Question about NexxTech ESDVD100 System
System doesn't read any disk
My nextech esdvd100 stopped recognize dvd/cd: message-no disk. I did use laser lances cleaner, doesn't work. It doesn't recognize any disk. It looks like speed of disk is slow.
  • Anonymous Sep 16, 2008
    i cant play anything either. it makes a clicking sound, tries to load and then says no disc.
Mine started doing this just the other day and stopped playing the DVD it was playing. I found a solution for a portable player that worked on this one. You need to open it, eject the tray and slide the laser carriage back and forth all the way two or three times gently and by grabbing on to plastic that hooks around the metal bar on the right if you are facing the player from the front. Then plug it in and play a CD all the way through and this recalibrates the laser.
I wonder how many people throw away their DVD players when this is all it needs. Makes me sick to think about it.
Posted on Jun 21, 2009
  • alsdkjfalkjf Aug 24, 2009
    I should add that the solution I posted above does not work alone. My esdvd100 did the clicking and no disc thing again and this time I had to take a q-tip with just a tiny bit of rubbing alcohol on it and very gently clean the laser lens first. It's better to not dry it with the dry side of the q-tip because you may scratch it and the alcohol dries quickly anyway. I did this after I noticed a fine layer of grainy dust on top of the metal housing of the laser lens/apparatus. I also did this many times before moving the laser carriage back and forth last time but did not mention that because it did not fix it alone the last time.
    It seems that both actions have to be performed. It may also affect playback if your player is on a slant or the cover is off of the player. I am not sure but expereinced issues with these two conditions. It wasn't until the player was level and the cover in place (but not screwed in) that things went completely back to normal.
  • alsdkjfalkjf Sep 26, 2009
    I would edit my solution above but I don't see a button for editing.
    The latest solution that I arrived at is to thoroughly saturate the q-tip with alcohol and press the excess out on the inner side of the bottle, clean the lense gently, then dry with the dry side of the q-tip. I am not sure if moving the carriage in and out is necessary. However, mine starts acting up again within a few weeks.
    I am going to look into making sure that the disk is spinning level and make adjustments if it isn't. I just fixed a three disc stereo system that had fallen out of whack. The disc was spinning on a tilt, rubbing against the tray. I had to raise the back end of the lower clamping part that housed the spindle and laser until it was level then it was alright.
    Other possible issues are the motor needing oiled or the ribbon cable becoming disfunctional (not attached or burned up).
2 Suggested Answers
SOURCE: nextech esdvd100 stoped recognise dvd/cd
I found the problem with this....the motor which drives the disk fails...I am looking to see if I can locate parts for the system now
Posted on Nov 20, 2008
My dvd drive doesn't work
If it happens for only one particular disk:
Bring that disk to a game store like Gamestop or Rock30 Games and have them professionally clean the disk for a couple bucks.
If it happens for all disks:
Clean the cd/dvd with a laser lens cleaning kit. If that doesn't fix it then the cd/dvd drive will need to be replaced.
Jul 31, 2012 | Acer Aspire 5738Z Drivers Recovery Restore...
My DVD ROM is not reading and it's not even recognized in my computer. I tried uninstalling the driver in device manager (showing usual incomplete driver sign) to see if the system will automatically...
Just click on the link http://support.microsoft.com/mats/cd_dvd_drive_problems/en-us
and also click on NOW RUN from right side box. It will automatically give youthe message, well or bad.
If the problem with the lens, you should try cleaningthe lens,with disk cleaner, it's already gone bad and there is no harm to take a risk to open ordisassemble the dvd/cd rw,click on the bellow link http://www.youtube.com/watch?v=WaiTJYHQCCg
  1. When running your pc, open the drawer.>
  2. clean the optical lance
  3. http://www.howtodothings.com/computers/a3631-how-to-clean-a-cd-rom-drive.html
  1. now you can fit to your pc
If it does the same problemplease change the cd/dvd rw because the lance has defected. If you need more information, reply me soon.
Thanks
May 17, 2011 | Acer Extensa 5620 Notebook PC
My RCA RTD317 has problems recognizing most DVD movie disks. It will play some disks most of the time and all audio disks, so I figure the lasers are working. What could be the problem?
If you've tried cleaning the Laser with a Lens Cleaner Disk or directly with Lens Cleaner Fluid and a QTip without any improvement then the Laser is Failing.
It takes less power to read some DVDs than others and a lot less power to read an Audio CD. The Laser will continue to deteriorate until it won't play anything.
May 08, 2011 | RCA RTD317 Theater System
Nexxtech ESDVD100 DVD player gone bad, how to replace?
You can try cleaning it with a dvd disk cleaner first. If that dont work by a cheap dvd player and run it to the inputs on the back of the surround player.
May 24, 2010 | NexxTech ESDVD100 System
"No Disk" message
Your dvd lense need cleaning .
For that buy lense cleaner disk from nearest computer shop then put that disk into cd/dvd rom then play it then it clean dust from lense then you can use it again .
But if still same issue then you need to replace your dvd lense .
Let me know if you need further assistance.
Thanks for using FixYa.
Feb 24, 2010 | Sony Bravia DAV-HDX265 Theater System
My DVD burner stopped working...but will still copy cd
Please try to clean your DVD Disk Drive using a CD or DVD Disk Cleaner to clean the laser lens of the DVD Disk Drive like dust, dirt and other small particles that causes the lens hard to read or eventually not read the laser lens. IF you don't have a Disk cleaner you can find it in any computer shop or video shop in your place.
Thanks
Aug 13, 2009 | Toshiba Satellite A135 Notebook
DVD writer not reading disks
change ide cable 1st ok get back with me thx nick
Feb 03, 2008 | Computers & Internet
Nextech esdvd100 stoped recognise dvd/cd
I have the same problem with my esdvd100 were it stop recoginze my dvd or cd. msg: No Disk
Jan 04, 2008 | NexxTech ESDVD100 System
My dual layer DVD burner wont read any media
When was the last time you cleaned the dust out of the laser head? Or your PC, for that matter? Just asking.
There are cleaner disks that work sometimes, or you can go in with a cleaner foam swab with a little alcohol on it. Worth a try.
Apr 08, 2017 | LaCie (300978) DVD RW Dual Layer Burner
Disc Read Error
This is the problem with your dvd player's lance so you need to repair it from your Toshiba DVD/VCR Home Theater System provider. and after replacing it u have to take care of it. do not use crashed disks . Use lance cleaner liquid to clean lance .
Aug 10, 2007 | Toshiba SD-V57HT System
NexxTech ESDVD100 System Logo
222 people viewed this question
Top NexxTech Audio Players & Recorders Experts
Mohamed Ismail
Mohamed Ismail
Pieter Vleeshouwers
Pieter Vleeshouwers
Willem.
Willem.
Are you a NexxTech Audio Player and Recorder Expert? Answer questions, earn points and help others
