Question about Canon PC-940 Black and White Copier
Canon PC940 copier
Was using my copier and it turned itself off and will not power up.
  • msprissy Feb 22, 2008
    I have a Canon PC941 and the machine will not power on. I hardly use the copier.
  • Anonymous Oct 01, 2008
    My pc940 was working until I plugged it into a bad outlet, it got a surge and now wil not turn on.
    Problem Solver:
  • 6 Answers
Check the operations panel on/off switch.
Can be a problem on this type of machine.
Posted on Jan 30, 2008
Start button for canon pc940
I also am having this problem...but the system tray disapears almost like someone took some scissors and cut it out..and all my icons slide under the startbutton. but whatever programs that are unminamized i can still use..but thats all
Mar 19, 2014 | Canon Pc940 Alog Copier 13cpm 0008a040
Trying to find a manual for a canon pc940
http://www.devicemanuals.com/guide/Copier/Canon/Canon-Personal-Copier-PC940-User-Guide-TkRFd01URT.html
Jan 01, 2011 | Office Equipment & Supplies
I get E0 message and the copier shuts off copier model PC940
to reset that error remove the two screw in both side of control panel then after that remove the control panel then you will see a board in that board just look for two terminal there is service indicate in that terminal just make it shorted that 2 terminal then turn on the power switch
Nov 28, 2010 | Canon PC-940 Black and White Copier
Canon pc940 error code e261
try turning the machine off and then on...you either had a power surge and it freaked out your machine or the fuser is shot...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Dec 17, 2009 | Canon PC-940 Black and White Copier
EO10 CANON PC940?
E010 is a code indicating main motor failure.In actuality it rarely fails.look for a broken belt or gear in the Main Motor train.Good Luck
Apr 02, 2009 | Canon PC-940 Black and White Copier
Toner is jam and will not come out.
Generally with a PC940 you must rotate the old toner cartridge clockwise to get it out.When you put in the new one, after pulling the tape off turn it counterclockwise to get it to work.Good Luck
Mar 17, 2009 | Canon PC-940 Black and White Copier
Canon pc940 won't turn on
power fuse blown on power supply board ,replace it.
Dec 10, 2008 | Canon PC-940 Black and White Copier
Canon PC940 Ticking noise when copying and regestration is off
The waste toner is in the drum unit it's self. If it full you may as well replace the drum unit all togather. Once it is full the drum is just about shoot. If the regestration is off, you may have a problem withe reg. feed clutch. Dose it show up with the paper tray and the manual feed try?
Nov 15, 2008 | Canon PC-940 Black and White Copier
Canon PC940 Problem
You could have a broken exposure lamp. Does the scan bar light up when you make a copy? If not that is the problem. You might also ck the contacts on the machine where they touch the toner cartridge. The toner cartridge opens a shutter to the drum when you slid it into the machine and that may be broken.
Feb 11, 2008 | Canon PC-940 Black and White Copier
Canon PC-940 Black and White Copier Logo
157 people viewed this question
old marine
old marine
