Question about Logitech QuickCam Communicate STX Personal Web Camera
Newly purchased stx plus: slow image and cuts out.
My image is very slow, choppy. Also, afer a few minutes, camera stops working and i get a message that %appname% is using camera, need to stop app, hit "reconnect" to use cam again. Can't find%appname% anywhere. Have to reboot system to get cam to work again, then problem starts over. Thanks for your help. Al
  • paul_335 Feb 09, 2008
    I have exactly the same problem - after using the Camera for a while using only the logitech software to take some stills, it seems to think another application called %appname% has grabbed the camera. I close all other apps and still it doesn't work. Rebooting is the only thing that cures it.
    Also when I'm using Window Instant Messenger the same thing happens ... so what is this mysterious %appname% ?
    President:
  • 2,712 Answers
Removing the software and reinstalling it using a "clean boot" may resolve the symptoms you are experiencing. Booting clean is a way to eliminate programs from conflicting with installation of software.
1. Unplug the camera from the computer. Later you will be prompted by the software to plug in the camera; do so at that time only.
2. Open the Windows Control Panel.
3. Open the Add / Remove Programs window.
4. Locate the listing for the software and remove it. When prompted to remove the camera drivers files, click Yes.
Now download the latest version of the software for your OS from HERE.
The following is the procedure for a 'clean boot'. I am assuming that you have XP. If you have a different OS, just let me know and I will send you the appropriate procedure to boot clean in that OS.
1. Click Start --> Run --> Type MSCONFIG --> Click OK
2. On the General tab, choose Selective Startup
3. Uncheck Process SYSTEM.INI file
4. Uncheck Process WIN.INI file
5. Uncheck Load Startup Items
6. Click on the Services tab
7. At the bottom, check Hide All Microsoft Services
8. Uncheck all boxes in the window or click the button labeled Disable All
6. Click OK
7. Click Restart
After restarting, reinstall the downloaded software. Next , do the following:
1. Click Start --> Run --> Type MSCONFIG--> Click OK
2. Replace checkmarks in the items that you previously removed them from.
3. On the General tab, choose Normal Startup
4. Click OK
5. Click YES, when asked to restart your computer
Hope that helps...Should you have any further questions, please feel free to post them here.
P.S. Before you assign a rating, please make sure that the issue is resolved or you are satisfied. If not, please post back as to what you did, and/or any other questions you may have, and I will try to assist you as best I can. Please do not assign an ‘Inappropriate’ or ‘Thanks for trying’ rating if your issue is not resolved after the first response itself, as sometimes a bit of to and fro dialogue may be necessary before we can find a fix or an answer to your query.
If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on Apr 26, 2008
  • 1 more comment
  • Swilin Sampson
    Swilin Sampson Apr 27, 2008
    Just checking to see if your issue has been resolved… If
    please close the ticket with a FixYa! Rating under my solution.
    I
    post them here.
    Cheers!
    IrishDruid
  • Swilin Sampson
    Swilin Sampson May 03, 2008
    Just wanted to inquire if your issue is resolved, or if there is anything
    further I can do to assist you…
    to, or resulted in a fix, please take a moment to close the ticket with a FixYa!
    rating under my solution.
    post them here.
    Cheers!
    IrishDruid
  • Swilin Sampson
    Swilin Sampson May 31, 2008
    P.S. -You can rate this solution with one of
    four votes, if you feel your issue is resolved.
    • "FixYa!"
      - The solution provides great advice on how to solve the problem.
      (Positive Rating)
    • "Helpful"
      - The solution provides useful leads that helps solve the problem.
      (Positive Rating)
    • "Thanks
      for Trying
      " - The solution does not solve the problem but the
      effort is appreciated. (Negative Rating)
    • "Inappropriate"
      - The solution has absolutely nothing to do with the problem.
