Question about Canon Rebel XT / EOS 350D Digital Camera
Cmaera turn on/off
My camera stopped working - no on/off light - so I thought it was the battery and charged overnight.  Now the light comes on wether on or off and the camera still does not work - no lighting in the back panel - no picture taken when button pushed.  IS it the battery, the lythium battery or something else???  The camera is about two years old maybe three. 10 megapixels.
  • pmealkap Feb 02, 2008
    It wasn't the battery.  The camera store said to send it back $225 minimum charge and 8 weeks.  May be better to buy a new one...
I'm having a similar problem. I was told it was the shutter button. Something must be lodged in there causing it to not push. It will push sometimes.
BTW. . it's 8 Megapixels.
Posted on Feb 06, 2008
  • 667 Answers
If you have used the camera a lot in that time frame then I would try a new battery first.
Posted on Jan 30, 2008
NEEDING TO CHARGE BATTERY. WHEN WE PLUGGED IT IN, THE LIGHT DID NOT COME ON. WE HAD IT PLUGGED IN ALL DAY LONG AND ONLY A QUARTER OF IT WAS CHARGED. FIRST OF ALL WE THOUGHT THE LIGHT WOULD COME ON TO...
Hi, Sounds like the battery is quite old which means its probably stopped being able to hold a charge which would cause the problems you've described. The solution would be to buy a new battery.
Jun 13, 2011 | Canon EOS Rebel XS 35mm SLR Camera
I purchased a new battery, installed it and plugged in cord to charge. The charge light came on, it was on charge for about ten hour, This overnight that I charged the battery, the charge light was out the...
Some units will charge with the light on and when it reaches full capacity the light goes off preventing overcharging the battery. Now! you mentioned that the battery had charged, how long did the battery run? "should be around 2 hours" If you find the light comes back on to recharge the battery then this probably normal. But if the battery is ready to be charged and no light comes on, then it indicates the charging circuits in the motherboard is not working.
Jan 14, 2011 | Compaq Armada M700 Notebook
Panasonic lumix dmc fz18 won't zoom in or out after being dropped from a table. the camera can still take photos but not zoom on playback or while taking photos
The innards of modern DSLRs are precise and fragile. You need to contact a reputable repair shop ASAP. In addition to fixing your camera, they will clean the interior properly, eliminating dust particles that find their way to the CCD. The cleaning is something you should have done from time to time anyway, so just bite the bullet and take it in!
Sep 05, 2009 | Panasonic Lumix DMC-FZ18 Digital Camera
Camera won't come on
Likely you need to replace the battery. They're good only for a set number of recharges, and then they just won't store the charge anymore. The other possibility is corrosion or dirt on the battery contacts (on the battery and inside the camera) -- wipe them with a Q tip dipped in rubbing alcohol, let them dry, then try it again.
Jun 05, 2009 | Sony Cyber-shot DSC-W120 Digital Camera
Won't turn on
look for reset near the battery compartment. should need a paper clip to push.
Jun 02, 2009 | Cameras
"turn off and on again"
a few weeks ago i dropped my camera in the sea and i thought, ****. i was in the same boat, so i opened the shutter myself and turned on the camera and it works and takes pictures but the shutter wont close again so if you can make sure you have no dirt in your lense and you can manually open the shutter yourself it may work and if it stops turning on all together keep charging it and once it goes green turn the switch off and on again until it always turns green then it should work again.
Jun 22, 2008 | Samsung NV3 Digital Camera
Batter won't hold it's charge if left in the camera overnight
Apparently you shouldn't leave the battery in the camera when you're not using it - the on/off switch doesn't turn the thing off completely. Weird!
Apr 06, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Cmaera will not stay on
I had the same problem. After trying several different new batteries I bought high grade Lithium batteries. This worked! Before getting a new camera try spending $15 on quality batteries. It worked for me.
Oct 31, 2007 | Sony Cyber-Shot DSC-W5 Digital Camera
Casio Exilim EX-Z70
that happened to me too - you need a new battery.
Aug 24, 2007 | Casio Exilim EX-S500 Digital Camera
Canon Rebel XT / EOS 350D Digital Camera Logo
23 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
