Question about Apple iPod mini M9160LL/A MP3 Player
IPod difficult to turn off
I am having difficulty turning it off. Is there somthing I can clean?
  • Kurt Van Etten
    Kurt Van Etten Jan 30, 2008
    Thanks Longhorn_Fan. I appreciate the quick response!
  • 77 Answers
No. The contacts for the click wheel are sealed so cleaning won't help.
Sometimes ipod's just need a reset. Reset it by holding down the center and menu buttons for 10 seconds.
Posted on Jan 30, 2008
6ya staff
SOURCE:
Circle of dots only
Have you attempted to reset the ipod yet? And if that failed, does it connect to your computer at all? If so I would restore using itunes. It sounds like a hardware issue with the ipod itself, but by using those two trouble shooting steps you may be able to get it back to working normally. Just in case you are unfamiliar with how to reset or restore an ipod, I have included a step by step below. :)
Last Modified: January 28, 2009 Article: HT1320 Old Article: 61705 Summary Learn how to reset or restart iPod following a freeze.
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
How to restore iPod (ARTICLE NUMBER HT1339)
Open iTunes, and then connect your iPod to your computer using the USB or FireWire cable that came with your iPod.
After a few moments, your iPod will appear in the Source panel in iTunes.
Select your iPod in the Source panel and you will see information about your iPod appear in the Summary tab of the main iTunes windows.
Click the Restore button. You will be prompted with one or more restore options that may prompt iTunes to automatically download the latest iPod Software.
The 4 possible restore options are: Restore Option
1: Restore - Restores with same iPod Software version already on iPod. Restore Option
2: Use Same Version - Restores with same iPod Software version already on iPod even though a newer version is available. Restore Option
3: Use Newest Version - Restores with the latest iPod Software available. Restore Option
4: Restore and Update - Restores with the latest iPod Software available.
If you are using a Mac, a message will appear prompting you to enter an administrator’s name and password.
A progress bar will appear on the computer screen indicating that the first stage of the restore process has started.
When this stage is completed, iTunes will present one of two messages on screen with instructions specific to the iPod model you are restoring.
Restore Instruction 1: Disconnect iPod and connect it to iPod Power Adapter (typically applies to older iPod models).
Restore Instruction 2: Leave iPod connected to computer to complete restore (typically applies newer iPod models).
During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage.
Note: The progress bar may be difficult to see since the backlight on the iPod display may be off.
After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
If you have any difficulties please let me know
Apr 28, 2009 | Philips Audio Players & Recorders
Drum having a difficult time spinning
YOU'LL HAVE TO OPEN IT AND CHECK THE FELT SEAL IN BACK OF DRUM. THE DRUM ROLLERS. AND THE FRONT SHROUD SEAL.
Apr 13, 2009 | Dryers
How do i turn my nano chromatic off
hi,
just like any other iPods, press & hold on the pause button & wait 'til the screen turns off. Just make sure you don't have it on "lock." It's the orange switch.
if you're still having difficulties, try and check your manual that comes with your iPod.
P.S don't forget to rate our answers..
thanks,
Feb 18, 2009 | Apple iPod nano MP3 Player
Keeps losing the time ?
if you turn the ipod off all the way the unit turns down completly and is all use up a lot of battery power its somthing apple is still looking into so you sould leave it on standby and you will keep the same time and actully save battery life.
Nov 16, 2008 | Apple iPod touch
Ipod nano
try a reset
To reset your iPod:
  • 1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  • 2. Press and hold the Menu and Select buttons until the Apple logo appears, about 6 to 10 seconds. You may need to repeat this step.
Tip:
  • If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
  • If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
Jun 14, 2008 | Apple iPod nano 3rd Generation
Apple iPod Model A1136, 30 GB.
First make sure your hold switch isn't on. It's on the top or bottom and slides back and forth. It needs to be switched to the left. Once it is to the left, here's how you reset:
You can reset your ipod by holding down the menu and select (round button in the center) buttons down for at least 10 seconds. You'll see an apple logo flash, that's when you stop pressing the buttons. It will shut off, then back on.
Feb 14, 2008 | Apple iPod MA446LL/A MP3 Player
When turning on my iPod keeps saying to go to the Apple web site for support
To reset an iPod with a Click Wheel, including: ipodnano3.jpg ipodclassic.jpg icon_ipod_5g.gif ipodnano2.jpg ipodnano.jpg ipodphoto.gif ipodg4.gif ipodmini.gif
  • iPod nano (3rd generation)
  • iPod classic
  • iPod (5th generation)
  • iPod nano (2nd generation)
  • iPod nano
  • iPod with color display (iPod photo)
  • iPod (Click Wheel)
  • iPod mini
  • iPod mini (2nd generation)
  2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
Nov 26, 2007 | Apple iPod MA446LL/A MP3 Player
IPOD shows no file found
  • iPod classic
  • iPod nano
  • iPod mini
Oct 10, 2007 | Apple iPod MP3 Player
Apple iPod mini M9160LL/A MP3 Player Logo
52 people viewed this question
Top Apple Audio Players & Recorders Experts
Ekse
Sean Cole
Sean Cole
Jeffrey Groves
Jeffrey Groves
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
