave Warm
Panasonic NN-S960WA 1300w Inverter Microwave heats items but does not get them hot. There was a pop or crackling and a brief burned smell of an electrical component. After removing the cover, no obvious damage can be seen, except for load buzzing coming from the Hi-voltage microwave cage. All else is working fine. Just guessing here: I think...that the magnatron and inverter are both contained in this protective housing. The magatron is worth replacing but the inverter... cost more than the unit when new.
  • 2 more comments
  • RockieEstes Feb 07, 2008
    No separately mounted Cap (silver can) on this newer model. There is an SMPS kit available though to replace the IGBT (bolted to the heat sink) that was found to have a burned off lead. A few other pieces are available in the kit for change out and update as well. Kit691 from Wagner.net
  • RockieEstes Feb 17, 2008
    This "newer" model does not have the capacitor can anymore. All the parts are on the invertor board. The cap are tiny little fellas. The problem is the heat sink mounted "1M30D"
    IGBT (Insulated Gate Bipolar Transistor). This swit over-heated and burned a leg off at the circuit board.
  • rderamon Jan 28, 2009
    I have not taken the unit apart yet but it has the same basic problem. It heats but it doesn't power up all the way. After about 10 seconds or so, you can hear a crackling or buzzing noise coming from the unit. The serial number is AD011900646. It was manufactured in April 2000.
    Given its age it may not be worth fixing.
    Thank you for any help you can give me.
    Rod
  • Anonymous Mar 22, 2014
    I don't see a way to access the light bulb. Is it replaceable?
  • 579 Answers
Replace the h.v. capacitor (the silver can mounted in back under the magnatron) and the h.v. diode and it will be fine.
Hope Ya Fix It!
Posted on Jan 30, 2008
How do I remove the sensor inverter on the Panasonic NN-S96OWA ?
That's a misnomer.
And oven may have an inverter and it may have a sensor (usually either a heat sensor or humidity sensor).
Please note that FixYa is not currently notifying us Experts when Clarification Requests are answered.
So to allow us to help you effectively (at no charge), please post a
NEW problem to FixYa, and please include your brand name and the full model number from the tag in or on the unit, and your exact symptoms, so we can help you troubleshoot the problem and make recommendations.
Jan 08, 2010 | Panasonic NN-S960WA Microwave Oven
Panasonic genious sensor inverter 1300w nn-t664sfx displays code "h98" & will not run - what's the problem?
Mine did this once and it was the magnetron. Once replaced, it worked fine. Repair is an option if it is still under warranty or someone will do it on the cheap. Otherwise, just get a new microwave, since this is the main part.
Oct 04, 2009 | Panasonic NN-S960WA Microwave Oven
My Panasonic Microwave Genius 1300W will not heat up the food and the rotate dish spins and the sensor reheat will not heat up the food. Nor cook Pop Corn when pressing the buttons to 2:00 cook time. I...
Sounds like the magnetron has failed. This is the component that produces the microwaves that heats the food.
The cost of the magnetron is about 95% of the cost of a microwave oven. Most people don't, for this reason, replace the magnetron, they replace the whole oven which is probably what you will end up doing.
There is a possibility that the circuit that provides power to the magnetron is faulty and you need to take it apart, find the proper electrical leads and test them with a volt meter. To do this you have to remove it from its mounting and take it apart. It is a fairly lengthy process however.
Benjamin
May 14, 2009 | Panasonic NN-S960WA Microwave Oven
Panasonic Model No. NN-S933BF Microwave Oven
No sorry the issue will be with eiher the inverter, the magnetron or the main timer board. There is a tracer signal that comunicates through these components and if it doesnt get to where it is supposed to go it wil just shut off, the big hint at that is the time interval. It is not something like a sensor heating up and causing a fault. it is not running long enough to get any thing hot it is in the electroincs. Too expoensive to repair, im sorry better to get a new one. Good Luck
Jun 17, 2017 | Panasonic NN-S950BA Microwave Oven
Stopped heating, shuts off before time expires
My panasonic microwave model # NN-S540BFW stops after 4 seconds after you hit the start button and cuts off on its own. What is wrong with my microwave?
Jan 12, 2009 | Panasonic NN-S763BF Microwave Oven
I want to defrost a small frozen food item for 2.5 minutes. How do I do this with my Panasonic Genuine Sensor 1300W Microwave? Thanks! Dan
You can download your Panasonic owner's manual here.
Dec 19, 2008 | Panasonic NN-T990SA Microwave Oven
What cause the wattage difference?
Wattage is based upon voltage & current. I would think that on the 1300W unit, either the voltage or the current is higher than that which is used on the 1200W unit.
Perhaps the magnetron in the 1300W unit is being driven harder. Are the fans the same size?, The magnetron in the 1300W could be running harder and they have a larger fan in it.
In any event, if the part numbers are the same, you should have no trouble using one units parts to fix the other.
- Jim
Feb 17, 2008 | Panasonic NN-S561 Microwave Oven
Panasonic Microwave NN-A770S getting hot on right side externally
If you described this to Panasonic very carefully, and they said it's normal, then I would say keep using it until such time that you get other symptoms. The inverter has some parts mounted on a large chunk of aluminum called a heat sink. It draws the heat out of the parts and the heat radiates and/or convects away. This keeps the circuit parts from overheating. As long as you have good air flow through the vents, it sounds okay.
Sep 13, 2007 | Microwave Ovens
Microwave
It's usually located on the floor of the oven behind the control panel, or with the door switches. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk Feel free to contact me directly if you have further questions. I appreciate your thoughtful rating of my reply.
Jun 17, 2007 | Panasonic NN-S960WA Microwave Oven
Panasonic NN-S960WA Microwave Oven Logo
545 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
