Question about Dell 1600n All-In-One Laser Printer
Vertical line when using document feeder
I have a vertical line that is appearing when I fax or scan documents from the document feeder. When I print or receive a fax, there is no problem, so it is not toner or drum related (or at least I think so). I see some minor marks or scratches on the glass where the feeder sends the documents through, but none of those line up with where we're getting the line. Any suggestions?
Look really close at the small glass strip. There will be toner embedded in the glass. It will probably be a very thin streak though, so hard to see.
Posted on Feb 11, 2008
How do I fix this
Vertical Bands, Lines, or Streaks in Copies, Faxes, or Scans
Figure : Sample output with vertical colored bands or lines ... Remove any paper from the automatic document feeder (ADF) tray. ... To protect the scanner, do not spray the glass cleaner directly on the glass. .... determine if your printer is still under warranty, and then Contact HP Support to schedule a repair or replacement.
How to get rid of lines on a copied page - YouTube
? 2:10
Feb 17, 2010 - Uploaded by Wayne Springer
When you make copies on your copy machine, does it ever leave a black vertical line ... QLS ' How to Eliminate Vertical Linesfrom Scans, Copies & Faxes ... Part 2- Fix or repair color laser printer with fading, light print, or lines ...
Dec 29, 2015 | Office Equipment & Supplies
There is a vertical black line appearing when I scan or copy
To the left of the A4 scanner glass, there is a narrow glass strip. This is when the top document feeder scans from. Check for any contamination (even a small speck) on this glass at about the position of the vertical line.
Mar 29, 2015 | Brother MFC-9440CN Multifunction Printer
Vertical Black Line
Probably there is nothing wrong with that scanner, just open and clean document feder with alcohol or glass cleaner.
Mar 29, 2013 | Canon PIXMA MX870 Wireless Office...
I have a Epson cx11 and get a black vertical line down the middle of scans and copies
Check your flat bed and Document feeder scanning glass need to be clean, if any dot or dust in scanning glass of document feeder it will appear a line, check this points first
1- Check printouts from computer or FAX if it is clean problem in scanning section
2- Check using Copying a blank paper using only Flatbed if it prints without any line its problem from document feeder Scanning glass
So solution is clean the Document feeder scanning glass using wet cloth, note careful about wet cloth switch off the machine and clean it
Feb 04, 2013 | Epson AcuLaser CX11NF Printer
Black vertical lines when scanning on canon mx420
the ocr sensor in the ADF needs to be replaced, I would recommend replacing the whole ADF as a whole.
Aug 10, 2012 | Office Equipment & Supplies
Xerox WorkCentre 4150, 3 vertical white lines in all feeder scans
the problem is in the scanner, open it up and see if you can find any smudges, and clean any obstruction, any ink, liquid eraser residuals, can cause this part to appear as lines on your copied faxed image.
dont concentrate on the printer this is a scanner problem
Jul 28, 2009 | Xerox WorkCentre 4150/X Laser Printer
Vertical line from document feeder
there is probably a dirt spot on the scanner glass where the document feeds in. try cleaning the thin glass under the document feed cover.
Apr 24, 2009 | HP Officejet J5780 All-In-One Printer
Vertical lines
I just want to know that which did you try to use to scan. is that by using the ADF (automatic document feeder) or using the scanner glass?
Jun 18, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Print Problem - vertical lines
If the problem only occurs when using the document feeder, the problem is not usually caused by the drum. When using the document feeder, try to notice where the scanner (the light assembly under your scan glass)stops just before the paper is being fed. Some multifunction machines have a small piece of glass that is separate from the large scan glass and the scanner assembly stays parked underneith it as the original is being fed over it. Most likely there is something on the glass where the scanner parks as originals are being fed thru the feeder. When putting your original on the large scan glass to copy, the mark on the glass will only show as a spot, but will show as a vertical line thru the whole copy when using the feeder.
Feb 23, 2007 | Brother MFC-7820N Laser Printer
Scanner inserts vertical line on some documents
Clean the glass with IsoPropyl Alcohol. Dont use any other solvent. A speck of dust stuck to the glass can give a continuous line in the output
S. Mohan
Sep 29, 2006 | Canon DR-1210C Scanner
Dell 1600n All-In-One Laser Printer Logo
293 people viewed this question
Top Dell Office Equipment & Supplies Experts
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
