Question about IBM NetVista M42 PC Desktop
Memory upgrade I have an ibm netvista 8307 trying to upgrade to 2GB (2x1GB modules) have tried both PC2700 333 and PC2100 266 DDR but neither seem to work as the pc refuses to boot after the installation. If i put the original memory 512MB (2x256MB) the pc boots. Is there a jumper to set. My motherboard is a gigabyte ga-8igmiu factory fitted c2003. Thanx
    Genius:
  • 1,067 Answers
No jumper just touchy mobo on ram u buy u have to buy ram off ebayt samsung low denstity 64x64 chip config ok like i did and it workeed mark this as fixed ya so others can get same help thx nick
Posted on Jan 30, 2008
Memory Upgrade
The memory must be matched registered1333 MHz DDR 3 ECC memory. Make sure that the memory you purchased meets these requirements or the motherboard will not recognize any DIMMs that do not meet the requirements set by the manufacturer.
Jan 08, 2014 | IBM System x3200 M3 7328 Server tower ...
Descriptif 8307 73g
cobra software or 3dp pro
Oct 03, 2013 | IBM NetVista PC Desktop
I have an IBM Netvista A30p that I am trying to upgrade the memory in. It currently has 640mb and I am trying to go to 2GB. I have 2 1GB dimms to install but it will not boot with them. It will not boot...
are the modules of the same brand and type
make sure the sockets and ram modules are dust and corrosion free and are securely seated
you might swap each module over then reboot one might be faulty
RAM
  • Installed Size 256.0 MB / 2.0 GB (max)
  • Technology DDR SDRAM
    hope this helps
  • Nov 17, 2011 | IBM NetVista A30p PC Desktop
    I have a IBM Netvista 8307 and I was planning on a RAM upgrade and have a few questions. Im not sure if a RAM upgrade is what i need but my problem is, the computer has a hard time loading screens like...
    it sounds like a slightly older computer if your going to veiw streaming video i would go for more ram and $5 seems real cheap just make sure its the same ram card as your slot
    Apr 20, 2010 | IBM NetVista PC Desktop
    Acer Aspire ASE571-ED450A configured with 2x1gb My acer is configured with 2x1gb memory. I have two additional 512mb memory chips HYS72T64000HU.3.7-A 512mb 1Rx8 PC2-4200E-444-11-A1. Can these be used in...
    The 512MB PC2-4200 DDR-533MHz ECC Unbuffered CL4 240-Pin DIMM Memory Module Mfr P/N HYS72T64000HU-3.7-A will run with you're current 2GB DIMMS.
    Cheers'
    Mike
    Feb 23, 2010 | Computers & Internet
    Not upgrading 1gb ram to asus p5vdc-mx
    yeap its the wrong memory.
    max mem is 2GB DDR2 533/400 non-ECC, 2 x 184-pin DIMM
    or you can use. 2GB DDR 400/333/266 non-ECC,
    Note, you cant use both DDR2 and DDR in the same time. so set both memory stick as same type.
    so if you set 2x1GB DDR2 533 you get the optimized speed.
    hope it helps.
    Jul 06, 2009 | ASUS P5VDC-MX Motherboard
    Processor Upgrade For An IBM Netvista 8307-73G...
    If the physical size, and numper of pins is the same as your current processor, you can most definately upgrade. Hyper threading is enabled through the bios, but as far as I know it's not neccesary.
    Swapping out processors is fairly easy, and when you buy a new one, it should come with extensive instructions and pictures showing you exactly how to do it. Good luck!
    Mar 12, 2009 | IBM NETVISTA M42 - P4 2.4GHZ/512KB 256MB...
    Memory upgrades
    mostly most of computers allow memory increment upto 1 gb...wdout any issues ,,,so u can easly do it uptio 1 gb which is more thn suficient ,,,
    Sep 12, 2008 | IBM NetVista PC Desktop
    I have same problem as ninja9er
    hi,
    First try Using one at a time, since its not advisable to use memory chips with variable bus speeds i.e (333 & 266).
    Since IBM Computer are little complicated i would suggest your to call the customer care or Tech support for assistance in buying a Memory module. In that way you can cross check the memory module you have bought is compatible with the computer.
    Kindly give a feed back to Improve my statistics and to see If it was helpful for you...
    Thanks and Regards
    Mar 22, 2008 | IBM NetVista M42 PC Desktop
    Upgraded PSU
    go to www dot affordablesurplus dot com. This is a power supply company. they'll walk you through picking out a proper power supply and then some.
    Nov 29, 2007 | IBM (20L2312) for Intellistation Z Pro...
    IBM NetVista M42 PC Desktop Logo
    377 people viewed this question
    Top IBM Computers & Internet Experts
    Alun Cox
    pankaj rautela
    pankaj rautela
    Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
