Question about Estate TEDX640JQ Electric Dryer
Kicks off circuit breaker
My estate dryer is brand new, everytime I turn it on it will run for a few mins then kick my circuit breaker off. The circuit breaker was replaced and its still doing it. What else can it be? The vent is clear, we have checked everything we know to do.
  • 1 more comment
  • valinky77 Jan 30, 2008
    Oh and it runs fine if u use the no heat setting, but even on the lowest heat setting it kicks the circuit breaker off
  • dryerkicker Jan 11, 2009
    I have the same problem, I am using 30A, 10 gauge wiring, dryer is rated at 5400W, so it should be correct amperage. Other thoughts?
    I have a Samsung Dryer. Also, it is hooked up to 2 x 15Amp breakers and only one of them is tripping after about 1 min of turning on the dryer with heat. I have replaced that breaker and it is still doing it, could it be a problem with the other breaker (the one that is NOT tripping)?
  • 4 Answers
Make sure your breaker is high in amps, at less 50 amp breaker
Posted on Feb 02, 2008
6ya staff
SOURCE:
Dryer kicks circuit breaker off after a few minutes running.
Hi gel937
Replace your thermostat, it is defective causing the dryer to overheat and kick the breaker
Mar 13, 2013 | iPhone Apps
Pool motor kicking the breaker only after a few minutes .
If the pool pump is running and then 10 minutes into the cycle it trips the breaker, then it is overloading the circuit. The pump is laboring, workingf too hard . The filter shoiuld be cleaned. maybe there is a blockage in the return line to the pool. the other thing could be the wire size to the pump, but you said that it was running last summer . so that should be OK
May 11, 2010 | Hayward 1.5hp Max Flo Inground Pool Pump #...
The hottub keeps kicking the circuit breaker off.
Either the breaker is bad or you have an electrical problem. Unless you know how to work with electrical problems call for service. If you unplug the hot tub and plug a lamp or hair dryer into the outlet does the breaker trip? If yes, call an electrician. If the outlet is fine call for service on the hot tub.
May 01, 2010 | Home
Dryer is flipping breaker after 10 minutes into dry cycle.
You have a weak circuit breaker . Should be a 30 amp or higher . If you have access to an amp meter , split the dryer cord , separating the 3 wires (do not remove the insulation ) . If you have a black round cord ( 4 prong ) , carefully slice into and remove the black insulation in a small portion only . Check the amps on both outer wires while running dryer . Make sure the amps being pulled are lower than the circuit breaker amps . On a black cord , test the black wire and the red wire amps . If the dryer has a short , it would not run for 10 min and then throw breaker . It would be almost imediate . A bad breaker will gradually get hot and then flip , but check the dryer amps anyway to be sure .
Aug 15, 2009 | Estate TEDX640JQ Electric Dryer
Dryer kicks off circuit breaker, pf code is on dryer. now won't let me do anything
pf is for power failure. sounds like You may have a short somewhere. Be careful of electric shock.
Apr 21, 2009 | Dryers
Dyer starts but after 1 to 3 mins the circut breaker kicks off
If it is the correct size breaker for the dryer, the circuit breaker may be weak and in need of replacement.
Mar 29, 2009 | GE DBSR453EBWW Electric Dryer
Kenmore dryer
first dryer should be on circuit by itself..if dryers runs ok for a while before tripping breaker call electrican to change breaker..change it not ck it ..too many times had electricans tell cust breaker ckd ok but after explaining to cust a breaker can not be ck without load they had breaker changed and solved problem ..not just old breaker but even new ones can cause problems..if breaker kicks as soon as dryer is turned on ck wiring at connection where ac is connected very seldom does any other issues with dryer cause immediate tripping of breaker
Sep 16, 2008 | Kenmore 63012 Electric Dryer
Dryer problem
ck vent system to outside also ck the vent hose behind dryer to be sure it is not being mashed flat when pushed back..while you have it out ck to see if cord connection screws are tight loose screws can cause cord to overheat and melt insulation causing short..if breaker trips immediately suspect dryer if runs for a time before kicking suspect weak breaker
Aug 09, 2008 | Whirlpool WED5100SQ Front-Load Electric...
Estate dryer kicks off circuit
you can check where the cord is connected to the drier did you use the cord off your old drier see if the cord is tight at the back of the drier and the center terminal of the cord should be on the center of the terminal block and why did you buy a new drier hold my rating till were done please
Jan 30, 2008 | Estate TEDX640JQ Electric Dryer
Estate TEDX640JQ Electric Dryer Logo
208 people viewed this question
Top Estate Dryers Experts
John Tripp
John Tripp
Mike
jimorris77
Are you an Estate Dryer Expert? Answer questions, earn points and help others
