Question about HP Pavilion (F2111-60950) CPU Heatsink & Fan
HP Pavilion Laptop
When I start my computer it vibrates really bad. Then through out the day ... the fan starts working 'really' hard to where it sounds like an air plant taking off. THe airplane noise gets more frequent through out the day. Suggestions?
  • lilxcute Feb 10, 2009
    my hp pavillion dv6174ea does the same thing. the sound is really getting very annoying
  • 1,067 Answers
Ya change that heat sink out get new thermal paste on cpu screw down mobo and everting else tight ok sells fans for heatsinks just gotta figureout what soket uuse ok
Posted on Jan 30, 2008
What to do if my laptop overheats often?
You have to get that fan working well because if you don't you will fry your motherbord and you will start poping caps computer run very hot
May 21, 2014 | HP Refurbished: Black Pavilion g7-2233cl...
I have an HP Pavilion a4000. It just stopped working a couple days ago. Display just rolled up and quit. I've been through everything I know how to deal with. When you push the power button it
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Jan 18, 2013 | Computers & Internet
I turn it on, but the screen stays blank and the fan starts blowing really hard, caps lock and other lights light up but my laptop doesn't start at all.
if this continues consistently you might be looking at a screen problem, take the system to a qualified laptop screen repairer to get it fixed.
hope this helps
Jul 06, 2011 | HP Pavilion dv7-1130us laptop
My cooling fan has stopped working - laptop is a hp pavilion, model tx2000
If you unplug the fan, you can test the connector to make sure the fan is bad and the problem isn't with the power getting to the fan.
You can get a new fan and heat sink assembly here (make sure the model number is the same as your computer):,Pavilion,tx2000,KX531AV,Laptop,Fans.aspx
But in the meantime, you shouldn't run the computer much because it can easily overheat without the fan.
Jun 06, 2010 | HP Pavilion TX2000Z Notebook
Hp start up broplem
This seems to be the fault in RAM ..pls try to replace the RAM ...If after replacing RAM not worked then the motherboard needs to be replaced...
Thank you for using FIXYA!!!!!!!
Dec 02, 2009 | HP Pavilion dv2000t 14.1" Notebook Laptop...
I have an HP Pavilion 9000 that was working just fine. We powered it down for the day and when we went to start it up the next day it would not start. Blue light is lit where power supply plugs into...
That a nice computer you have there. Based on your description, my guess is you have a bad power supply.
About a $300 fix if you send back to HP. Which is what I had to do a while back.
Oct 20, 2009 | Compaq Laptop Keyboard for HP Pavilion...
Make sure the PS or adapter you are using is good. If it does the same with another known working adapter or battery then it appears that the cmos on the mo bo is corrupted. U might try disconnecting the hard drive and optical drive to see if unit stays on. But if it still goes out then it is definitely the board and a faulty peripheral is not to blame.
If board is bad, time to go shopping since the repair is not really cost effective given the cost of the board and the high labor expense involved.
Jun 14, 2017 | Compaq Laptop Keyboard for HP Pavilion...
HP Pavilion dv2500 - FTB
The troubleshooting you have done seems to be fine. It does not seem to be a problem with the power supply,cord or battery.Did you try a hard reset. If there is a reset button on the bottom of your laptop, you might want to try pressing that with laptop plugged in, not plugged in, with battery, without battery and different combinations thereof.
If this does not work or you don't have a reset button read on.
Before assuming it's the motherboard, there is one other possibility. There is a part called a PCA switch. It is possible this switch has gone bad or a plug might have come loose.
If you are comfortable with doing your own work, you can obtain a repair manual for your laptop online. Within this manual, it should explain what is involved in replacing this part. It is really not too complicated.
It does not sound like a hard drive problem simply because it doesn't seem to be getting power to any other part of the laptop.
You can try these steps.
Aug 03, 2009 | HP Pavilion dv2610us Notebook
I have a HP Pavilion dv6000 and the fan has started making noises
Its possible but it would require taking out all the screws from the bottom of the latop, taking out the keyboard and the screws from the top cover. Then disconnecting the ribbon for the mouse pad and any other plugs coming from the top cover. After you take off the top cover you'll expose where the fan is at and at that point you can clean it off. If it still makes weird sounds then the fan would need to be replaced.
Jun 08, 2009 | HP G60-120US Laptop
HP Pavilion, Screen working, but extremely dark!
As per your description, I find that the issue is with the LCD Backlight which is also called as LCD Inverter which lights up the LCD to show us the Display on the LCD Display.
If this Backlight is gone bad, you will be barely able to see the Display on the LCD.
Coming to the Noise you had mentioned above can be from the Cooling fans of the Notebook which will be spinning at high speed when the Notebook starts and will reduce gradually after few minutes.
I recommend you to try cleaning the Cooling fan vents using any Vacuum Cleaner or Air Blower.
I recommend you to contact any nearest HP Authorized Service Center and get the LCD Backlight replaced.
Hope this helps....
Jul 21, 2008 | HP Pavilion dv6000z Notebook
HP Pavilion (F2111-60950) CPU Heatsink & Fan Logo
393 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
