Question about Dishwashers
Dishwasher pump not working
I have a kenmore model 665 that would not pump I took it apart cleaned it out now I am having trouble putting it back together . At the pump there is a spring what looks like a metalwasher and what I would call the impellor. when i took it apart it came apart and I did not see how it was put together. any tips on my problem and how to fix it would be great. the whole model # 665-17791790
    President:
  • 1,314 Answers
If you go here http://www.searspartsdirect.com/partsdirect/index.action and enter your model number without any spaces you can get a parts list on that page you will see show diagram it will give you a blueprint of the pump moter assembly
Posted on Jan 30, 2008
665.13049k110 kenmore dishwasher won't drain.
Check that the drain pipe exit point is higher than the water inlet and drain connection on the machine, thats a comin problem, also check and clean the drain pump situated at the front of the machine at the botom underneath the cover
Oct 03, 2017 | Kenmore Dishwashers
Kenmore dishwasher model 665-16629000 is leaking out the front. Checked the gasket, ok. Checked the door screws, took the door off, no cracks.
Before I took the machine out from under the cabinet, I would take a really strong light and some hand mirrors and try to see it leaking with the front cover off.
There is not a good chance this can be done.
Other than that, I would pull the machine out from the hole and test it where I could look underneath.
Should be either a drain hose of an inlet hose giving you trouble.
God bless your efforts.
Apr 15, 2016 | Kenmore Dishwashers
It wont wash the top of my dishes
If he left the blade and filter off this will cause the the spray arms to get plugged up with residue. Check the holes in the spray arms to make sure they are clear. The link below will show in detail how he took this apart and where you will find the screen and blade.
You should not have to pre wash your dishes, if everything is cleaned and working right in this machine all you should have to do is scrape and load.
Cleaning the sump
May 30, 2010 | Kenmore 24 in. 15193 Stainless Steel...
Kenmore Elite Mdl:665, Same probelem
if ur unit drain pipe is connected to air gap mounted at the sink then open up the cap of air gap and see if some food debris is stuck there?debris will rectrict the flow of water back to food disposar and water can remain in the unit.
Aug 21, 2009 | Kenmore 15899 Built-in Dishwasher
Dishwasher won't run. Light flashing on Air-Dry button.
check bottom of dishwasher, front left, round breather, gets clogged...clean and restart
Mar 13, 2009 | Dishwashers
Kenmore 665. dishwasher blinking "clean" light
kenmore lite blinks on quick rinse, seems to be stuck on that.
Aug 08, 2008 | Kenmore 15129 Built-in Dishwasher
My kenmore ultra wash model #665 does not pump out water.
my model #665 dishwasher will not pump water into the unit
Apr 25, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Kenmore 665 dishwasher blinking clean light
you'll need to enter a diagnostic mode, press in this order, hi-temp(sani-rinse)----heated dry--hitemp---heated dry... all lights should light, close door and let cycle for about a min, after press the cancelbutton, you should be good to go, the buttons on your model may read slighty different names, if this "toggle of buttons" does not work, you can remove thelower access panel and htere willl be a tech sheet/trouble shoooter behind the panel, in there it will explain how to enter diag/test mode
Feb 02, 2008 | Dishwashers
Dishwashers Logo
862 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
