Question about Visioneer 9020 Flatbed Scanner
Lock I have a 9020 which has worked fine, but the power adapter has had to be replaced, and since then I get a box saying Optical Module Lock is on. Please turn off etc. I have unlocked it a thousand times. I have turned off the scanner power, restarted the computer, no good. This is on Scan Reflective. On Scan 35mm or Scan Negative, the light carriage moves (so the lock is not on) but I get a box saying Verify the TA is positioned properly etc. I have a million 35 mm slides so I need this thing. Please help! David Powell davidmarkpowell@yahoo.com
  • 2 more comments
  • barradalagoa Jan 31, 2008
    djnick:
    Thanks for your response. Yes I got the new power adapter, and the problem started as soon as I connected with it. It is the correct voltage, so a power surge from the old one could have caused the problem.
    I have uninstalled and reinstalled several times with no success. I even connected the scanner to another computer and installed the program on it. Still get same problem. On Scan Reflective it says the lock is on, and on Scan 35mm and Scan Negative it says Verify Position of Trnsparency Adapter (but in this case the light carriage moves, so the lock is obviously not on.)
    I think its a hardware problem in the scanner, as it did get moved quite a bit when replacing the power unit. You had a suggestion about opening the scanner but I was not able to read all of it. Can you repeat please?
    I have tried unlocking, disconnecting, reinstalling etc to no avail.
    Any ideas?
    Many thanks
  • barradalagoa Feb 02, 2008
    I have uninstalled and reinstalled several times. In Scan REflective the scanner thinks the lock is on. In Scan 35mm and Scan Negative the carriage moves half way (so the lock is clearly NOT on) and the scanner no longer says Unlock, but says Verify the Transparency Adapters are positioned correctly.
    Could this have been caused by a power surge when its power adapter failed?
    Do I have to buy a new scanner? (I hope not - I really like this one!)
  • barradalagoa Feb 03, 2008
    Soulvisitor,
    Hi, and thanks for responding to my problem in such detail.
    Firstly, the scanner is not working at all. On Scan Reflective it tells me that the optical module is on, and that I should unlock it. I have, many times.
    On Scan 35mm and Scan Negative the box tells me to verify the position of the Transparency Adapter.
    I have scanned about two thousand slides on this machine, so I know the position of the adapters.
    Re the lock, the part that is moved by the control on the bottom of the scanner can be seen through the glass. It is clearly not inhibiting the movement of the light carriage, as on Scan 35mm and Scan Negative the carriage moves halfway along its track, then returns and the Verify the TA Position box appears.
    In fact, even on Scan REflective, the carrriage moves about an inch (i.e. past the locking device) then returns and the Module is Locked box appears.
    I believe the scanner may have suffered a power surge when its power adapter failed. It may have had a dose of 15v or more instead of the required 12v. Could this have done it? And can the effected part be replaced? I leve in Brazil so replacement will not be easy.
    Re possible Install Uninstall remedies, I have tried, and even loaded the program onto another computer. Same result, so I am fairly confident that the problem is in the scanner itself.
    Thanks again for your efforts
    David Powell
    Soulvisitor,
    Yes, both lamps are shining brightly. As a matter of fact they both come on when I boot up the computer. Then when I start the PaperPort program,The one that is not required goes out.
    This is such a shame - the damn thing is trying hard to work for me, and everything is fine except for this gremlin!
    Thanks for hanging in with me.
    David Powell
    President:
  • 1,944 Answers
It sounds like the problems you are experiencing is related to a hardware failure. I think that the unit needs to be serviced.
Posted on Feb 02, 2008
  • 1,113 Answers
David so this unit works normally, but doesn't when scanning slides, is this correct?
  • 3 more comments
  • Soulvisitor
    Soulvisitor Feb 02, 2008
    Ok so are you using a template and have it positioed correctly ie page please ensure pages 34 to 38 in manual are being followed
    Make sure that template has calibration area correctly postioned
    ie
    To scan a 35mm slide, first position the 35mm mask on the glass. The mask has one square corner.Align that corner with the arrow on the scanner body.Make sure that the text on the 35mm mask faces up so the slide fits properly in the mask.
    Follow the directions on the mask and place the 35mm slide horizontally into the slide holder.Notice that the mask has a narrow slot above the 35mm slide holder. That slot is for calibration to assure that you get the best possible scan results. Do not place items to be scanned in the calibration slot.
    To scan a negative, first slide the filmstrip into the 35mm negative mask and center the frame you want to scan in the opening.
    Then position that mask on the glass and align its square corner with the arrow on the scanner body.
    Make sure the text on the mask faces up.
    The 35mm negative mask also has a calibration slot. Do not place items to be scanned in the calibration slot.
