Question about HP Officejet 5610 All-In-One InkJet Printer
Scanning and copying all in one 5610
If I try to copy or scan a document I get a black page (printed or on screen). Also when I changed the black ink and tried to align the page it said it couldn't detect the alignment page on the glass. It seems the scanner head is not working correctly. Any help appreciated
Thanks
  • Azli Feb 04, 2008
    Hi
    I have the same problem too.
    HP Support has directed me to here:
    http://h10025.www1.hp.com/ewfrf/wc/docum...
    But no luck too. My usage for 2 years around 700++ pages for printing and scan is very minimal.
    Anyone?
    Thanks
  • Anonymous Mar 19, 2014
    When I lay the page on the glass and hit start, it scans the page, but then asks a series of questions (job finish, cancel, etc.) instead of spitting out my copy. I just want to make a copy from the glass quickly. Thanks!
    Problem Solver:
  • 9 Answers
Pls. check ur scanner cartridge move or not if it is move then
set the default settings of printer menu
if the problem resolve pls. remark me
Posted on Jan 30, 2008
6ya staff
SOURCE:
Epson stylus dx6000 only copy in color mode
Any ink in the black cartridge or can you use clean mode to clean it?
Mar 15, 2014 | Office Equipment & Supplies
The scan of color document gives a black and white product
there some reasons :
1- Are you sure to select the copying color not black and white ?
2- try to reset color ink cartridge ,
3- try to select clean print head
i hope that was help you
Mohamed Hejazi
Afaqnama -Libya
[email protected]
Mar 21, 2013 | HP Officejet 4620 e-All-in-One Printer,...
Copying a document prints out black page
Its CCD(scan camera) unit faulty, replace it..see the idle snap shot
Jan 09, 2012 | HP Officejet Pro L7680 All-In-One Printer
When scanning or copying a document it prints a black page
IN NO TIME AT ALL, YOU WILL RUN OUT OF INK.
SUGGEST YOU REMOVE PROG RESTART, THEN SETUP AGAIN. GLITCH?
Nov 15, 2009 | Dell V305w All-In-One R840635AU InkJet...
HP OfficeJet J5780 Vertical Black Line Prints when copying or scaning only. Cleaned rollers and changed black ink cartrigde. Still problem.
Have you tried cleaning the document feeders Scan Glass? (small glass under doc feeder ~ 1" by 9") Most times there is dirt spot on this glass, causing a shadow on scans and copies.
Try copying from the large glass by lifting doc feeder / platen cover and manually placing original. If no line copying or scanning manually from large glass, then small scan glass is deffenitely the culprit. Hope this helps.
Sep 07, 2009 | HP Officejet 5780 Printer
HP Officejet 5610 - Scanner/Copier only prints black pages
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.hp.com/printer/prob676ijt65/solution
djiu9ofdfd27
Jul 08, 2009 | HP Officejet 5610 All-In-One InkJet...
Scanned Items or Copies all print in Solid Black
I assume that you mean color images are being produced in black and white. If that's the case, there's a document on the HP web site that shows you what to look for and provides solutions:
Color Image Prints in Black and White
Good luck.
Sep 13, 2008 | HP PSC 1610 All-In-One InkJet Printer
Blurry Scanning/Copying
Are you scanning both black and white and color the same way? The ADF (automatic document feeder) uses a different scanning area than when you place the document on the scanning glass. If you open the scanner cover, look to the left of the main scanner glass to the narrow strip used for the ADF. Make sure this narrow strip is clean -- no ink or white-out or scratches. This can make your copies look dirty or smudged.
Jul 26, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Scanned documents are very light
I have found that when scanning b/w documents, its helpful to start with a black and white copy, not a grayscale, pen written, or printed form a printer in grayscale mode copy, but a true black and white on the copier or fax copy. The scanner doesnt read shades of black so well and when scanning multiple page documents, my pixma tends to scan in lightly. I havent found a piece of software to do just this, batch darken what has been scanned (at least not for free). Copying before scanning is the work around. Hope this helps everyone who's had this problem. It also doesnt hurt to darken what your scanning down a notch when copying
Mar 21, 2008 | HP PSC1510 Printer/Scanner/Copier...
Black lines
Not sure what you have tried but if there are no lines when printing but there when scanning there is something on the scanner. Could be something as small a single dot of dirt and it will put a line down the whole page. Try cleaning the glass.
Dec 13, 2007 | Office Equipment & Supplies
HP Officejet 5610 All-In-One InkJet Printer Logo
305 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
