Question about Frigidaire GLTF2940ES Front Load Washer
Best parts to replace
Our 10 year old front loader has started to make a
roller whine" during spin cycles. So, I wanted to ask what a good assortment of replacement parts would be to purchase. Kind of a tune-up.
Belt, Shock absorbers and what else? I'd like to do as much as I can at one time to keep it running smoothly.
We also have the matching dryer, any suggestions for it as well?
  • 1 more comment
  • gallery guy Jan 30, 2008
    Well its started to get kind of grindy metaly sounding. It used to sound much smoother/quieter during high spin.
    I'm assuming there are rollers/bearings or a single axle bearing?
    I haven't been in it yet..
    its on a single rear bearing if i was going to replace it id throw in a belt clean the pump i wouldnt worry about the shocks you a mechnic
    So are you saying you'd replace the main bearing or not?
    Ok thanks so:
    Washer: Belt, Shocks, Clean the pump.
    Dryer, Belt, Rear Bearing kit, Door felt kit, Clean the motor and check the heater coil.
    Clean everything else...got it.
    Muchas Gracias.
    Any ideas why our softener doesn't drain? We've cleaned it well, all the holes are clear, We can hear the water going by....
    President:
  • 1,314 Answers
What kind of whine are you talking about in fast spin they should sound like a lear jet they are simple machines not much to worry about in my book one of the best on the market
Posted on Jan 30, 2008
  • 1 more comment
  • robert samples Jan 30, 2008
    yes but its a chore bearing has to be pressed into the tub you might be able to rig something with a couple of large sockets and a heavy bolt and two washers and nut if you get my meaning now as to the dryer replace the rear bearing they have a kit for that pretty easy the door felts they have a kit for that too clean the lint out of the motor and a new belt while the tub is out check the heater coil in the pan behind the drum
    ill do better than that send me an e mail at b4829@yahoo.com
Kenmore 970-C42062-00 washer drum squeaky and bangs
The bearing may be shot. A common problem with front loaders. At 10 years of age, the machine has replacement in its future.
Apr 27, 2017 | Kenmore Front Load Washer
Whirlpool WF665/1 clunking/grinding
Could be worn drum bearings.
Jun 04, 2010 | Washing Machines
We have a 10 year old Kenmore front loading washer makes a noise during the spin cycle. We have already replaced the shock absorbers. Do you have another suggestion? It knocks loudly off and on during the...
It appears your drum roller/guide has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 10, 2010 | Kenmore Elite 45986 Front Load Washer
GE Top Loader 10 years old. won't drain
Timer is faulty and should be replaced.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 10, 2009 | GE WBSR3140DW Top Load Washer
Vibration during spin cycle
Unless your front loader is set firmly on concrete and leveled to perfection, the force of a heavy wash load spinning in excess of 1000rpm will create a bit of vibration and noise.A firm footing is your best defense against to much movement.
Also due to the earlier movements during the spin cycle, the shocks that are used to dampen the spin cycle might have been broken or damaged.
If the problem persists inspite of proper levelling, please do check for the shocks or might have them replaced them for good.
Dec 13, 2008 | LG WM2688HWM TROMM SteamWasher
Whining during spin cycle
zato2
Could be a loose belt, or drum bearings,or ( drum rollers if your model is so equiped) In my mind machine would be worth repair when needed.
hope this is helpful
handiman518
Jan 17, 2008 | Maytag MAH6500 Neptune Front Loading...
Kenmore 44832200 banging during spin cycle
The support spring beside the spinning hausing are cut replace w/new spring available appliances store. bring sample.
Jan 07, 2008 | Kenmore 44832 Front Load Washer
Clanking noise during spin cycle
I was told by 3 technicians that my washer had shot bearings and this is a common problem for the Kenmore Elite Front loader.
Sears knows it and will not do anything about it except try to sell you a new washer since it costs $800 to replace the unit with the bearings.
Jan 02, 2008 | Kenmore Elite 45986 Front Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
46 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
