Question about Motorola Mobility RAZR V3
Can't Remove Flip Head
I am trying to switch my screeb displays on my V3M. Problem is: There seems to be an unmovable bearing or axle that prevents me from removing it from the rest of the phone body. Any tips?
THANKS JIM!
Posted on Jan 30, 2008
  • 2,130 Answers
Typically the "axle" you are referring to is spring loaded. It's very much like the spring-loaded pin on a watch band.
You need to push one end of the "axle" in so that it gets shorter and you can then pull the axle out and remove the flip part. It can be a tricky thing! Be patient when you are dong this so you don't break anything else.
Becareful - the flex cable runs through there as well. If you don't have a replacement flex cable, you want to make sure you don't damage the one you have. Hopefully the new screen came with a new flex cable attached.
- Jim
How do I remove the rear axle shaft?
remove the bearing retainer plate from the end of the housing and use a slide hammer to pull the axle out
the bearing and seal adhere to the housing initially but once the is broken the axle will come out easily.
Aug 26, 2015 | 2006 Cadillac Escalade
Greasing the axle
The front wheels don't use axles, instead they use roller bearings similar to auto wheel bearings. Scooter front wheel bearings are usually sealed bearings or shielded. If the bearing is stiff or ruff and a sealed bearing you must replace it. Sometimes you can revive a shielded bearing by soaking in carburetor cleaner rotating soaking rotating soaking until the bearing runs smooth. Then you repack the bearing with grease. To repack a bearing you must place some heavy grease in the palm of your hand. Hold the bearing at a 45 degree angle to your palm. Catch some grease between your palm and the inside of the bearing race. Force the grease between the race and the shield until you see grease coming out the other side. Do this all the way around the bearing The rear wheel are normally mounted to the trans-axle. The manufacturer considers this to be a sealed unit however you can open it. Remove the Allen head screws and split the axle case by move the slender side down the shaft until its open enough to apply grease with a gun. PUT LOTS OF GREASE. When you close the case most of the grease is going to be squeezed right out again. To prevent this i installed a Zerk fitting. WARNING Do not install a Zerk yourself. What i'm trying to do is to pressurize the case with grease in order to get the grease to where its needed. Do not use the scooter inside until you find its not dripping grease. Hope this helps
Jun 02, 2012 | Pride Go Go Elite Traveller Plus HD 4...
How to remove the right side axel shaft on a 98 olds bravada
1. Raise and support vehicle, then remove tire and wheel assembly. 2. Install a brass drift or a screwdriver to prevent the rotor from turning, Fig. 7 . 3. Remove axle nut and washer. 4. Remove stabilizer shaft or link from control arm. 5. Remove nut from ball joint, then separate ball joint from steering knuckle using separator tool No. J-36226, or equivalent. 6. Remove drive axle from hub and bearing assembly using front hub spindle remover tool No. J-28733-A, or equivalent, Fig. 8 . 7. Remove drive axle from transaxle using axle shaft remover puller tool Nos. J-33008, J-29794 and slide hammer tool No. J-2619-01, or equivalents, if necessary, Fig. 9 . INSTALLATION 1. Install drive axle into the transaxle using seal protector J-37292-B, or equivalent 2. Seat snap ring by placing a screwdriver into the groove on the joint housing and tapping until seated, Fig. 9 . 3. Grasp the inner housing and pull outward. If the snap ring is properly seated, the axle will remain in place. 4. Install drive axle into hub and bearing assembly. 5. Install lower ball joint to steering knuckle and tighten to specifications. 6. Install stabilizer shaft or link to control arm, tighten to specifications. 7. Insert a screwdriver or drift into caliper and rotor to prevent rotor from turning, Fig. 7 . 8. Install new hub nut and washer, tighten to specification. 9. Install tire and wheel assembly, then lower vehicle
Feb 13, 2011 | 1998 Oldsmobile Bravada
Replacing a rear wheel bearing 1996 gmc sonoma 5 speed what all is involved does the axle have to come out or can you just take wheel and brakes drum off etc.
To remove the rear axle to replace a bearing you have to remove the rear differential cover and remove the small retaining bolt holds the spider gear shaft in place and then slide this shaft out far enough to remove the "C" shaped axle shaft retaining clip. Once this clip is off then the axle can be slid out and the bearing & seal replaced. Make sure that none of the spider gears or thrust washers behind them get out of place and you should use a new retaining bolt when reassembling the differential components as they come [or should come this way] with thread locker to prevent them from coming loose.
Jun 22, 2010 | 1996 GMC Sonoma
How to remove the rear driveshafts on a 93 subaru legacy?
driveshafts as in tailshafts? or axels from diff? if its just the tail shaft, it just has 4 12mm nuts and bolts, one spanner will get it out make sure you dont lose the spring washers and try support it when removing to prevent damage to the centre bearing.
