Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Every several hours the screen goes all blue, and the set turns off.
When the screen goes blue, none of the controls work. After a minute the set turns off with rapidly blinking green light. When turned back on everything works properly for another hour or more. This happens 1 or 2 times every evening. All connections have been checked. The set has been reset..no help
  • ebehlke1 Feb 02, 2008
    The fans are working, they have been vacuumed and cleaned...no change, I get about 2-3 hours use before it shuts down. Have ordered new bulb as I have had set for 2 and 1/2 years...but signal is solid green. Lamp likely overdue. Is it likely this is an external problem? Thanks
    Genius:
  • 1,067 Answers
Overheating in back get fans and clean it out dust before it gets worrse
Posted on Jan 30, 2008
  • nick helpap
    nick helpap Feb 02, 2008
    ya could be light engine it self balest ect cusing the issue
My dreamgear chargepack works but when I but my sliver remote control in it lights up which means that its charging but when I try to charge my blue control the lights wont turn on. how do I make the light...
I have several controlers in several different colors, but "coincidently" several of the blue colored controls have had the LED lights stop working completely. I am begining to think that many blue colored Sixaxis PS3 controlers were made during a version that had problems with the LED lights going out and no longer working, or simply a bad batch of controlers.
Did you try letting it charge for a while, even if the ligfhts won't light up, then press and hold the PS3 button to check and see if it took the charge?
On my blue controlers, they still charge and still work, but none of the LED lights illuminate anymore.
Solution would be to buy a new controler, or ignore the lights not working.
Sep 20, 2013 | Video Game Consoles & Games
Mitsubibishi wd series 73"..Mitsubishi ws series 73" dlp. Works fine but after several hours of viewing screen scrambles then goes blue and sound goes off. I can switch to another input and watch ama
A couple of suggestions, if only on cable and using a box disconnect the set and box from power and after several minutes repower and see if a reboot helps.
The two models listed here both should also have a soft reset done with the original remote and the set on---Menu,1,2,3, enter.
Dec 20, 2012 | Mitsubishi WD-52525 52" Rear Projection...
After the tv is turned on it turns off 3 or 4 times after turning it back on and the screen turns blue for a few minutes before becoming clear. It lasts longer each day.
Many of these sets had problems with bad picture Tubes--they use a red, green and blue crt. Most commonly the blue gives troubles--The tubes are now only available on a rebuild basis--usually not worth doing as the cost is very high.
You may have a bad blue picture tube but there is a way to deal with this first----the set has a black plastic block with six controls---three are Focus(red,green,blue) the other 3 controls are Screen controls(red, green, blue)
Someone has to remove the entire piece on the front of the set below the screen(usually a plastic part) most of the time it is secured with 3 screws on either side of the set in the back; once you remove the screws the entire piece should pull out(pull from right to left(it will not fall off or come out easy--it is held in with several large plastic pegs) With it removed there is an inspection plate with 4 screws-----the screen/focus block is behind it.
You need to look very closely at the block to identify the focus versus screen controls----one row left to right will be marked Focus and the other row left to right will be marked screen------YOU need to locate the Blue Screen control (they are black like the block) With the set on(be careful) go to a video input clip_image001.gif with nothing connected---if you see a blue screen as well as the input number turn the BLUE SCREEN CONTROL SLOWLY TO THE LEFT UNTIL THE BLUE is gone.
If this cures the problem you may only be buying yourself some time----if the blue picture tube is bad sooner or later this trouble may return----I have seen sets where this was adjusted and the set worked for a year or more with no repeat of the trouble----replacing the blue tube would likely cost you 400 -500 parts and labor.
I do this here for free so if this has helped you rate this solution.
SD TECH
Dec 11, 2009 | Sony KP-65WV600 65" Rear Projection...
Tv just turns off while watching it the screen goes blue than turns off
This is one of a group of sets (KP-57ws500) that had bad picture tubes---all of them had this trouble.
The picture tubes are no longer available from Sony--only available on a rebuild basis from another company--very expensive and usually not worth doing---blue is most common tube to show trouble.
The set is shutting down because if the screen goes bright blue---it pulls too much current and the set goes into protective shutdown.
There is one fairly easy thing that you may be able to do-----I have done it before.
What it entails is getting at the Screen/ Focus control block and turning the Blue Screen control down--if it works it may just buy you some time but I have seen several sets where it allowed the set to have some more life.
Usually if the set was working the way this problem begins is you on a blank video input notice a slight blue color in the background with some faint curved lines visable.
