Question about Bernina Artista 170
Bernina 170e Top thread catching around bobbin and knotting
My 170e will embroider fine and all of a sudden the top thread bunches around bobbin casing and knots up on fabric and in top plate needle hole. Nothing specific seems to cause it. Just randomly happens. Sure can put an end to a nice project. Also if the machine is fixable any ideas where I can find the older software? I have Artlink v3 and CPS v4 and have to run on windows 98. I wondered about Artista. I am limited on putting together designs and especially fonts.
  • Jawic Feb 06, 2008
    Still hoping for a solution of the thread binding and knotting. I have cleaned between the tension plates, I checked the tension, and threaded with needle in stop position. It seems like the tension gets tighter and tighter until it holds the needle from going farther. I can tell when it happens because of the sound. The bobbin sounds loose and noisy.
    OK I thought so, but hoped for an easier solution. Anyone else have anything to add? I would like to have some knowledge when I contact a service center.
    Thanks
    Jawic
  • 796 Answers
Just give it a try by lubricating the edges of the bobbin case ,,,due to friction the thread wont be able to come out from the bobbin with ease,,,,..
thank you
Posted on Feb 07, 2008
    Guru:
  • 1,894 Answers
When you have decided to go to a service person why do you strain yourself more?
    Genius:
  • 3,422 Answers
Try this out:
When you thread the machine...to ensure it is right in the top tension. Thread as far as the take-up lever and stop.
Set the presser foot down. Turn the top tension dial to zero, and then to 3 or 5. While turn the dial, pull the thread some to see if it tightens up as teh dial is increased in numbers.
After the thread comes out of the tension discs, it should then go through the check spring, then up to the take-lever.
The needle is correct, and thread from the inside out, meaning right to left.
If this works thhen please don't forget to rate me as fixya..
Posted on Feb 06, 2008
  • Priya darshan Feb 06, 2008
    When you remove your bobbin case, bobbin, and two extra pieces, the
    piece that is left in the machine has a spring around it. Check to see
    if the spring is broken as this causes noise in bobbin
    I also want u to check these below link may be u can find a solution:
    Click here
  • 871 Answers
Hi there
embroiding machines like this one nowadays have limited troubleshooting and issues that is fixed. however, the only way for you to really know the exact cause why you are having random errors with your machine is to bring it to a service center and have them diagnose this for you before they could make a probable solution to the problem.
Again, it does frustrates whenever you are in a middle of a project and suddenly the machine goes haywire.
Glad to read that you are taking good care of your machine. i quick way to determine though aswhat youve said, is the sound. you will know that theres an error with the sound it makes. Practically thinking boils down to a faulty cogwheel somewhere inside the machine.
So, my only suggestion is for you to have your embroidering machine serviced in a service center for the technician to actually have a look at your machine.
thanks for reading and hope this helps.
    Master:
    Sergeant:
  • 440 Answers
Http://se.bernina.com/download-n40-sD.html
hers the dl link ok butthey dont make it for win98 just vista and xp ok thx nick
Thread not catching to bobbin
Hai, How many heads in your embroidery machine? As far as you should have brother embroidery machine's maintain and handling is smooth and carefully. Please check the timings. Otherwise ask your machine mechanic.
Mar 19, 2014 | Brother Se400 Computerized Embroidery &...
Bernina 1008 thread bunching on bottom
"Nesting or Rat's Nesting" on the bottom side of Bernina sewing machines (CB hook type) is generally the result of very loose top tension. If the problem is found in newer sewing machines such as machines made after 1986 (serial numbers beginning with 26xx xxxx), may have an older Bernina bobbin case in the machine. The problem with the older bobbin cases is that the rounded projection of the latch on the left side of the casing will catch thread, preventing easy thread escapement during the take-up lever cycling resulting in loops on the bottom side and or thread breakage, etc..
Note:....Timings and modified latch geometry's were applied to later models to allow for good thread escapement. Older Bernina cases cannot be used on newer machines but newer cases can be used on all CB hook Bernina machines.
Additionally, Chinese copies of the Bernina/Cerliani OEM bobbin are rampant and can cause sewing issues. Always ask for OEM Bernina cases.
