Tv picture HAVING PIXEL PROBLEMS WITH MY TOSHIBA 40XF355DB MODEL. DARK COLOURS VERY BAD REALLY SEE THE SQUARES.......MID TO LIGHT BROWNS VERY BAD TOO...but not on every programs
    Problem Solver:
  • 7 Answers
It seems to me that you are watchin an analog signal on a digital HD TV, the analog signal is has a standard resolution of 720x576 for NTSC (American Signal) and 720x480 for PAL (European Signal).
It could be worth to go contact your cable company, they can hook you up with a digital receiver which gives a better signal and might even have a HD Signal (this means it has a HD-Ready 1280x720 of Full HD 1920x1080 resolution).
If you really want to use your LCD TV on his max this is really worth considering
Posted on Jan 30, 2008
Bad picture
Sounds like the DLP chip has failed. You can get replacement parts here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Feb 14, 2018 | BenQ Televison & Video
The colours are no longer lining up. On captions you can see the three seperate colours. The auto focus does not fix. How do you enter service mode to adjust grid lines?
U can't do any grid lines adjustments for this problems,the tv problems it is having are known as a convergence pictures problems,it is dead.The tv have any colors lines like R,G,B mis alignments,tv have any colors shadows pictures or have a 3D pictures look alike?Yes,than the tv convergence board it is dead for the tv to causes all of these convergence pictures problems.The tv convergence board must have to be repair like replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence pictures problems.The tvs shops will cost like $300-350 for parts and labors.
Sep 21, 2011 | Toshiba 57H83 TV
I have a problem with the picture on my Infocus IN1501. It has small squares on it and I see every pixel. How do I remove this?
Generally the screen is full of pixels, and thats a good thing.
It's a problem when you see the pixels that should be off, and don't see them when they should be visible.
So I presume that your pixel problem may be the first type where they appear when they should be hidden.
Now it would be good to know if the bad pixels are all one colour, or if you have chromatic pixelation problems.
Monochrome pixel problems are better than chromatic pixel problems. But alas all pixel problems come back to the DMD or the colour wheel.
Either way your machine is basically compost material for the garbage shredder, unless you want to pay big money to replace the faulty bits.
Ask the local serviceman or servicewoman to give you a quote to look inside the unit and see where the pixels have gone astray.
Mar 17, 2011 | InFocus IN1501 DLP Projector 3000 Lumens...
I have a Toshiba REGZA LCD Model 42XV600A and am having problems with the picture. The picture was fine but now the colours are all out of whack. I have checked the connections and aerial reception and...
Go in ur tv menu go "Picture"go down to reset.Press it,will go back to Factory setting.The colors should be back to factory setting.Not,than ur tv Main Tuner signal board is the cause must change to fix.
Apr 04, 2010 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Flat panel TV shows a bright pinpoint of light in dark scenes
maybe or maybe not. It is a pixel that is stuck 'on' all the time. Not a warranty claim item as a few bad pixels are allowed.....
It does not spread, but that is not to say that another pixel somewhere else on the screen will not go bad.
Mar 26, 2010 | Sylvania LC225SSX LCD TV
Toshiba 40" LCD TV has bands each side where picture is brighter
Same Problem Here on different Toshiba Model. Did you get it fixed?
Sep 22, 2009 | Toshiba 37HLX95 37 in. LCD TV/DVD Combo
We have a samsung rear projection tv with the same problem of fine wavy lines across the whole screen,more visible with light and dark colours, its like watching the tv with fine rain, sometimes the...
Your convergence ICs could be going Bad if so TV will shut down if the one that starts it goes out first STKs big black ICs also 2 resistors l;ow ohm 2.7 ohms near ICs.
Aug 14, 2009 | Samsung Televison & Video
Poor picture quality on Toshiba Regza 32AV555DB LCD TV
i had the same problem! i just changed my scart leads to some quality gold ones, this made the picture a lot crisper . hope this helps :0)
Dec 14, 2008 | Toshiba REGZA 32WLG66 32 in. Television
Bad picture/colours on Samsung LCD TV
loretta change your power pack
entwined  try another cable
Aug 21, 2008 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
Hello, i have a panasonic 50" dlp tv and the picture is really dark....i bought the tv back in 2003....any suggestions...
The light engine bulb might be bad or going bad. Check it first. Then check its power source. These are you two most likely problems. I would suggest you having a TV technician perform this task.
I hope this helps,
Thank you,
Shuttle83
May 27, 2008 | Panasonic Televison & Video
Televison & Video Logo
178 people viewed this question
Top Televison & Video Experts
