Question about GE JKP30WMWW 27" Built-in Single Electric Wall Oven with Dual Element Bake & Electronic Oven Control...
Wall Oven No Power
The oven fan went of,f then on, during cooking and then oven went dead. Light in oven doens't work, panel display is black. I checked circuit breakers. O.K, not tripped. I turned circuit breaker off for 5 min and turned back on. Everything still dead. GE can't come out for a week. Any ideas?
  • 5 more comments
  • Anonymous Mar 12, 2014
    set the oven at any temp.and it will not start.
    Shows "LO" but will not increase in temp. Has the start time. I turned off the breaker for ten min. or so and then turned it back on, still wont light off
  • Anonymous Mar 20, 2014
    If timer is not set the oven will not work, I have set the timer earlier and cooked , timer went off at the correct time, food needed more cooking, tried to set timer, but couldn't , set the same as before. Any ideas?
  • Anonymous Mar 22, 2014
    had a short in light socket and tripped out breaker now only oven lights and convection fan don't work , the only thing i can see is it looks like i have no continuity in small transformer in back of oven ? could that be the problem or is it a pc board ?
  • Anonymous Mar 23, 2014
    Oven trips the mains circuit breaker
  • Anonymous Mar 24, 2014
    Our oven cut off in the middle of using it at 450 and seems to have no power now . We checked our fuses and everything seems to be ok. We cannot find a manual online.
  • Anonymous Mar 25, 2014
    all the light on control panel went on
  • Anonymous Apr 01, 2014
    The display lights aren't working
  • 1,314 Answers
Yes the oven thermal fuse blew when the fan went off its also called a tco switch if you pull out the oven and take the top off there will be a tech sheet there that will give the location of the tco some are on top some are on back this can also happen if the oven is too tight in the cabinet not enough room around it to let the heat dissipate its a round metal disc with two wires on it
Posted on Jan 30, 2008
Maytag cwe4800acb oven shuts off and display goes blank during heating
Display on maytag oven 8114p471-60 went blank - Fixya
Jan 20, 2013 - Stove top electric ignition still works fine, so there is power going to the .... maytag cwe4800acb oven shuts off and display goes blank during .
Oct 10, 2015 | Maytag CWE4800ACB 2.6 cu. ft. 24" Single...
My oven will shut off while cooking, it's like it loses all power
I have the exact same problem with my GE wall oven, my model number is JCKS05BA2BB. Is there a known fix?
Oct 03, 2012 | GE JKS05 Electric Single Oven
Lower oven loss of power
I'd check the control switch first, and the wireing and connections.
Sep 05, 2012 | Ovens
Blomberg BEP 906. After power went out a couple
When baking or cooking common foods in your oven, it is important that the oven heats to the proper temperature. Otherwise, the food in your oven could become over- or undercooked. The electric ovens are able to be calibrated if only slightly off, however, if the temperature is 25 degrees off or more, you should replace the oven sensor. The oven sensor is the device in the oven the detects the temperature. The control board increases or decreases the oven temperature, depending on the oven sensor reading. Before calling a repair technician, attempt to calibrate your oven or change the oven sensor.
1 Turn on the oven and set the temperature to a medium-heat setting, such as 350 degrees.
2 Allow the oven to preheat and then open the door and insert the oven thermometer.
3 Allow the oven thermometer to remain in the oven for a few minutes and the look at the temperature reading, comparing it to the oven temperature setting.
4 Recalibrate the oven if the temperature is only slightly off, or replace the oven sensor if the temperature is greatly off, such as 25 degrees or more.
Calibrating the Oven
1 Turn off the oven to prior to calibrating.
2 Press and hold the "Bake" button until the calibration settings are displayed on the display.
3 Use the arrow buttons or "+" and "-" buttons to adjust the temperature the number of degrees that the oven is out of calibration.
4 Press the "Start" button to save the calibration settings.
Replacing the Oven Sensor
1 Unplug the oven from the wall or cut the power to the oven in your breaker panel.
2 Open the oven door and remove the oven racks.
3 Locate the oven sensor, located at the top-center of the rear oven wall.
4 Remove the mounting screw securing the oven sensor to the wall and then pull the oven sensor away from the wall.
5 Remove the cable connected to the terminal on the rear of the oven sensor and then discard the oven sensor.
6 Connect the cable to the terminal on the new oven sensor and then reposition the oven sensor and secure it using the mounting screw.
7 Replace the oven racks and then restore power to the oven.
Dec 23, 2011 | Ovens
Hi got a NEFF B1691 oven. Thing is the oven light, element and fan keep switching off during cooking is this correct functionality - if not what could be wrong? The temperature display remains functioning...
There does seem to be a fault, as the fan should run continuously even when the element goes off at the required temperature setting, and the light should atay on as well.
It suggests to me that there is a fault with the oven thermostat, or it is wired incorrectly.
Dec 21, 2010 | Neff B1691 Single circotherm super...
Our display panel light went out on our model w30400p jenn-air single wall oven.
Make sure there's power getting to your range, oven or cook-top. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in. I would also advise to inspect the junction point on the backside of the unit for a possible separation of the power cord as well. If all checks out ok, The main control board will be the culprit.
NOTE_ If your unit is equipped with a relay board, this will be the likely culprit, if all checks out ok. If there is no relay board present inside the unit, replace the main control board.
Jan 02, 2010 | Jenn-Air Ovens
I saw sparks? or small flame on back wall behind fan inside oven
It sounds likely that the fan motor is faulty,more so if the oven is heating to some extent.
You should be able to see or hear if the fan is working or not
Hope this helps with your prob.
Nov 26, 2009 | Gaggenau EB 270/271 Electric Single Oven
278.4088891 Kenmore wall oven. The display goes black
Sounds like the "display" part of the timer is faulty or has a bad connection. As the cooker still heats up then the "relay" is working ok.
A replacement timer will be roughly £70 - £80
Hope this helps
Aardvark Repairs
Nov 15, 2009 | Hotpoint UY46 Style Line Stainless Steel...
Wall oven controls do not light-up or function.
i cant call you but iv seen this a few times the display part of the board went out (you can still probably get it to cook but cant see the temperature) you are gonna have to replace the board.
Dec 12, 2008 | KitchenAid Architect Series KEBC107KSS...
F1 code on display pad
That error means the main control board has a internal failure. The board will have to replaced to fix that issue. If you need detailed repair help with that visit the link below:
Appliance Repair Help With Live Chat
Mar 23, 2017 | Amana AOGD2750 Gas Double Oven
GE JKP30WMWW 27" Built-in Single Electric Wall Oven with Dual Element Bake & Electronic Oven Control... Logo
705 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
