Question about Canon PowerShot A430 Digital Camera
Viewfinder/lens problems hey there, i have a canon powershot a430, and am having a ton of battery problems as well as this strange problem with the viewfinder + lens. i'm going to try out the suggestions i've found here to see about the battery issues, but i havent found anyone yet with a similar viewfinder/lens problem. this is what happens: when i try taking pictures from the viewfinder (having turned the screen off to save on batteries), the picture that ends up being taken isn't what i was seeing in the viewfinder. it's shifted an inch or two up and over. so, when i'm taking a pic of a piece of jewelry, and it's nicely centered in my viewfinder, the actual picture turns out with only the bottom corner of the pendant and a whole lot of white space. as far as i know, the camera hasn't been dropped, but it has been lent to my sister on a few occasions and was working before, but now isn't. is there a fix for this? i could always work around this by using the LCD screen to preview shots before i take them, but i much prefer to preserve batteries and save myself a few bucks. any suggestions would be much appreciated. thanks!
  • 1 more comment
  • cmallam Jan 31, 2008
    Thanks t00nz - I'll give that a shot tonight. Do you think, though, that battery problems would just start up out of nowhere when previously I was at least able to take some pictures ... and then all of a sudden, I'm not even able to take one? That's the part that's worrying me, that maybe somehow something is malfunctioning in some way.
    I'll try out the NiMH batteries tonight and see if they help, and thanks for the input about the viewfinder/LCD issue - someone else had suggested maybe that was the problem which, in hindsight, makes total sense.
  • cmallam Feb 04, 2008
    t00nz, thank you so much - i've picked up a set of 2500 mah NiMH rechargeables over the weekend, gave 'em a good charge before trying them out and everything seems to be working great.
    thanks again!
  • lisn Feb 20, 2008
    cant open lens. comes up with lens error, restart camera, but the same thing happens every time i restart it.
    lis
When picture is taken, there are black lines in the display and also appear in the picture. Can anyone help with this?
Posted on Mar 01, 2008
  • Canon Master
  • 4,738 Answers
Alkaline batteries just don't have the power for more than a few pics in a digital camera. Digital cameras for the most part should only be used with rechargeable NiMH batteries. Walmart sells these for around $7 for a package of four (about $15-19 for the batteries with charger). Keep in mind they'll save you big bucks in the long run over alkalines, AND they'll last for at least 100 pictures per charge (and probably many many more). You'll be very pleased with their performance. Really, you'll slap yourself for not buying them sooner. When at the store, look on the package for a power rating of at least 2500 mah.
And yes, your camera's optical viewfinder is off by a couple inches from what's show in the LCD. Take a look at the front of your camera. This offest is equal to the distance between the other end of the optical viewfinder, and your camera's lens. This should only be a problem for close up pictures. Recommend leaving your LCD on and using that to center your pictures. If using rechargeables, it shouldn't be a problem.
Posted on Jan 31, 2008
  • CameraR
    CameraR Jan 31, 2008
    Performance of alkaline batteries will vary greatly in a high drain device such as a digital camera based on quality of the battery, manufacturer, and shelf life of the battery.
    Remember, NiMH rechargeables (NOT NiCad) rated at least 2500 mah.
Turn camera on error message keeps popping up lens error, restart camera. Have restarted but still keeps coming up. Can you help please Thanks David
Some problem with the lens.
Look at the lens as it comes out, and listen as well. If it does not come out at all, then internal problems exist.
If there are noises, problems are inside.
If the lens comes out but is not at a straight angle, you may be able to fix it by carefully pulling on it as it extends.
If nothing else, sell it on Ebay as a repair camera.
List it like this:
Canon PowerShot A430 Digital Camera as is repair
Jul 10, 2011 | Canon PowerShot A430 Digital Camera
Canon Powershop A430 Digital Camera wont work with new batteries. I tried switching and used both alkaline and some regular ones but it keeps saying the batteries are low. How can I fix this?
If the camera has a lens that extends when you power-on, it may have failed to park completely when power went off, due to the weak battery.
Gently press on the front of the lens barrel to attempt to seat the lens.
Then (with a good battery) turn-on the camera.
If you are currently using the NiMH AA rechargeable batteries, I would suggest you try standard Alkaline AA batteries. They have a bit more voltage than the NiMH and it might make a difference in this case.
If that does not work, you should phone Canon Service and see if they have any suggestions.
I am sure they have encountered this problem before.
Hope this helps,
Feb 18, 2011 | Canon PowerShot A430 Digital Camera
I have a canon powershot a430. When I am taking pictures in daylight all pictures are heavly over exposed, Si I cant take pictures but the lest is ok because I can take his res video of 640x480 without...
I do not know the solution Yet, I have the same problem on a canon A430 and a canon A460 ,after 1.5 Years of use,very strange they are like time-bombs
I ordered the flex cable of the shutter unit,but it is not arrived,
I will let you know the results
Dec 30, 2010 | Canon PowerShot A430 Digital Camera
Image too bright plus the white lines
Hi!
I had a similar problem with my powershot A430 recently. I took it to a canon service center and they identified the problem as "shutter unit problem". My cam was under warranty so they fixed it for free and also replaced my lens (even though i didnt ask for it!). :-)
Take your cam to canon; they will fix it. All the best!
-Aashish.
Aug 04, 2008 | Canon PowerShot A430 Digital Camera
Lens error
The lens on my canon camera power shot A430 wont open and when I try to start it is says lens error restart the camera
E18 on Canon Powershot A95
Canon E18 error happens when the lens gets stuck while trying to extend. The camera will beep a few times and the LCD will display a little E18 in the lower-left corner. The lens gets stuck in the extended position, and refuses to move either to focus the lens or to retract when powered off.
take a look at e18error.com website for more info
Jul 30, 2008 | Canon PowerShot A95 Digital Camera
How to restart A430 Cannon dig cam
Can you please explain how to restart lens error for camera A430?
Nov 05, 2007 | Canon PowerShot A430 Digital Camera
Canon PowerShot A430 Digital Camera Logo
81 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
