Question about Philips 50PF9630A 50 in. Plasma Television
Philips 50PF9631D menu panel
I need to know how to remove the right side Menu Panel. the ON/OFF button has been mashed into the side where I can't get to it! Button is turned side ways.
  • Anonymous Mar 21, 2014
    blue screen comes up with panel lock on screen and don't know how to remove it or unlock it. I don't get a menu on the side of the screen also.
  • 476 Answers
The control panel is fairly straight forward to get at.
Reove the stand from the tv, and lay the tv, screen down, on a flat surface. You should lay a cloth of some kind to prevent scratching to the casing.
Remove all the screws from the central metal plate on the back. You will need a torx T10 driver for these screws.
Carefully remove the plate. Note any cables which may be attached.
Remove the screws from the outer back casing and remove the casing.
The control panel is held in by two screws. Remove the screws and re-position the control panel. If the control panel is damaged it can be replaced.
Posted on Feb 12, 2008
Mune shows up suddenly at anytime, side menu button doesn't respond
had the same problem, did a software update and it fine now.
you can update at site for your tv.
Nov 25, 2012 | Philips 42PF5521D 42 in. HD-Ready Plasma...
My Philips Plasma TV 50PF9631D/37 will not turn on. LED flashes 6 long, 3 short. Bad power board? How can I be sure it is not a bad 25 cent fuse on the power board?
Visit the site named 'Electro-help' for more details. Click this link. View it in 'Flip card' option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 990 posts to different brand TVs now. Pull up older posts there.
Oct 14, 2012 | Philips 50PF9631D 50 in. HD-Ready Plasma...
Is there a code number that needs to be entered to bring the convergence pattern or menu on screen.
From a user standpoint you would follow these steps to bring up your Convergence menu:
1) Press your MENU button.
2) Press the Right Cursor Button to enter the Picture menu.
3) Press the Down Cursor Button until you highlight the MANUAL CONVERGENCE choice on the menu.
4) You will then see the following choices on the right hand side of the menu: Convergence Red, Convergence Blue, Multipoint Red, Multi Blue, Save Multipoint.
5) Once you choose either the Red or Blue choices you will get a crosshair in the middle of your screen. You will then use either your Up, Down, Left, or Right Cursor buttons to get the two images to line up correctly. If you still have multi images on your screen in either Red or Blue you would then have to adjust the Multipoint choice for that color.
May 14, 2011 | Philips 51PP9100D 51 in. Television
Casing on off switch plastic mount on side of tv broken. on off switch dropped inside
Hello, you're supposed to put the TV on the screen carefully. Remove the screws of the lid back and assess the damage. Usually it is possible to catch the break, or improvise in any way, the switch back in place.
Let me know if it worked out, or if you need additional guidance
Mar 06, 2011 | Philips 50PF9631D 50 in. HD-Ready Plasma...
Philips 50 amblight keeps returning to menu screen
I'd open the TV by pulling the back cover and then disconnect the buttons bar cable to see if the problem is there.
This is the #1 thing I would do in an attempt to isolate the most likely source of the effect.
Let us know what happens.
Mar 24, 2010 | Philips 50PF9631D 50 in. HD-Ready Plasma...
50 in philips hd plasma with ambilight model number 50PF9631D/37
The x-sus and y-sus panels have some fuses,check to find out wich panel is broken and replace.
Sep 04, 2009 | Philips 50PF9631D 50 in. HD-Ready Plasma...
I need to know if where the input button is on my Philips Plasma
go to link below.
http://www.p4c.philips.com/files/5/50pf9631d_37/50pf9631d_37_pss_aen.pdf#search=%27owners%20manual%27
Jun 22, 2009 | Philips 50PF9631D 50 in. HD-Ready Plasma...
Problems with getting channels locked in on our plasma tv
Yuo can change the pin # even if you don't know the old one then you can can turn off with the new one.
Press the 'MENU' button on the remote control.
Press cursor down to select SETTINGS.
Press cursor right twice.
Press cursor down to select MENU PREFERENCES.
Press cursor right.
Press cursor down to select CHANGE PIN.
Press cursor right once.
Enter code 0711 if you have don't know yours
Enter a new four digit PIN using number buttons. Number combinations from 0000 to 9999 are valid.
When prompted to confirm PIN, enter new PIN again.
Press the 'MENU' button to exit the menu.
Feb 22, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
Flatscreen TV
your best off calling philps at 1-888-philips to purchase remote to access and change menu settings more conveniently but if you press the menu button on keyboard on lower right side of tv you can use the volume and channel buttons to navigate menu. user manual is available at www.p4c.philips.com in pdf format to download. this model was manufactured in mid 2006 to 2007
Aug 14, 2008 | Philips Televison & Video
Open Questions:
Philips 50PF9630A 50 in. Plasma Television Logo
103 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