Note the following trouble shooting logic:
1. The center tension disk that is visible through the thread slot in the top cover of most machines must be positioned exactly in the middle of the top cover slot. By loosening the fixing screws on the top tension mechanism, one can adjust the disk position to center.
2. It would be a very rare situation for the top tension to change whatsoever from the (red center marking) factory setting. The most likely cause of loose top tension under the normal center mark position, would be accumulated lint, thread, or a sticky substance between the disks. This would prevent the tension compression disks from applying an even tension on the sewing yarn (thread). Often this can be blown out with compressed air when the presser foot lever is lifted in the up position. In some cases, soft drinks and other sticky or corrosive liquids can find their way between the disks. In this case, the tension assembly must be removed, disassembled, and the disks cleaned and polished.
3. Check the facial surfaces of the bobbin case for corrosion, and sticky substances that prevents the thread from easily sliding over the bobbin case.
4. Check that the spindle of the hook body is not bent or warped, causing the bobbin case to wobble, thus creating an intermittent pressure on the hook race cover at the moment that the thread is trying to escape over the bobbin case finger. (Replace the hook body)
5. Inspect the undercut on the hook body spindle for thread wrappings and knots. This condition can cause the bobbin case to press hard against the hook race cover, hence hindered thread escapement .
6. Exceedingly tight bottom tension can cause some problems as well. ( If you don't know how to adjust Bernina bobbin cases to factory settings, please ask).
7. Hook timing, (loop lift) can be out enough to affect thread escapement. This is typical of newer machines made after 1986 since Bernina no longer made fixed timed machines like the earlier Swiss made models. The later made models have timing components that can slip under stressed machine mechanics.
SewTechnical Home ">
Feb 13, 2014 | Bernina 1008
Embroidering in blue thread, and the white bobbin thread was coming through on the material. Adjusted the tension to -8, sprayed the bobbin casing and area lightly with WD40, changed the bobbin, changed...
The white bobbin thread was showing on the top of the material correct? Make sure bobbin thread is in the tension correctly, check the top thread spool and make sure thread is not caught around it, if you have a manual top tension make sure that is set correctly. Personally I would never use wd40 in a sewing machine, sewing machine specific oil is always better. You seem to be describing two different problems. The thread bunching is probably from the thread jump out of the take up lever.
Sep 12, 2013 | Brother Sewing Machines
I have a Bernina Deco 330, I am having issues with the Bobbin thread coming through on top of design. It is also tieing the knot in top of the fabric. The design will be flipped, the smooth side on back of...
A few things to check. Is the upper thread caught? You can test the upper tension, that could be pulling up the bobbin thread, by putting a size 80 needle in the machine. Put the presser foot down and pull on the upper thread it should bend the needle about an 1/8 inch when the tension is at 5. Also check the threading is done correctly and not catching on a thread guide.
Sep 02, 2013 | Sewing Machines
Needle thread knots up under fabric.
I have the same problem but i have not watched it. I does not seem that anyone wants to help us here, I am going to other sites until i find someone knowledgeable. apparently we are the smartest here at the moment ;)
Mar 31, 2013 | Sewing Machines
Burnette 65 bobbin tangling can't adjust thread tension
Have you replaced the needle with a new one? Your needle may be bent or in wrong, or the wrong size. You may have a bad needle. Check that the upper thread path is running freely and is not tangled or wrapped around anything. Make sure that the bobbin is unwinding in the correct direction as well, most bobbins, this is clockwise as the bobbin faces you. If you are using inexpensive thread, it could be the thread that is the culprit. Uneven thread in the needle will not flow through the needle properly, and cause bunching as well. Save it for the bobbin, and use good thread in the top.
Jul 16, 2009 | Bernina Bernette 75
Bernina Aurora 440 knotting below my fabric and into bobbin area.
Are you sure you have the bobbin the right way round in the holder....when you look at the bobbin and tug the thread, the bobbin should move clockwise.
Pull out the foot pedal and use bsr2 with the start/stop button.
Bring bobbin thread to top of work before starting to sew. This may help knotting problem
May 25, 2009 | Bernina Activa 140
Sewing Machines Logo
194 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Chris Wetmore
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