      (Negative
      Rating)
    If your issue is not still not resolved, do not
    assign a rating just yet. Please post back as to what steps you took, results,
    etc, and I will try to assist you further as best I can.
    IrishDruid
Sent image freezes and I get message that cam is in use by another application
What messenger are you using? Let me know and I'll send you a fix so it will work. Thanks, Bud
May 18, 2009 | Logitech QuickCam Communicate STX Webcam
Slow slow slows down my computer!!
Normal 0 There are a number of things that can cause the computer or the camera to freeze up or slow down.
First I’d check to see how much memory is installed in the computer. It takes additional memory to operate the camera.
Hope this helps. Bud
May 19, 2008 | Logitech QuickCam Communicate STX Personal...
Logiteck quickcam communicate
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>- --> Troubleshooting: Image Quality for Cameras trnsp.gif Detailed Description This article covers some standard troubleshooting for issues such as fuzzy, grainy, out-of-focus or off-color camera images. trnsp.gif Answer The information in this article applies to the following software
QuickCam 9.x and below
ImageStudio 7.x and below
Many factors can affect the image quality of your pictures. If you are experiencing blurry images, please try adjusting the focus ring located around the lens. This will allow you to focus the camera image on objects at different distances. Also, make sure there is good lighting. Improving the lighting conditions can improve the image quality considerably.
Connection Issues:
If the image quality is poor while transmitting video over the Internet using video enabled programs such as MSN Messenger, Yahoo! or AOL Instant Messenger, your connection speed to the Internet directly affects the image quality of the transmitted video. Corporate LAN, DSL/cable modem connections will result in the best image quality experience, while dial-up connections may result in choppy and overall poor quality because of the slower connection speed. Even broadband connections such as DSL/cable modem may experience choppy video at times because of Internet traffic or slow upload speeds. If the image appears clearly in the camera software, most likely your Internet connection may be responsible for the poor image quality in your video program.
Changing Display Adapter Settings:
If you are still experiencing a distorted, fuzzy or grainy image, you may need to change the settings for your display adapter. For optimal image quality, please make sure the video display adapter is set to display at least 16-bit high color or higher. To change the color palette please perform the following steps:
  1. Click on "Start," "Settings," and "Control Panel."
  2. Double-click on the Display icon.
  3. Click on the tab labeled Settings.
  4. In the dialog box labeled Color Palette, verify the video mode is set to 16-bit (high color) or 24-bit (true color).
  5. Also, check with the manufacturer of the video card for updated video drivers.
Low Light Boost:
If you cannot do anything to improve the lighting situation, some Logitech video cameras have an option for "Low Light Boost." If there is an option for "Low Light Boost," try enabling the "Low Light Boost" in the QuickCam software. To do this:
  1. Open the QuickCam software.
  2. At the bottom right hand corner of the camera image box, click on the arrow next to the QuickCam icon.
  3. Choose "Advanced Camera Settings".
  4. Under the Image Enhancement box, place a check mark in the "Low Light Boost" option.
  5. If that does not improve the image quality, try adjusting the other image settings, such as contrast, saturation brightness, gain and white balance.
  6. Click OK when your are done.
Mar 05, 2008 | Logitech QuickCam Communicate STX Personal...
Webcam
Feb 28, 2008 | Logitech Webcam
My webcam has all of the sudden started running slow on msn, it didn't before, so I don't understand why it is now, I've installed 3 different cams and it's doing the same with each one
Feb 27, 2008 | Logitech Webcam
Web Cam Logitech 9000
slow computer with not enough memory and slow processor.
Feb 26, 2008 | Logitech QuickCam Communicate STX Personal...
Sony TRV22 Slow USB response
The lesson I learned was connect such with Firewire. And having an USB 1.1 cable is always a bad idea for USB 2.0. It may or may not work.
Sep 14, 2005 | Sony Handycam DCR-TRV22 Mini DV Digital...
Logitech QuickCam Communicate STX Personal Web Camera Logo
137 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
