Question about Hitachi 61UWX10B 61" Rear Projection Television
Hitachi 61UWX10B 61 in | TV will not turn on
My tv will not turn on and also do not see the red light on front. All I hear is a clicking noise with it. No picture and no sound. Will appreciate if any one can provide any expert advise/solutions. Thanks.
  • dhanney Feb 02, 2008
    Thanks to Fixya ! for the excellent solution.
  • joegc299 Jun 22, 2008
    My tv just stopped working while watching. Wont turn back on. Tried to unplug and plug in again, looked for somesort of reset button. No red light and not getting power.
    President:
  • 4,402 Answers
If your set all of a sudden won't come on, e.g., the screen is blank, but the LED on the under the screen next to the on/off switch keeps flashing, then there may be an internal fault on the set that needs to be reset.
To force the reset, try this:
  • Unplug the set and wait a few seconds
  • Replug and see if the video returns
Whenever the set senses an internal fault through its monitoring circuitry, it essentially shuts down the set. The flashing LED provides the indication that a fault has been detected. Removing power to the set resets the monitoring circuitry. When plugged back in, the circuitry again does a check of the systemHitachi 61UWX10B 61 in | TV will not turn on - 1.gif. If it finds that there truly is a problem, then the set is shut down and the LED will again flash.
Posted on Jan 30, 2008
Hitachi 61UWX10B 61 in. Rear Projection Television, See double image, Magic focus doesn't fix
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 06, 2011 | Hitachi 61UWX10B 61" Rear Projection...
Image is showing with yellow & red shades
Ur convergence is dead.Must know how to solders?Replaced convergence ICS and all it resistors.Tries Tv repair World.com,Tvrepairkits.com to buy a convergence kit.Shop will cost u $300 for parts and labors.
Jan 16, 2010 | Hitachi 61UWX10B 61" Rear Projection...
61uwx10ba. no power to any boards but power supply.
have you reched around the new soldering area carefully, check for solder spills or drops in the printed circuit, also another thing to look for is some of those replacement stk do not hold their weight, you might want to take them out and try the old ones to see if you recover tv power.
Jan 15, 2010 | Hitachi 61UWX10B 61" Rear Projection...
Hitachi 61uwx10b needs more convergance work than magic focus can apply. Options for savvy DIY'er ?
Know basic soldering?That all require changing convergence ICS all it resistors.Tries Tv repair World.com,Tvrepairkits.com for the convergence kit.
Oct 02, 2009 | Hitachi 61UWX10B 61" Rear Projection...
Hitachi 61UDX10B
I would check for burnt resistors as the 150s are interchangeable with the 110s however in alot of hitachis I have seen resistors blow after upgradeing to the higher wattage ICs. I Usually switch out the convergence resistors whenever I go to a higher wattage IC just to be sure. If you need more help let me know.
May 18, 2008 | Hitachi 61UWX10B 61" Rear Projection...
Hitachi 61UWX10B 61 in | TV will not turn on after reset | any reset button inside the TV ?
My Hitachi was doing the same thing. The culprit is a bad or intermittent 5V relay on the power supply board.
Jan 30, 2008 | Hitachi 61UWX10B 61" Rear Projection...
Hitachi 61UDX10B
[BRAND SPECIFIC][TOSHIBA][QUICK FIXES]
Flashing LED
<< Back to Quick Fixes Page
Whenever the set senses an internal fault through its monitoring circuitry, it essentially shuts down the set. The flashing LED provides the indication that a fault has been detected. Removing power to the set resets the monitoring circuitry. When plugged back in, the circuitry again does a check of the system. If it finds that there truly is a problem, then the set is shut down and the LED will again flash.
Jan 22, 2008 | Hitachi 61UWX10B 61" Rear Projection...
Hitachi rear projection "61UWX10B
I was told may be problem with high voltage capacitor. not true. 1 your problem in power supply. 2 if it is ok it is due to horl.section.
Sep 14, 2007 | Hitachi 61UWX10B 61" Rear Projection...
No power to Hitachi 61UWX10BA Projection TV. Have tried steps found in other blogs.
These set are good for having convergence amps go out, and also audio problems. So if your set had experienced color alignment problems, or sound problems this may tell you what is going on. There are codes for Hitachi, and it's in the LED lights that lights up when you plug in and then hit power button. Some LED lights up and goes off some stay on this tells a tech what is wrong, I use to have code but gotten away from Hitachi, but if you could safely tell me which ones maybe I can help further. Like I said, this set has had many problems with convergence amps going out. There are small fuses on the big board that do not look like the ones in powersupply. They usually say F001 or somthing to that sort. They sometimes can be yellow in color, but the problem is replacing without fixing problem will have it going out again. So hope this helps. and Read the threads here on sets like yours becaus the answer might be here already.
Mar 12, 2007 | Hitachi 61UWX10B 61" Rear Projection...
Hitachi 61UWX10B 61" Rear Projection Television Logo
147 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
