Question about ASUS P4P800 SE (890552603657) Motherboard
Strange ram problem: just one socket works
Hi this is Georg from Germany, hope you can help me;)
I've got an problem with my asus p4p800 se motherboard. yesterday I removed one of my two 512mb ddr DIMMs. maybe I caused some problems because after reinstalling it the computer didn't start properly. just the fan and drives startet but there was nothing on the screen even the BIOS seemed to be dead...no beeps or something like that.
I removed the ram again and the pc did start...Now my curious problem: at this point the working RAM DIMM was installed in socket DIMM A1. later on even this didn't work anymore... I removed and installed the Ram several times and tested ervery DIMM socket on the board. Now it seemes that socket DIMM B1 is the only one working. I tested every socket and this is the only socket where the pc starts.
The actual state is:
-just socket B1 works
-just one of my two DDR DIMMs works in this socket
any other configuration causes the problem I posted above. It seems that not only the RAM is broken but also the board. am I right?
thanks for your help
Georg
  • 749 Answers
Try cleaning the socket with a small clean paint brush or similar to this... then clean the memory socket-in area with an eraser, best eraser is the black area of RABBIT brand... or Mongol eraser.. Just clean that part and try again...
I hope it works.... Works most on my customers here on my shop.
Posted on Jan 30, 2008
Download ethernet controller drivers for p4p800 se asus mainboard
Go to the follwong site and follow these steps: -
http://support.asus.com/download/download.aspx?SLanguage=en-us
1. Select Product - Mother board
2. Select Series - Socket478
3. Select Model -
P4P800 SE and click search, it would ask you for operating system
4. Select operating system and download drivers
Hope it helps!
CreativeTECH
Nov 22, 2010 | ASUS P4P800 SE (890552603657) Motherboard
I have p4p800 se 2.6 ht cpu I recently bought 2-1gig sticks of ddr400 pc3200 cl3 hp memory and tried everything I could think of wont boot can anyone help
Asus gives this as the board memory spec:
-4 x 184-pin DIMM Sockets support max. 4GB DDR400/333/266 non-ECC DDR SDRAM memory
I suspect you bought DDR2 type memory.
Apr 16, 2010 | ASUS P4P800 SE (890552603657) Motherboard
PCI Simple Communications Controller, seem not to function
Hello my friend
First your motherboard does not support windows 7 and the maximum ram capacity is 4GB DDR400/333/266 non-ECC DDR SDRAM memory
Second you can go here and check which memory your motherboard supports
P4P800 SE Memory QV
http://dlcdnet.asus.com/pub/ASUS/mb/sock478/p4p800-se/P4P800_SE_QVL.pdf
Third you can try updating your Bios,more information in your manual
MANUAL
http://dlsvr.asus.com/pub/ASUS/mb/sock478/p4p800-se/e1886_p4p800_se.pdf
your motherboard details is here
http://www.asus.com/product.aspx?P_ID=YNlDkmz5gSNpiCr6&templete=2
Good luck
Jan 14, 2010 | ASUS P4P800 SE (890552603657) Motherboard
Cmos settings error system hait,
You will need access to another computer and go to: http://www.asus.com/, choose you country, then "Download", the on the next page, "Download" again. Select you "Product, Series and Model". Motherboard, Socket 478, P4P800-SE click "Search". Then choose you operating system. You will get to the page where you can download the latest BIOS, and install program. Read how to upgrade your BIOS and follow the directions carefully.
I suggest you also change the CMOS battery before you upgrade to make sure a dead battery is not the cause for the CMOS corruption.
Jun 10, 2009 | ASUS P4P800 SE (890552603657) Motherboard
Does ASUS P4P800 deluxe support high density memories
Here is a link to Asus' Qualified Vendor List of RAM modules for your motherboard. I do not see it mention high density RAM. You would need to search the specs on the modules recommended to be sure.
ASUS QVL
In case you don't have the manual, here is a link for it too:
ASUS P4P800 Deluxe Manual
Memory info begins on Page 2-10. Again, there is no mantion of HD modules.
Mar 01, 2009 | ASUS P4P800 SE (890552603657) Motherboard
ASUS P4P800 SE DVD WRITER NOT WORK
Turn the burn rate down.If that does not solve the problem.reinstall the burn program.
Was this solution helpful? Show your Appreciation by rating it..RICHARDM69
Dec 14, 2008 | ASUS P4P800 SE (890552603657) Motherboard
Is AGP slot acepting PCI express card?
Yes, your motherboard actually does contain an AGP 8x VGA interface. (ASUS reference is at http://www.asus.com/products.aspx?l1=3&l2=12&l3=31&model=179&modelmenu=1 AND http://www.asus.com/products.aspx?l1=3&l2=12&l3=31&model=179&modelmenu=2.) This means that the video card you replace the All in Wonder with must meet that specification unless you are prepared to switch out the board.
However, as the card you have indicated above is a PCIE x16 card, that may represent additional compatibility options. (The reference for this card is here: http://ati.amd.com/products/radeonx1300/aiw2006pcie/specs.html). This is a bit confusing, given that the motherboard specs indicate an AGP 8x interface. There is the indication on the "modelmenu=2" page that the MB includes 5 PCI expansion slots, but there is no mention of any PCIE x16 interface.
It is often best to return to the site of the manufacturer, or a respected seller, to check for compatibility with the specific brand and model of your PC. This would likely be the best approach, and if you would like for me to help with that, please post back with the information.
If this information assists you in resolving the problem, please take a moment to rate the solution at a "FixYa" level. If you do not feel that you can rate at a "FixYa", please post back with more information regarding what has occurred subsequently and/or more details regarding the situation, and I will gladly help you until we have reached a definitive solution. Thank you for using and rating FixYa!
Sep 30, 2008 | ASUS P4P800 SE (890552603657) Motherboard
Asus p4p800-x no screen no beep
Could be that your ram is either Bad or the wrong type. I just had a similar problem. I changed the ram and up it came.
Aug 04, 2008 | ASUS P4P800-X Pentium Motherboard
Try to have the driver of the motherboard p4p800 se sound driver
hello,
You can find your drivers here: http://support.asus.com/download/download.aspx?SLanguage=en-us
Pls input necessary data about your motherboard.
may this help
melnavz
May 02, 2008 | ASUS P4P800 SE (890552603657) Motherboard
ASUS P4P800 SE (890552603657) Motherboard Logo
69 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