If you want to attempt to do the adjustment--let me know and I will tell you how.
I am here to help people----I have seen over 100 of these Sony sets with this problem---replaced tubes in many of them when they were new or under warranty.
SD TECH
Oct 26, 2009 | Sony KP-57WS500 57" Rear Projection...
Full Color fading to blue then screen turns off. Repairable?
Here is what you need to do.
1.) You need to remove the entire plastic piece below the front of the screen. You most likely will find 3 screws on either side in back that you have to remove.
2.) The grill will not come out easy, pull from one side and then when it starts to come loose from the other side(there are several plastic pegs that hold it in.) Then from the bottom pull out( most of these sets have square plastic tabs at the top that tuck in.)
3.) With the grill removed locate the inspection plate behind it (it usually has 6 screws.) You will have to tilt the grill to the left and on its side as several cables are connected to it--they are held in place with trash bag like ties that you can release to get some room.
4.) With the inspection plate removed you will see a fairly small (about 3 inch square) BLACK PLASTIC BLOCK WITH SIX CONTROLS-usually they are marked with whiteout so someone can tell if they have been adjusted.
5.) You need to look very close at the block with a flashlight----usually the top three controls are FOCUS--don't touch those.
The lower three are usually marked Screen and if you look very close you will see b, g, r(blue green red)
6.)Usually the blue will be on the bottom left--it does vary
7.) Once you locate the BLUE screen control have the set on and turn it down--if the set is shutting down you may have only a few seconds to try to turn it down---usually to the left with the Blue Screen control.
8.) Best way to do this if the set is on is on a video input with nothing connected--you turn the blue down until the set stays on and then very slowly turn it up until you see a slightly blue screen with or without diagonal trace lines----if you get it to turn on this way turn the blue screen back down slowly until the blue screen and trace lines just disappear.
Let me know if you get it to work--Like I said if it is shutting down you may have to slowly turn the blue screen down a few times to get it to stay on.
I do this here for free and if this helps you at all give me a vote here--it costs you nothing.
Regards, SD TECH
Sep 17, 2009 | Sony KP-65WS500 65" Rear Projection...
Screen turns blue
You may have a bad blue picture tube but there is a way to deal with this first---This is a 2001 model and does not have a light engine---I did one of these with the same problem a week ago---the set has a black plastic block with six controls---three are Focus(red,green,blue) the other 3 controls are Screen controls(red, green, blue) Someone has to remove the entire piece on the front of the set below the screen(usually a plastic part) most of the time it is secured with 3 screws on either side of the set in the back; once you remove the screws the entire piece should pull out(pull from right to left(it will not fall off or come out easy--it is held in with several large plastic pegs) With it removed there is an inspection plate with 4 screws-----the screen/focus block is behind it.
You need to look very closely at the block to identify the focus versus screen controls----one row left to right will be marked Focus and the other row left to right will be marked screen------YOU need to locate the Blue Screen control(they are black like the block) With the set on(be careful) go to a video input with nothing connected---if you see a blue screen as well as the input number turn the BLUE SCREEN CONTROL SLOWLY TO THE LEFT UNTIL THE BLUE is gone.
If this cures the problem you may only be buying yourself some time----if the blue picture tube is bad sooner or later this trouble may return----I have seen sets where this was adjusted and the set worked for a year or more with no repeat of the trouble----replacing the blue tube would likely cost you 400 - 500 parts and labor.
I do this here for free so if this has helped you take a moment and give me a vote here.
SD TECH
Sep 03, 2009 | Sony Grand WEGA KDP-57XBR2 57" Rear...
How to break bios password
Continue with a blank password field, since none was manually set.
If that doesn't work, locate the BIOS battery and remove it for several minutes and replace it, that should flash the BIOS to default.
Feb 12, 2009 | Acer TravelMate C110Tci Tablet PC
Blue screen
your screen may be shot. Do not take out the battery. Try these IN ORDER:
1: place in charger overnight WHILE THE PHONE IS OFF!
2:place closed phone (that is on) in the refrigerator for 5 hrs. Leave open for 10 minutes to defog. DO NOT HEAT IT IN ANY WAY!
3: Turn off phone. Remove battery and let sit for 10 minutes to 1 hour.
If none of these work, then your screen is shot.
4: Take to your carrier's dealer and get the screen replaced.
Jul 22, 2008 | LG VX5200 Cellular Phone
The screen goes blank
try going to a previous version of firmware
get it here
Jan 26, 2008 | Creative Labs Zen Digital Media Player
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
48 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