    If this is being followed then what would of happened is the lamp in the lid of the unit has failed but the one under the glass is ok Just like a normally lamp they can be stuffed by power surges..
    Your scanner has sensors that capture the image of the item being scanned. Those sensors are located in the body of the scanner. When you scan a paper item, the light in the bottom of the scanner shines up on the paper and reflects the paper’s image down onto the scanning sensors.
    If a 35mm slide or negative is on the glass, however, the light from the bottom of the scanner would shine up through the transparent 35mm slide or negative and would not reflect its image onto the sensors. That is why your scanner has a light in its document cover.
    When you scan a 35mm slide or negative, the light in the bottom of the scanner turns off, and the light in the cover shines down through the film onto the sensors to capture the film’s image.
  • Soulvisitor
    If your scanner has a Transparency Adaptor (and yours must to do slides), check that the cable is plugged into the Option port on the back of the scanner.
  • Soulvisitor
    pic of lock that I'm pretty sure you already have made sure it is unlocked.
  • Soulvisitor
    Soulvisitor Feb 03, 2008
    Scan reflective uses a different light(scanner) than scanning for slides/transperancys, so the thery of scanner moves, so is not unlocked seems somewhat flawed.
    Did you read and follow djnicks link?
    Toggle the lock switch firmly 4 times leaving the scanner in the unlocked (open padlock) position
    • Unplug the USB cable from both the scanner and the computer then plug the USB cable back in again
    • Do not use a USB cable longer than 6 feet
    • Do not use a USB extension cable
    • If plugged into a USB hub or keyboard, try plugging the scanner directly into the back of the computer
    • Turn the scanner power back on
    • Try plugging the scanner directly into the wall
    • The low power output from a UPS battery backup can cause incorrect hardware errors to be reported
    and from the manual
  • Soulvisitor
    David can the lamps be seen to shine?, my first port of guess is that they dont, hence machine thinks scanner is not operating, the light should shine I beleive, during power up, and also when command to scan is given reflective or transparent..Look for it.
    Please insure when testing reflective that you have a original in place, not slides, and ensure when in scan transparent the template is positioned correctly.
    If no light can be seen, then I'd be testing the lamp for continuity.
    bu there is a good chance that they along with control board could of got zapped when power surge was experenced in the past as so could light sensors
    Chhers
    Genius:
  • 1,665 Answers
Follow installation instruction given at installation Guide below:
(uninstall , re-install)
http://www.visioneer-europe.com/support/manuals/en.pdf
http://www.visioneer-europe.com/products/home/9020/default.asp
Posted on Jan 30, 2008
    Genius:
  • 1,067 Answers
Have u gotten new power sorce yet and did it stop error from bad power supply not getting right voltage
  • 1 more comment
  • nick helpap
    nick helpap Jan 30, 2008
    take off the blue lid and there are two screws at the back of the scanner, take them out
  • nick helpap
    http://support.visioneer.com/Knowledgeba...
    read this ok talks about erroer u have how to fix more
  • nick helpap
    Step two: Verify the shipping lock is fully unlocked
    The scanner may have a shipping lock that prevents the scanning carriage from being damaged during shipping. Lock and unlock the shipping lock several times to be sure it is fully disengaged.
    For instructions on unlocking the scanner refer to the setup poster that came with the scanner
A LG soundbar to a Laurus TV I've fix a optical lead one end and jack plug on the other but it doesn't work
A fiber optic cable carries infrared light path only. It's a digital signal, you can only connect this to equipment that has an optic connection. Adapting it with any kind of analog jack just simply won't function.
laurus tv images Google Search
checking the Google images of the Digital module does not show a tos-link connection for the module.
Apr 17, 2015 | LG Televison & Video
I can call out on my Majic Jack Plus but cannot receive calls. The majic Jack is registered and set up on my modem.
This could be failure of the power adapter module.
Is your Magicjack plugged into the wall power thru a power adapter? Try bypassing the power adapter and plugging the magicjack directly into a USB port on your computer. If the magicjack work correctly now, then you have a bad power adapter module.
I had a similar problem. My Magicjack was plugged into a wall socket. First the dial tone became inconsistent, then I could no longer receive calls, then it died completely.
I plugged the MJ into a USB socket on my computer, and it then worked normally.
If you have a failing power adatper, it will continue to deteriorate, and it will eventually fail completely. The blue power on the magicjack will not come on when it is plugged into the power adapter, but it will illuminate when plugged into the USB socket on the computer.
Note: the computer must be on to power the magicjack thru the USB port.
Magicjack is aware of the problem and offers a replacement power adapter module. To contact them, go to www.magicjack.com and go to "support". They will ship you a new power module for about $5.50. Some people have reported that the replacement modules from Magicjack are no better than the originals and have had repeat failures.
