Question about Thermador PRG304US Gas Kitchen Range
Thermador oven/broiler turns off after 5-8 seconds
I have a 30" Thermador ALL-GAS SELF-CLEANING RANGE that I purchased about 2 years ago. I have had intermittant problems where when I turn the oven or broiler on, it starts and lights the burners, but then it seems the gas shuts off after 5-8 seconds. Any ideas of the problem? I have already replaced the ignition unit. Thanks.
  • johnny40 Feb 26, 2008
    unit flashes code 43
  • Anonymous Mar 17, 2014
    My 7 year Thermador gas oven is not working. The broiler element is working but the gas stove done not work and I can smell the gas when I turn it on.
    President:
  • 1,314 Answers
Two things come to mind a faulty safty valve thats the device that the ignighters connect to the other maybe trash stopping the screen on the pressure regulater are any codes displayed on the clock
Posted on Jan 30, 2008
Whirlpool WFG510S0AS2 range - stove burners work just fine, but both the oven and broiler does not stay lit. NOTE - this unit has been converted from natural gas to LP
when the lp conversion is done , it is normally just a jet size change that is done
however the air shroud has to also be adjusted to get a clean blue burn of the flame
The just jet change results in a slightly yellow flame which is incomplete burn of the gas and that creates carbon build up at the jet and burners causing partial blockage
I would suggest that you call in an accredited gas fitter to check the problem and if necessary , clean the jets and adjust the air shroud
Dec 30, 2015 | Whirlpool WFG510S0AS
Broiler shuts off
Make sure you keep the oven door OPEN when using the broiler, otherwise the thermostat will shut it off.
Jan 18, 2013 | Maytag Gemini MGT8655X 30" Freestanding...
How do i start self cleaning oven
To Self-Clean:
1. Press SELF CLEAN to set the clean time to HI (4 hours
30 minutes).
2. Press the TEMP/TIME "+" or "-" keypads to cycle between LO
and HI clean time.
3. Press START.
The oven door will automatically lock. The CLEAN indicator
light will be displayed. The time remaining will also be
displayed.
4. When the self-clean cycle is complete and the oven cools, the
CLEAN indicator light will turn off.
5. When the oven is completely cooled, remove ash with a damp cloth
Remove the broiler pan, grid, cookware and bakeware, all
cooking utensils, oven racks and aluminum foil and, on some
models, the temperature probe from the oven
Dec 07, 2012 | Maytag MGR5751AD Gas Kitchen Range
Oven and broiler won't come on at times
my whirlpool roper gas oven or broiler wont come on can any one help me please
Oct 05, 2009 | Whirlpool 30" Self-Cleaning Slide-In Gas...
Temp control
No adjustment. Could be bad temp control unit or bad oven temp sensor. You would have to purchase a repair manual and test the current flow to and from the circuit. And then testing the oven temp unit with multi-tester.
Jul 23, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Self-clean turns off after 5 minutes with F2 error message
Hi MaryB,
F2 error code means that the oven temperature is too hot. You will have to replace relay board if faulty. Check and replace oven temperature sensor (RTD). If failure repeats, replace ERC (electronic range control or clock).For replacement part you may contact Sears at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central.
Hope this helps.
Thank you for using FixYa.
Apr 15, 2009 | Thermador C272 Electric Double Oven
Stove is suddenly haunted
F3 Oven too hot Replace oven temperature sensor it also sounds like you need a main control too..hope this helps
Aug 25, 2007 | Kenmore 75503 Stainless Steel Dual Fuel...
Thermador PRG304US Gas Kitchen Range Logo
698 people viewed this question
Top Thermador Kitchen Ranges Experts
Dan Webster
Dan Webster
butch welch
Are you a Thermador Kitchen Range Expert? Answer questions, earn points and help others
