Can't open windows, computer screen has
When I switch the computer on, a message: ATTENTION NO VIDEO INPUT floats around a black screen and I cannot get anything past this despite switching it off and on repeatedly. This first started while on a banking site and the screen went blank and after a while came back on and then blanked out again and then I got this message. I have checked all the cables and everything seems to be plugged in properly.
I am using Windows XP (well, I was!!)
  • mccleave Jan 30, 2008
    Thank-you, I'll try that. We have been having problems with our electricity supply and we often loose power for 2 hours or more. Could this have caused the problem? The computer is not on, but is plugged in during these power outages
    Thank-you, will do so when up and running.
    Genius:
  • 1,067 Answers
Bad onbord video need new video card ok if uuse atoi make sure pluged in u will have to go out buy new one that one toooka crap ok they do gota have cpu dusted out ever 2 3 mo gets to hot kills vvideos cards ect best to buy new one just video card
Posted on Jan 30, 2008
  • nick helpap
    nick helpap Jan 30, 2008
    yes video cards dont last to long erther in hot computers take big blower blow all dust out of it also and run cccleaner tooool free to dl online
I have a attention input not supported recanagle that continually scrolls around and around my screen and i cannot acces the menu or do anything. I disconnected it from my modem and then from the monitor...
This is most likely because your computer is trying to display a screen resolution higher then tht monitor can support. Turn your PC on, and press F8 until you see a black and white menu. Select safe mode. Run safe mode and when windows loads, goto your control panel. Select Display and navigate to the resolution / settings tab. The screen resolution should be set to 1440 x 900 for this monitor to display video correctly.
If you need more detailed information on where to find the display resolution settings in windows I will need the name of the OS you are running... XP, Vista, Win 7 etc..
Regards, Chris
Jul 01, 2011 | HP w17e Monitor
Screen went black and a window came accross the screen saying attention entering sleep mode......and then it said no video input...
It sounds like the problem is in your computer, hook a spare monitor to verify, if you have the same problem, it is your tower that needs to be checked out.
Mar 25, 2011 | Philips Computers & Internet
I have a blank screen on my HPf1905 monitor. I have a HPm7330n computer. How do I know if its the monitor or the video card? Monitor shows a message no input signal,then goes to sleep mode.
if the message you recieve is no input signal if only means that you have a problem with your video card, the monitor is fine but you need to have your video card check
Nov 21, 2009 | Computers & Internet
My laptop got broke, i'm using a small flatscreen monitor plugged into the back. a screen says "ATTENTION INPUT NOT SUPPORTED" just keeps floating around the screen. i don't know how to fix it
Start in safe mode and change the resolution to 1024x768 and 60Hz refresh rate. Restart and reset the resolution at the native of your display and 60Hz refresh.
Oct 28, 2009 | Acer AL1916W 19" LCD Monitor
During setup, got a "INput not supported" message
Reboot the computer and enter into Safe Mode through pressing F8 repeatedly on the keyboard.
If Windows will not come up, then you have to access the system through system restore.
In windows xp, it's c:\windows\system32\restore\rstrui.exe
In windows vista, it's c:\windows\system32\restore\rstrui.exe
This is done through Safe Mode with command prompt or command prompt; depending on the operating system.
Aug 08, 2009 | Acer AL2016W 20" LCD Monitor
FLOATING BOX WITH ATTENTION INPUT NOT SUPPORTED
Your monitor has several different video inputs.
Go to the configuration settings on your monitor and select the video input that matches the video cable from your computer.
Nov 12, 2008 | Computers & Internet
INPUT NOT SUPPORTED
Start your Windows in Safe Mode (pressing F8) during boot process and adjust your Display Settings to a lower resolution.... say 1024 x 768. Once fixed, you can play around again increasing the resolution a notch at a time. Fix ya!
Aug 28, 2008 | AOC A15X221 15 in. LCD Television
Monitor
When your computer is starting up, hit F8 and you'll see the safe mode, safe mode with networking, etc. screen...You should see a choice that says "enable vga mode". Select that and windows will start and the os will select a screen resolution for you. After that, everything will work fine...I hope.
Good Luck!
Anonymous
Mar 15, 2008 | Acer X193W LCD Monitor
FLOATING BLOCK
hi, it means, u need to change the input mode i.e pal/ntsc/vga..etc or whatever options avilable in the LCD menu..let me know
Dec 28, 2007 | Rosewill 19" 12MS DVI R911E LCD Monitor
Attention No Video Input
Check your input cabling and connectors and make sure you have a good input signal. Put another tv on this same input cable and see what happens. Keever
Dec 20, 2007 | Philips Magnavox 27MS343S 27" TV
Computers & Internet Logo
57 people viewed this question
Alun Cox
David Payne
David Payne
