Cant seem to get my new beko 5100 washing machine to work. Anybody out there with any solutions? It just wont go on even though i have connected all the neccessary pipes
unplug from wall check contacts at motor and pcb/ timer plug back in see if that works motor pulls a lot of juice look for a burnt contacts or connections. motor may be thermally fused .dont just bypass find the reason why thermal fuse failed
Try further spin/drain cycle then try door again. If no go, sounds like door lock switch may have jammed. Have to have lid off and see if you can unlatch the door manually.
Hi sam this might help if your beko wma10w washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Also check all waste pipes are clear and inspect the pump I have included this video below.
At our website I am doing self diagnostic videos on these beko's as we speak so all tutorials will be in this link below How to replace Beko Washing Machine Motor Carbon Brushes
you might find this test video helpful but only do it if you have checked the motor
Hi if your beko w765s washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