May 09, 2010 | 1993 Subaru Loyale
How do you change rear bearing on 2000 safari?
The rear axle bearing? I'm going to presume that's the bearing you're talking about and not the rear main bearing, so please take that into consideration if you would
You're going to have to jack up the rear of the van, remove the tire and drum. Then you have to place a drain pan under the rear differential and remove the cover. After the cover is removed spin the rear axle (the one with the tire off) to locate the pin in the very center of the differential. On the right side you will see an 8mm (5/16) bolt head.
When you remove the locking bolt (the 8mm) and slide the pin out DO NOT SPIN THE AXLE WITHOUT THE CENTER PIN IN PLACE. Push in on the axle with the bearing to be replaced and a "C" clip will fall out of the differential. SLIDE THE CENTER PIN BACK IN and screw in the locking bolt a few turns. Once the "C" clip slips out, you can pull the axle out. If you don't have a bearing puller, it's best to rent one. Insert the bearing puller and pop the bearing out.
Apr 06, 2010 | 2000 GMC Safari
Cant get the front differential out
  1. Raise and support the front end on jackstands.
  2. Remove the right wheel.
  3. Position a drain pan under the axle.
  4. Remove the stabilizer bar.
  5. Remove the skid plate.
  6. Disconnect the right inner tie rod end at the relay rod.
  7. Remove the axle shaft flange bolts, turn the wheel to loosen the axle from the axle tube, push the axle towards the front of the truck and tie it out of the way.
  8. Unplug the indicator switch and actuator electrical connectors.
  9. Remove the drain plug and drain the fluid from the case.
  10. Remove the axle tube-to-frame mounting bolts.
  11. Remove the axle tube-to-carrier bolts.
  12. Remove the axle tube/shaft assembly. Keep the open end up.
  13. Position the axle tube, open end up, in a vise by clamping on the mounting flange.
  14. Remove the snapring, sleeve, connector and thrust washer from the shaft end.
  15. Tap out the axle shaft with a plastic mallet.
  16. Turn the tube, outer end up, and pry out the deflector and seal.
  17. Using a slide hammer and bearing remover adapter, remove the bearing.
  18. Clean all parts in a non-flammable solvent and inspect them for wear or damage. Clean off all old gasket material.
Jun 27, 2009 | 1999 Chevrolet S-10 Pickup
Rear bearing
rear axle bearings I assume? Pull the diff cover, rotate the carrier so you can remove the pin from the center of the 4 spyder gears, push the axle in slightly, and remove large c clip from the carrier area. The axle will pull right out! These vehicles are hard on axle bearings. Look them all over.
Good Luck!
Apr 02, 2009 | 1996 Jeep Grand Cherokee
2 issues.\1st is the truck has dual fuel tanks and
The only way the empty tank could leak is that the switch that controls the two tanks is pumping fuel into your empty tank. This is a common problem with the Ford trucks. In fact Ford had a recall on these to replace the switch for this very problem.
Problem 2: The F-250 you have probably has a full floating axle in it. Remove the wheel. Remove the brake drum. Remove the 8 bolts on the end of the axle stub. Remove the axle. Then you will need to remove the large axle lock nut and the lock ring under it. Then remove one more axle nut. Carefully remove the hub and dont let the outer bearing drop to the floor as it might damage it. Flip the hub over and remove the old wheel seal. Check the bearings. If o.k. put them back in the hub. Install the new wheel seal. Then reverse the disassembly procedure to place it all back together. When finished refill the differential. And be sure to clean the oil from the brake drum and replace the brake shoes if they are contaminated so badly that you can't get them clean again. No special tools needed. Just a good all around assortment to accomplish this task. If you need to purchase tools it would be a good investment anyway. Tools never go out of style. They have uses over and over and pretty much pay for themself.
Mar 03, 2009 | 1993 Ford F250
Getting rear gears out of the difential case 1999 dodge durango
  1. Raise and support vehicle. Ensure that the transmission is in neutral.
  2. Remove wheel and tire assembly.
  3. Remove brake drum. Refer toBrakes, for proper procedure.
  4. Clean all foreign material from housing cover area.
  5. Loosen housing cover bolts. Drain lubricant from the housing and axle shaft tubes. Remove housing cover.
  6. Rotate differential case so that pinion mate gear shaft lock screw is accessible. Remove lock screw and pinion mate gear shaft from differential case
  7. Push axle shaft inward and remove axle shaft C - clip lock from the axle shaft
  8. Remove axle shaft. Use care to prevent damage to axle shaft bearing and seal, which will remain in axle shaft tube.
  9. Inspect axle shaft seal for leakage or damage.
  10. Inspect roller bearing contact surface on axle shaft for signs of brinelling, galling and pitting. If any of these conditions exist, the axle shaft and/or bearing and seal must be replaced
Feb 07, 2009 | 1999 Dodge Durango
Motorola Mobility RAZR V3 Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