Consider getting a power module from another source. There are lots of AC to USB power converter modules available on Ebay for only a few dollars. Search Ebay for "magicjack power adapter".
Oct 05, 2014 | magicJack Two, 2 Magic Jack Plus Voip...
Interior lights, radio, power mirors, remote door lock and power truck release do not work at all. Replace fuse and still dont work. Any ideas? Thanks
it is your body control module. . did not mix it up with the computer. the bcm runs every thing inside the car locks/radio/mirrors /etc.. in your car it is part of the fuse box under the dash
Jan 04, 2013 | 2001 Chrysler Sebring
I have lost the power adapter for the charge base. How many volts is the power cord? This is a GN netcom 9020
I have a 9120 headset and the mains adapter has the following spec if it's any help
input 230v 50 Hz 70 mA
output Dc 7.5v 700mA
I have found the manufacturer very helpful in the past and they would be able to supply an adapter
Feb 16, 2011 | GN Netcom 9020 Consumer Headset
My laptop will not turn on
Try another AC Adapter with the battery taken out of the laptop. If the light still blinks then that means the motherboard is bad and would need to be replaced.
Jun 01, 2010 | Compaq Evo N1020V PC Notebook
Blank screen on laptop
Sorry to hear you are having problems. I have had this same issue before with this particular model. The following solution works 90% of the time.Perform a hard reset as the first procedure.
  1. Disconnect all peripheral devices and remove all USB devices and media cards. You want to test the computer not the accessories!
  2. Disconnect the AC power adapter, remove the battery, and then press and hold the power button for at least 15 seconds .
  3. Reconnect the AC power adapter (but do not connect the battery), Press the Power button, Look for glowing LEDs near caps lock and num lock keys, and Listen for sounds of a disk drive and fan turning.
Meaning of Sample Blink Codes for some EFI Notebooks Number of Blinks or Beeps Location of Blinking LEDs Component Being Checked Error Condition Continuous glow Battery power LED Battery The AC adapter is attached and the battery is charging, but does not yet have sufficient charge to power the notebook. 1 Caps Lock/Num Lock CPU CPU not functional 2 Caps Lock/Num Lock BIOS BIOS corruption failure 3 Caps Lock/Num Lock Memory Module error not functional 4 Caps Lock/Num Lock Graphics Graphics controller not functional 5 Caps Lock/Num Lock System board General system board failure 6 Caps Lock/Num Lock BIOS BIOS authentication failure Continuous blink AC power adapter LED Power adapter Insufficient power
Blink codes are often displayed after a user adds memory to the computer but does not seat the module properly. The LEDs may also blink error codes if a hardware component is loose because the computer was dropped or jarred. Some HP Notebook PCs come with one stick of memory but have two memory slots. The problem could be that the stick of memory or one of the memory slots has a bad connection. The memory module compartment on most notebooks is located on the bottom of the case. The exact position varies by model. However, on some models, the memory compartment is under the keyboard. See your User Guide for the exact location of memory modules on your notebook.
Use the following steps to remove and reseat the memory modules: Step 1 - Remove the electrical power To remove all power from the computer and prevent accidental damage to the electronic components, do the following:
  1. Turn off the computer by pressing and holding down the Power button for about 30 seconds.
  2. Unplug the AC adaptor from the notebook.
  3. Slide and hold the battery release latch to the unlock position.
  4. Use your finger to lift the battery up and out.
  • Remove the memory module cover on the bottom of the notebook .Loosen the compartment's retention screws and lift up and remove the memory compartment cover. Remove the memory modules from the memory slots To prevent damage to the memory module, grasp the memory module by the side edges. Do not touch the metal contacts.
    1 - Pull the retention clips away from sides of the memory module
    2 - Gently pull the module out of the memory module slot
  • Reseat the memory module by holding module at a 45-degree angle, and pressing it firmly into the memory slot until it is seated.
    After reseating the memory module, replace the cover over the memory compartment before restarting the computer
    Hope this helps FiYa! If you find this solution helpful, please take a moment to leave us some feedback.
    Thank You!
    May 12, 2010 | HP Pavilion dv9000z Notebook
    Laptop will not power up, hard drive light flashes twice then nothing. model is an acer 9300 about 2 years old, the only thing I noticed before this is that it would never reboot from warn, you always had...
    Laptop is dead. How to troubleshoot the problem.
    In this post I’ll explain how to troubleshoot a dead laptop and find the problem. The following troubleshooting tips are not model and brand specific, they should work for most laptops.
    Let’s take a look at two different scenarios.
    Example 1. The laptop is absolutely dead.
    When you plug in the power adapter and press on the power button, there is no signs of life at all. The laptop will not make usual noises, LEDs will not light up, the fan will not spin, the screen is blank and black, etc… In short, the laptop is dead.
