Question about Brother IntelliFax-2820 Laser Fax
Fax machine phone connections
I'm new to this forum, hopefully you can help or direct me. As a tech trainer I often disseminate information to our techs. We have been installing digital phone to business and residential customers for quite some time. Occasionally we encounter problems with older fax machines that are sensitive to the polarity of the phone connection, the red and green wires(tip & ring) connected backwards. But a new issue is circulating about using a 4 wire silver satin phone cord to connect to the fax machine rather than the two wire cord (usually provided). If a 4 wire connector is used, are the outside wires (yellow & black) acting as antennas causing the fax machine to become confused? Or is there another explanation why a 4 wire connector on some fax machines would cause malfunction? Thank you very much,.
  • Bill G
    Bill G Jan 30, 2008
    Thanks for the quick response. This situation does not apply to a specific occurance - trying to "nip it in the bud" as other explanations pop up. In any case other than an installation error the outside pair of wires should not be grounded. eMTAs allegedly ( I haven't measured it yet) put out -48 vdc on both telephone lines although only one may be active. The two lines are supplied from a primary port on 4 wires, red, green, black, yellow. (I could see a problem if there is unexpected voltage on the second pair of wires) However, if the eMTA goes directly to a network interface device for distribution and does not connect the outside pair (for non-active line2) and a 4 wire cord is connected to the fax machine - is this a known potential problem to introduce spurious interference that would disable the fax machine?
  • Bill G
    Bill G Jan 30, 2008
    Thanks for the basic phone install procedures.
    If you run across anything about how a 4 wire silver satin cord with the secondary pair improperly or not connected to anything and affecting the fax operation, I would be interested.
    An user who is expert in 3 categories / brands.
  • Brother Master
  • 1,362 Answers
I beleive it's because they are grounding out on the fax, which then resets some of the functions.
Did you measure if there are any activity on those two lines?
V or Hz?
Posted on Jan 30, 2008
  • CheckitRight
    CheckitRight Jan 30, 2008
    The best procedure is to test each outlet before disconnecting the incumbent phone service provider. Go to each outlet, unplug any phone or wire, and use a butt set or a phone you know is working to check for dialtone and the ability to dial out. Document your findings on a room-by-room basis, indicating pass or type of failure mode.
    Once your service is installed and you’ve checked for dialtone at the embedded multimedia terminal adapter (EMTA) before it is connected to the customer’s wiring, you can verify service at each outlet. Begin by disconnecting all phones from outlets to isolate any potential problem in customer premises equipment (CPE - phones, fax machines, etc.) that might feed back into the customer’s wiring. This is particularly pertinent if noise on the line is a problem for the installation site.
    At each outlet, check for availability of dialtone, the ability to dial a number, and the clarity of a telephone connection. Once again, your best test tool for doing this is the butt set, but a known working phone will do most of the job in a pinch.
    On outlets where dialtone is present, verify that dial tone can be removed (broken) as soon as a number is dialed. This is a special testing scenario where just dialing on your butt set or a working phone will not reveal a problem. Failure to break dialtone is caused by the wire pair being reversed at a connection point. Newer phones and test sets automatically detect and compensate for this condition, but it may cause problems later with older or low cost phones and other equipment, such as fax machines.
Change incoming fax number
Unless I'm misunderstanding your question, your fax machine has nothing to do with the incoming fax number. That's assigned by your phone service provider to the telephone line the fax machine is connected to. The only way to change that number would be connect the machine to a different phone line. This might be as simple as just plugging the phone cord into another jack if that line already appears at a convenient location, or it might mean a visit from a technician to place a jack where it's needed. Or you can contact your phone service provider about assigning a new number.
I hope this has helped. If not, please post a comment with more information about your question and I'll try to help further.
Oct 11, 2010 | Canon FAX-L800 Plain Paper Laser
No dial tone on phone connected to ext port on epson dx9400f
Buy a double adapter so both cords go to the LINE port. Set your answering machine to 6 or 7 rings so the fax picks up first. Your fax machine will know the difference between voice and fax calls,
Jun 22, 2010 | Pitney Bowes 9920 Plain Paper Fax
HP 3380 All-in-one. wont send faxes. dials, says connecting, and even sometimes starts to send page, but comes up comm error. I have vonage phone service.
