In bios make sure the raid chipset is active. Ususally there's 2 one needs drivers one doesn't. I use the one that doesn't then in bios there should be a way to set up your array. Raid 0 is striping mode so you should only see one hard drive,the d drive should be the cd/dvd device. If this is right then you did it right.If it were raid 1 then you would see both hard drives,because one is mirroring the main drive for backup.
