Question about Siemens SL75 Cellular Phone
Software and display most of the time not loading
Since a long time after purchase of sl75 mobile phone it goes to sleep and doesnot wake up some times when i opt for camera option phone is dead and i am not able to revive it any solution to the p[roblem? i purchase in november 2006
  • Anonymous Mar 30, 2008
    I own siemens mobile phone, model no. SL75, it does not come on, it does give a very faint beep and the screen also lights up very faintly, but after this the mobile phone is dead. I have got my battery checked, it is fine, and is also able to store the power in it. Since the mobile phone does not come on it is practically impossible for me to retrieve my contact list, which is very important. I have the balance contact list which was on my sim card, but balance contact list which is on my mobile phone memory chip is not retrievable, please help me to get my contact list back, thank you. -
Also same problem!!!
Posted on May 01, 2008
Installling the software operating sytem on a IPhone
Download the latest iTunes to your computer and reset the iPhone. Then re-sync it.
Reset
To reset iPhone, press and hold the Sleep/Wake button and the Home button at the same time for at least 10 seconds. During this time, a red "power off" slider may appear and the screen may go black, but do not release Sleep/Wake and Home buttons until the Apple logo appears.
If iPhone won't turn on, or the display freezes or doesn't respond
  1. Press and hold the Home button for at least six seconds, until the application you were using quits.
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a 10 seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  3. If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears
More resets:
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
Dec 18, 2010 | Apple iPhone 3G
Sleep/hibernate mode
Hi, If the computer seem to wake from sleep mode for no reason? Some device settings can cause the computer to return from a power savings state when not expected. If the computer is using an optical mouse, changes in light can cause the computer to wake. Network activity can cause the network hardware to wake the computer, especially when the network is always on (like cable and DSL connections). High Definition Audio audio may also cause the computer to wake from sleep mode. Use the following steps to prevent the these hardware devices from waking the computer:
  1. Click Start c00847244.gif , and then right-click Computer .
  2. Select Properties , and then click Device Manager in the left panel of the window.
  3. Click the plus sign ( + ) next to the device that needs to be adjusted. If you are using an optical mouse, select Mice and other pointing devices . If the computer is using an "always-on" connection, click Network Adapters . To check the high definition audio, click Sound, video, and game controllers .
  4. Double-click the name of the device to open a Properties window.
  5. Click the Power Management tab, and remove the selection from Allow this device to wake the computer . Figure 6: Power management tab for a mouse c00851648.gif NOTE: If you prevent the mouse from being able to wake the comuter, wake the computer using the Sleep button on the keyboard or from the power button on the front of the computer.
  6. Click OK , close the windows that are open, and then restart the computer.
  7. Click Start c00847244.gif , and select the Sleep/Standby button to see the problem still exists: If the problem still exists, go to the next Step.
  8. Disconnect all non-essential connected devices (printers, scanners, USB drives).
  9. Restart the computer with only the original mouse, monitor, and keyboard connected. If this resolves the sleep/standby problem, one of the connected devices was causing the problem. Replace one device and test to see if the problem occurs again. Continue adding devices and testing until the you find the device that is causing the problem.
If you have already tried all the above steps, you can try the steps below: Many software components start up automatically and run without being seen. Most of these programs are not necessary to the work performed on a computer, but can interfere with sleep/standby mode. For troubleshooting purposes use the following steps to prevent programs from starting when Windows is first opened.
  1. Click Start c00847244.gif , and then type msconfig into the Search field and then press the Enter key.
  2. The System Configuration Utility appears. Click the General tab, select Selective startup , and then and remove the check from Load startup items . c00847247.png
  3. Click OK to accept the changes and restart the computer.
  4. After completing these steps, Windows opens using Selective Startup. A small reminder may appear when Windows restarts. Select Don't show this dialog again and click OK to prevent the reminder from re-appearing every time the computer is restarted.
NOTE: To undo the changes made in this process repeat the steps above and replace the checkmark next to Load startup items .
  • If disabling Load startup items did not resolve the suspend problem, go to the next step.
  • If disabling Load startup items resolved the suspend problem, enable one startup item and test to see if the problem occurs again. Continue enabling startup items, until you find the software task that is causing the problem. Remove or update problem software.
If the problem still exists, go to the next Step. Upgrading the BIOS and keyboard software If the sleep button on the keyboard still does not work, go to the HP Software and Driver Download page , enter your computer model number into the field provided, and install any keyboard and BIOS updates for Windows Vista. Should you require any further assistance regarding this issue or any other computer related issue in future please feel free to contact get back to us, we will be more than glad to assist you.
Regards
Malik Khan
Feb 01, 2008 | Microsoft Windows Vista Ultimate Edition
I think the display screen on my iphone 3g went out. how do i check?
Reset the phone:
More resets:
Try This:
1. Remove Sim Card
3. Replace Sim Card
Also, Try this:
2.) Start up iTunes
Dec 12, 2010 | Apple iPhone 3G
Instruktions for mms.From sweden , halebop
Ok i did this yesterday and it works for sl75
go to this address
http://www.halebop.se/mobiltjanster/installningar/
type in your mobile number
press "vidare"
chose "simens"
chose "SL65" (yes this works with SL75 to!!)
press MMS
then you'll get a sms that tells you that the settings will be sent
when you get the settings, install them then restart your SL75 and your done!!
Nov 10, 2010 | Siemens SL75 Cellular Phone
Iphone 3GS- only get the apple loading screen.
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a few seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
More resets:
Try This:
1. Remove Sim Card
3. Replace Sim Card
Also, Try this:
2.) Start up iTunes
Nov 29, 2009 | Apple iPhone 3G
How do I wake up the monitor when it goes to sleep when not used for a short time.
slapping it around usually works. "just a joke!"
tapping a few keys on your keyboard and moving the mouse will usually wake the monitor from sleep mode.
Nov 11, 2009 | Office Equipment & Supplies
Volume up key puts computer to sleep
try uninstalling keyboard software then re install.....do reply back if this works
Sep 30, 2009 | HP Compaq Presario SR5130NX PC Desktop
My phone goes to a sleep mode and refuses to wake up.
Mine does that sometimes too. If you just press and hold the button for about 3 seconds, it will turn on within 15 seconds.
Apr 01, 2009 | Samsung Omnia Cell Phone
Phone app not working correctly
If you have Kate installed - remove it. This solved the same problem that I was having
Sep 14, 2008 | Apple iPhone Smartphone
Non stop booting
1st- Press and hold the Home button and the Sleep/Wake button at the same time.
2nd- As soon as the screen goes black release the Sleep/Wake button. Continue holding the home button until you iTunes pops up a message telling you that it has detected an iPhone in recovery
Dec 27, 2007 | Apple iPhone Smartphone
Siemens SL75 Cellular Phone Logo
308 people viewed this question
Top Siemens Cell Phones Experts
Computer Repairing
Computer Repairing
michael galang
Yoav Shilon
Yoav Shilon
Are you a Siemens Cell Phone Expert? Answer questions, earn points and help others
