Question about O2 Xda II mini
White screen hi i installed an application and when the device restarted i faound just a white screen i tried to reset it but it didn't work plz tell me the solution or send it to my e-mail a_elsir101@hotmail.com
  • 2 more comments
  • a_elsir Jan 31, 2008
    i installed an iphone keypad skin
    i installed an iphone key pad skin
  • Manjit Singh
    Manjit Singh May 11, 2010
    please let me know which application you installed on PDA?
  • Al an Sep 21, 2012
    press and hold home button+volume down+ turn off button. That fixed my white screen problem
An iphone key pad skin
Posted on Feb 11, 2008
What application did you instal
Posted on Feb 09, 2008
I have a blackberry bold 9000 but my display screen is white and i cant see anything.but the phone vibrates and rings when i get my messages and calls. I can speak and hear the call properly only my...
try doing a battery pull if that doesnt work you'll want to run the application loader. i found steps on www.tmobile.com/forums
If the LCD screen is white, blank or empty, a soft reset may need to be performed, or there may be an error with the display drivers and the OS will need to be re-loaded onto the device. Please follow these steps:
  1. Remove the battery from the device.
  2. Wait 15 seconds, then replace the battery in the device.
  3. Turn the phone back on.
  4. If the screen is no longer white and functions correctly, the issue is resolved.
  5. If the screen is still white, continue troubleshooting.
  6. Confirm BlackBerry Desktop Manager has been downloaded to the computer.
If BlackBerry Destop Manger is installed, skip to step 2. If not,
  1. Install Desktop Manager
  2. Backup your information using the BlackBerry Desktop Manager (recommended).
  3. Download and install the blackberry handheld software to your computer.
Note: Running the Application Loader will take approximately 15-60 minutes to complete.
this link will actually show you a video on how and also all the steps with screen shots!!
http://forums.t-mobile.com/t5/BlackBerry-General-All-Devices/HOW-TO-Install-New-Software-and-Update-Application-Loader/ta-p/306005
Dec 24, 2010 | RIM BlackBerry Bold 9000 Smartphone
My acer laptop screen turns white while working
Try reinstall the video drivers as it looks like an issue with the video adpater. To do so:
Start Menu> All Programs> Acer erecovery management> Restore> install Application & Drivers> Select the appropriate Video driver (Intel, NTI etc as per your computer spec) and install it. Restart the computer and check, the issue should be resolved. If not, then I am sorry I bet the computer needs repair.
Jul 01, 2010 | Acer TravelMate 2300 Notebook
Whenever i download a software it shows ...that it require new version of microsoft.net compact framework then the version installed on the phone ....plz tell how to solve this
Some applications do require a newer version of .NETCF. You see, I have uploaded .NETCF v3.5 for you. I have also uploaded a small application, .Net Configuration. Install both of them on your device, and run '.Net Configuration'. I'll tell you how I configured it on my device, and you decide if it fits you needs: In the 'Device Policy' tab, I selected '3.5.7283' and tapped on 'Apply'. However I know that the mobile calculator doesn't quite like v3.5, for what in the 'Application Policy' tab, I selected '\Windows\MobileCalculator.exe' , assigned it to '2.0.7045' (my version of the default .NETCF v2;0 - yours might be slightly different) and tapped on 'Apply'. Tapped on ok to leave the application, and restarted my device.
Of course you can do differently: set your 'Device Policy' to v2.0 (as it has ever been) and assign the application, which is issuing errors with v2.0, to v3.5.
Hope it works for you.
Cheers! Carlos
Apr 19, 2010 | HTC Touch P3450 Smartphone
Itouch Problem. I only see White Screen help
To fix the iPod Touch white screen of death the solution I've used is press in the sleep/wake button on the top left of the device, and the big circular home button on the front face on the bottom. Do this for roughly 10 or more seconds and the device should shut down/off. Give if a moment and then restart the device.
If this doesn't work you can always try to restore it using iTunes. But be warned, this may wipe your files off your iPhone.
Mar 11, 2010 | Apple iPod touch
When I switch on my device I get a flashing white "X" in a red circle. The small picture of the hard drive[?] also appears on the bottom right of the screen. I have tried re-setting several times to no...
First turn your firewall off (if you have one).
You need to go into your 630 with the TomTom Home software and erase the downloaded software (with the remove items from my device) and reset the device (little reset button under the unit keep it pressed for 5 seconds), place it back in the cradle and restart your computer and than restart the 630 ,
Bring the TomTom Home program up, and when the TomTom Home software in your computer restarts and detects the 630 it will tell you that you need to update the application, if it doesn't than you force the update by going to the add maps option, select items on my computer, select applications and press the add button,
when done, go back and to device (option in top of your screen) and select disconnect device, restart your 630 and it should be back to life with the upgraded software.
Hope this Should solve your problem else Call their tech support at no charge (866-486-6866, Glen) , really good service
ENJOY! RATE THIS SOLUTION
RNJ VINOD KUMAR
Sep 13, 2009 | Tomtom Go 630 GPS Receiver
Screen deactivated & a red circle with an 'X' flashing
First turn your firewall off (if you have one). You need to go into your 720 with the TomTom Home software and erase the downloaded software (with the remove items from my device) and reset the device (little reset button under the unit keep it pressed for 5 seconds), place it back in the cradle and restart your computer and than restart the 720 , bring the TomTom Home program up, and when the TomTom Home software in your computer restarts and detects the 720 it will tell you that you need to update the application, if it doesn't than you force the update by going to the add maps option, select items on my computer, select applications and press the add button, when done, go back and to device (option in top of your screen) and select disconnect device, restart your 720 and it should be back to life with the upgraded software.
Aug 01, 2009 | Tomtom Go 730 GPS
Reset blackberry 8700
my blackberry 8700g on/off ligt red
Apr 16, 2008 | RIM BlackBerry 8700c Cellular Phone
Problem in using webcam of the travelmate 3260
Hi to everybody !
Please help me to finde drivers acer travelmate 3260 / WEBCAM DRIVERS
I download all driver from acer ftp but only one driver -camera - didn`t extracted
I think that this driver -driver vebcam is damaged !
Where can I finde other vebcam driver
thanks
from Elsan
Jan 27, 2008 | Acer TravelMate 2300 Notebook
Acer orbi cam not working
try to download the driver/application from acerpanam.com.
Jan 22, 2008 | Acer Aspire 5500 5570-2609 Laptop
TomTom GO 720 - flashing red circle with white cross on screen
Hi, I am back, just got the problem solved, I called their tech support at no charge (866-486-6866, Glen) , really good service.
Hope this helps
Aldo
Nov 20, 2007 | Tomtom GO 700 GPS Receiver
Computers & Internet Logo
133 people viewed this question
Top O2 Computers & Internet Experts
Computer Repairing
Computer Repairing
zurysk8
Level 1 Expert
Martin Murray
Are you an O2 Computer and Internet Expert? Answer questions, earn points and help others