    What you can do in this case?
    1. Make sure the wall outlet is working and the laptop DC adapter is getting power from the outlet. Try another wall outlet.
    2. Test the laptop DC power adapter, make sure the voltage output is correct. You can test the DC power adapter with a voltmeter.
    3. Let’s say the DC adapter is fine and the adapter outputs correct voltage. In this case unplug the power adapter from the laptop, remove the battery, wait for 1-2 minutes, plug in the adapter and try turning on the laptop again.
    OK, you tested the adapter and it’s bad. If you decide to replace the original DC adapter with a generic one, you’ll have to follow this rule:
    The voltage output on your new adapter has to be exactly the same as on the original adapter. The amperage on the new adapter could be the same or higher.
    If nothing helps and the laptop is still dead, apparently the motherboard is fried or there is a problem with the DC power jack. It’s possible the DC power jack is broken and the motherboard is not getting any power from the adapter. In this case you’ll have to disassemble the laptop and replace the power jack.
    Example 2. When you plug the DC power adapter and press on the power button, the laptop starts making normal noises, the LEDs work properly but noting appears on the screen. The laptop will not start.
    First of all, take a closer look at the LCD screen. Look at the screen under bright light. It’s possible that the image is still on the screen but it’s very faint.
    If there is no image on the laptop LCD screen, test the laptop with an external monitor. Connect an external monitor to the VGA port on your laptop and turn the laptop on. You can toggle video output between the internal LCD screen and external monitor by pressing Fn and F4 keys simultaneously on HP laptops, Fn and F5 keys on Toshiba laptops, Fn and F7 keys on IBM laptops. Other laptops may use different key combinations.
    Let’s say the external monitor works fine but the internal LCD screen has no image at all. If that’s the case, your problem could be related to the LCD screen or the video cable. Also, make sure the video cable makes good connection with the motherboard and the LCD screen. Try reconnecting, reseating the cable.
    In my case, both internal and external monitors were absolutely dead. Neither of them had image. That means the problem is not related to the LCD screen or the video cable. From my experience I know that this problem could be related to the laptop memory.
    Try reseating the memory module, maybe it’s not making good connection with the memory slot. Try cleaning contacts on the memory module with pen eraser. Try moving the memory module into another slot. Try replacing the memory module with another known good module, it’s possible that your original module is dead.
    If you have two memory modules installed you can try removing them one by one, it’s possible that one of the modules is bad. Try installing different memory modules into different memory slots.
    In my case reseating, swapping the memory module didn’t help. I was pretty confident that my problem is not memory related and I moved on.
    Try removing battery, hard drive and DVD drive and turning on the laptop without these components.
    Oct 11, 2009 | Acer Aspire 9300 Notebook
    The A light is blinking but the laptop refuses to power up.
    Also, try turning on the laptop with an external monitor when the video cable is unplugged from the motherboard. If the laptop start with video on the external monitor, apparently there is something wrong with the laptop display panel.
    Finally, disassemble the laptop and removed the motherboard.
    1. Motherboard. Like on most laptops, in my case the video card is integrated into the motherboard
    2. CPU with heatsink and cooling fan.
    3. Known good memory module.
    4. The power button board witch you need to turn on the system.
    5. Working DC power adapter.
    Still cannot get any video on the external monitor. The system turns on, the cooling fan starts spinning but there is no video.
    At this point I’m 95% sure that the motherboard is dead. CPU failures are not very common, so it must be bad motherboard.
    Oct 10, 2009 | Dell Vostro 1500 1700 / Inspiron 1520 1521...
    Camry 1996 automatic power lock doen't work, but windows work.
    if you can here relays when unlocking/locking check for power at door lock actuators inside doors, if you have power on lock/unlock and good earth from connector actuators are faulty.
    if no power on test light when operating check output from central door lock module while operating, none coming out of module then it might need replacing.
    check 30Amp power fuse for main relay under bonnet (which goes to pin 8 white/blue on module)and 10Amp gauge fuse in cab(pin 1 blue/red on module),pin 15 is also power when relay is on(red/blue) with test light, and module/ actuators.
    check outputs from module pin 3 & 4
    blue/red
    blue/black
    that go to door locks
    Jul 20, 2009 | 1996 Toyota Camry
    Unlock scanner message, still doesn't work
    is this an exact power supply as the original? not all supplies are created equal. some are regulated, and some aren't. is the supply ac or dc
    Feb 10, 2008 | Visioneer 9020 Flatbed Scanner
    Visioneer 9020 Flatbed Scanner Logo
    153 people viewed this question
    Top Visioneer Office Equipment & Supplies Experts
    TomHighRidge
    Mark Gough
    Are you a Visioneer Office Equipment and Supply Expert? Answer questions, earn points and help others
