Buzzing/Fizzing noise at the back of TV.
I have owned the jvc av-28r4sk for almost 3 years. There is a buzzing/fizzing sound coming from the back of the TV. It increases and decreases as the picture colour changes or as the picture transfers from scene to scene.Even with the sound at mute I can still hear the noise coming from the back of the TV. Can anyone help?
  • sodafarl Jan 31, 2008
    Thanks. I have already had an engineer look at this, but could not offer a sloution. Should he not have spotted this fault after testing it for a few days. If this is the problem how much is it likely to cost to fix.
    President:
  • 4,402 Answers
Sounds like arcing from the high voltage transformer. i don't not recommend using it until you have it looked at.
Posted on Jan 30, 2008
  • Cary Farah
    Cary Farah Jan 31, 2008
    flyback and labor looking at about 200
  • Cary Farah
    please mark the post solution as fixya
Tv making loud buzzing noise
A common cause are failure of decopling capacitors in the audio section, and or the circuit board power distribution that feeds the audio board. Most of the capacitors are surface mount components. The standard fix is to start by changing the circuit boards that have the defective parts.
If the set is under warranty, call for warranty service. Out of warranty service is expensive for these TV sets.
Jerry G.
Jun 12, 2012 | LG 32LG30 32 in. LCD HDTV
Tv started making a fizzing noise and now it is clicking as well with a slight movement of the screen during the click noises, goes up and down in volume now for a few days
is the fizzing noise when the screen is really bright? if so the scan coils on the tube have come loose and need glueing down with nail varnish i know it sounds strange but it really works
if the fizzing is coming from the tv then you have whats called dry joints
and this will need to be resoldered or the tv will shut down if you can do this yourself then the best way to find them is to remove the back and turn the tv on its side turn on the tv and turn off the light you will be able to see the dry joints sparking on the baord
hope this helps
John
Jul 06, 2011 | JVC AV32F476 32" TV
Hitachi UltraVision VG825 Series 60 inch Projection TV What is the part number of the lamp that I need? And, just to be sure, this is the process of what I do and what happens when I try to turn the T.V....
the fizzing sound you hear is most likly the ballast atempting to start the lamp so thats a good sign that the lamp is bad and not the ballast part # is(UX21516)
Jan 25, 2010 | Televison & Video
Buzzing/fizzing noise from back of sony flat screen tv
Below is an image of rear side of your TV, Sony KDL-40W5500
Top right corner is marked there and possible cause of noise seems back light inverter board, there are high voltage going to CCFL inside LCD panel and seems high voltage leakage causing that buzzing/ fuzzing noise.
Replace back light inverter board upon voltage leakage confirmation.
Thanks.
Oct 23, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Car wont start
try and listen where the fizzing sound is coming from. go to the fuse box where the relays are.put your hand on the relays when the key is turned and identify the one making the noise. sounds like the start relay is faulty. needs changing. hope this helps.
Apr 10, 2009 | 2002 Renault Sportwagon
Toshiba 36zp18q buzzing noise.
Humming sounds come from the power supply and buzzing sounds come from other circuitry. Most likely a capacitor somewhere.
Feb 18, 2009 | Toshiba 36A40 36" TV
LG Plasma TV has speakers fizzing in short bursts, cant hear any audio
Yes I believe you have a hardware failure in your audio amp IC. In some cases, a speaker will cause all the audio to distort, but its very rare for a speaker to cause this issue. If you just got it, you can return for a quick resolution, or contact a local repair center for a new main board replacement.
Nov 09, 2008 | LG 42PX3DCV 42 in. Plasma EDTV
Loud Buzzing Noise
Check filtr capacitor in power unit.
Check filter capacitor on supply to audio amp ic. or Amp ic itself is defective.
Gopali
Apr 23, 2007 | JVC AV-30W475 30" TV
Buzzing Noise and TV picture is yellow
Andy, I'm thinking the buzz is from the deflection coil (yoke) on the neck of the tube or the power supply. Probably not the high voltage as you can hear the "buzz". If it's really that annoying, you can take a length of rubber tubing (no metal) and listen to the buzz coming from the chassis kind of like a stethoscope. STAY AWAY FROM THE HIGH VOLTAGE, please. The yellow picture sounds like a blue chroma failure. A tube can be rejuvinated if need be but that's a job for a pro. Hope this helps.
Oct 30, 2006 | JVC AV-27220 TV
Televison & Video Logo
245 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