Vonage claims to work with all fax machines. However, some customers report having had trouble sending and/or receiving faxes with Vonage and other voice-over IP (VoIP) providers. The difficulties are a frequent topic in help forums and even made the Wikipedia entry for Vonage. Frustratingly, the problems have been intermittent and hard to diagnose, and some customers have resorted to buying a new fax machine that better-suits Vonage’s optimum specifications. The company’s official “help” resource suggests lowering the baud rate on the fax machine to 9600 (or “slow”) as well as disabling the machine’s ECM (error correction mode) feature, if applicable. Also, make sure the fax machine is on the “standard” setting. Some users have had good luck adding *99 before dialing, as that resets the bandwidth for that call.
Vonage also allows its customers to send faxes over the Internet, without a fax machine, by uploading documents to the Vonage web site. There is no additional charge for this service if you’re on the company’s “Unlimited Plan.” Per-minute customers will see fax use applied toward their monthly minutes allowance. Hope this helps.
Apr 20, 2010 | HP LaserJet 3380 All-In-One Printer
I have Linksys modem no AM300.I try and send a fax and it will not go through Error report "NO Answer" BUT I know fax machine on other end is ok.Internet is ok.Can you help John
Even though you have internet, have you connected a phone line? Most fax machines/software rely on the phone line. I don't know how you are sending a fax. If you are sending a fax directly from an all-in-one, you'll need to connect the phone line to the back of that device. If you're sending a fax using a program on the computer, you'll need to connect the phone to the back of the computer.
You can temporarily disconnect your land-line phone and connect it to the all-in-one or computer. Just remember to reconnect it when you are done so you can receive phone calls.
I hope this helps!
Sep 07, 2009 | Linksys Computers & Internet
HP Officejet 6310 will no longer receive a fax, but can send one
Have you checked the online support guides to make sure your fax is connected properly. There is a lot to work through, but you should be able to test your setup and see if you can send faxes but not receive them. See links here, here, and here. Treat the credit card machine as if it were a telephone answering device or another phone on the line.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jun 16, 2009 | HP Officejet 6310 All-In-One InkJet...
My Dell Photo 964 All-In-One won't receive faxes, but can send them just fine. All other features are alright. Spoke to Vonage (our phone service) for 2 hours troubleshooting and sending test faxes, and it...
First check a couple of obvious things:
Sometimes the presence or absence of a (DSL) filter on the line can affect fax reception.
Also check to make sure you have not enabled Fax Blocking.
Otherwise, I can only offer some information HP provides for support of VoIP fax setups, available by clicking here., and hardware setup options available here. Whether it is even remotely useful in your situation you'll have to judge.
You know there is also a Dell Forum where users
can pose questions and exchange answers. Have you checked to see if there are solutions posted there? Dell Forum 964fax error
I'm afraid I am not familiar with that particular machine or Vonage...sorry I couldn't offer anything more...
If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Apr 08, 2009 | Dell Photo 964 All-In-One InkJet Printer
Want to connect fax machine to pc
The KX-FM131BX, KX-FM131CX and KX-FM131AL do not connect directly to a computer. They only have RJ-11 connections (to the phone line (line in) for all models and to another phone or answering machine (in some cases).
To send and receive faxes with a computer, you need some sort of USB or network port on the machine. Brother has some that may fit your needs: is one of their lower end models.
I hope this helps.
Dec 06, 2017 | Panasonic KX-FM131 Fax
Canon MP830 - Outgoing fax dialing not connecting
Are you plugged into the LINE port of the fax machine?
Oct 21, 2008 | Canon FAX-B820 Plain Paper Bubblejet
Fuji Invertor FRN18
Based on your post, the local distributor of the AJAX CNC Lathe can not repair nor replace, then perhaps you should try to go direct to the systems manufacturer.
  • Fuji Electric Co., Ltd.
  • ED & C and Drive Systems Group
  • 12-1 Yurakucho 1-chome, Chiyoda-ku Tokyo, 100-8410 Japan
  • ED & C Phone 3-3211-1424 Fax 3-3211-7983
  • Drive Systems Phone 3-3211-1425 Fax 3-3211-7982
  • Fuji USA;
Alternately, you could try a local Industrial Electronics Tech. who is familiar with these and has access to a service manual or at least a schematic diagram.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 01, 2008 | Drills
Have vonage fax and phone service
I am new in the network field.How can i set up a LAN net work using 5 hosts.What are the devices that I need to set up this net work?This is my email address.You can send it thanks
Apr 02, 2008 | NetGear RangeMax NEXT WNR834B Wireless...
Brother IntelliFax-2820 Laser Fax Logo
686 people viewed this question
James Cagle
James Cagle
Jim Keysor
