Question about Kenmore 98702 Stacked Washer/Dryer
Slow rinse cycle fill
Model 417 has an extremely slow fill for the rinse cycle. It fills just fine for the wash cycle. ???
It also will not dispense the softner.
I had it apart to see if I could find a kinked hose or loose wire to a solenoid and after I put back together it worked fine for one cycle. Now its back to filling slow even after I took it apart agin to recheck everything.
Any suggestions?
  • fis2000 Jan 30, 2008
    Water pressure is fine. It makes a mess very quickly. lol
    I forgot to note that this symptom is also uneffected by water temp selection.
    Yes I did. Its fine.
    President:
  • 1,314 Answers
Take the hose off the cold water valve and check the screen on the water valve ,make sure the cold water is on all the way and the hoses are on the right valves get a water bucket hold the cold water line in it open the cold water valve to check the pressure
Posted on Jan 30, 2008
  • robert samples Jan 30, 2008
    did you check the screen on the water valve
    well washers wash on hot warm or cold but always rinse on cold only if you have a cold wash/ cold rinse setting try that and let me know how it fills on wash see where were going here
Kenmore 70 series washer
If you can see a constant water pressure from the hot and cold, chances are the water solenoid valves are ok.
I would look towards resetting to factory and checking the main control unit.
May 11, 2014 | Washing Machines
417-44052400 Fills with water, washes, drains/spins then comes to a stop. If I did the diagnostics right it indicates E11? Anybody else have this problem?
e11 is a water problem filling to slow,you could have a problem with your cold water fill line,clogged sediment in the valve or something like that,when it goes into rinse the machine uses cold water so the clothes won't wrinkle and it sounds like it's filling to slow.
Nov 26, 2011 | Washing Machines
Fabric softner compartment won't dispense during wash cycle
Fabric softener is to slow mix with rinse water in the rinse cycle... check the cold water supply line for a clogged screen or a clogged dispenser box cover... hope it helps
Sep 20, 2009 | Frigidaire ATF6000ES Front Load Washer
Kenmore 90 plus won't fill on regular orpermanent press cycle.
OK, Duh..... I guess there is about a 2 to 3 min. delay for the liquid soap dispenser to fill up and disperse the soap into the washer tub. After that short cycle is complete the fill cycle engages and fills at normal speed.
Mar 24, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Cold water is slow when filling for rinse cycle
Turn off the cold water.
Remove the cold water hose from the machine.
Look inside the cold water inlet on the machine and clean the debris from the screen.
Problem solved.
Feb 22, 2009 | GE WJRR4170E Top Load Washer
Washer fills slow only in the rinse cycle
Need a model # to get exact part you will need at rinse most washer go straight cold so I would say water inlet valve if humming sound is present
Apr 28, 2017 | GE WBSR3140DW Top Load Washer
Washer won't fill in rinse cycle
REPLACE YOUR WATER INLET VALVE(HOT,COLD WHERE HOSES ARE)IT'S NOT OPENING ALL THE WAY TO LET THE WATER FILL UP FAST,LET ME KNOW HOW YOU DO-MIKE
Oct 19, 2008 | Maytag Washing Machines
ck and clean screens first both sides be sure hoses are not reversed timer has no affect on fill rate if screens are clean replace valve
Sep 19, 2008 | Kenmore 24032\24036 Top Load Washer
Slow Filling only in rinse cycle
Tony, the fact that you are not receiving any error codes tends to leave me to believe that your cold fill hose filter may be restricted. Going by your model number you can enter this mode by having the power on at the source and off at the console. Press and hold the lifecyle button and then push power button. You should hear 2 beeps and then the display go blank. You can test the hot and cold valves by pressing how dirty up (hot) and how dirty down (cold). If you find the cold valve slow as in your rinse check for restrictions. If it were the thermistor, I would think you would receive an error code..Good luck.
Jun 06, 2006 | Fisher and Paykel IWL12 Top Load Washer
Kenmore 98702 Stacked Washer/Dryer Logo
325 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
