I can't answer your question but clearly if there is any metal in the construction of the coffee pot it should not be heated in the microwave oven.
Ceramic coffee pots aren't intended to be heated in order to make the coffee. The coffee is either made in them by adding hot water or made in another utensil and poured into the coffee pot for serving and perhaps kept on a gentle hotplate in the meanwhile. Glass coffee pots are treated in a similar way.
Metal coffee pots and jugs can be used on the stovetop even though it isn't a good idea except for "cowboy coffee" when dry ground coffee is scorched in the jug before pouring on boiling water; steel is best for this.
I have used all manner of glass, ceramic and metal coffee pots and jugs on the stovetop but always using a heat diffuser - two layers of perforated steel with an airspace in between.
A coffee maker is a different thing and must be heated fairly vigorously. I find an old electric percolator is still the superior method of making coffee.
I think there is a real problem with the whole cleaning system with the Mr. Coffee Pot. I have one and after making only a few pots of coffee, the light starts blinking. I have cleaned it over and over and still get the same alert. My son had the same problem you have with his, it wouldn't finish the cleaning cycle. He'd had it awhile and ended up tossing it because it was beyond the warranty and store told him too bad. I've had other Mr Coffee makers and like them, but they didn't have the irritating "clean" alert OR the obnoxious BEEPING to let you know it's done brewing. If I knew this was going to be an issue - I would never have bought it. Why do they have to screw around with a good thing - more buttons and thing cycles to cause problems.
Hi Sharon. ALL Farberware coffee pots make racket. You have a pot that is made in China. When the water is hot the noise stops and it goes into keepwarm mode. As long as your water is hot 175 to 185 it is good. If you were trying to make coffee and you are not perking through the basket is another case.When you want to make coffee you MUST use the cone spring in the pump.That keeps the pump tight so the hot water goes up the pump. With out it the water just boils and does not go through the pump. Good luck. and if you want more info use [email protected] Ron
Most modern coffee pots have a feature in them to keep you from spilling coffee all over the place when you want to take a cup of coffee before they finish brewing. It sounds like you are having some issues with yours.
Basically, the way they work is that there is some sort of gasket (rubber disk) that has a lever/spring mechanism that plugs the way out of the filter basket when there isn't a coffee pot under the filter basket. They are designed so that the lid of the coffee pot pushes up on part of the mechanism and forcing the little gasket open. (You can generally figure it out pretty easily by fiddling with it.) It sounds like you may not be assembling the lid on the pot completely (this model has a lid where the dome sticks up) or may be missing the lid all together. It's also possible that a piece of packing material may be clogging this or the gasket could be stuck shut, maybe with dried coffee.
One sign that the assembly is working properly is there is just a little bit of resistance (not very noticable) when you first start putting to pot in place and it makes a clicking/thunking noise when the pot fully seats.
Hello. What your hearing is the water being heated in the tank, these machines hold a couple pots of water at brewing temp all the time, unless you unplug it from the wall, or turn off the heater switch if you have one. So, as the day goes on, it will intermittently have to heat the water in order to keep it at the proper temp. I would not worry about it too much, unless water is spitting out when it does this.
One of the cooling fans is bad. You have to isolate which one &
replaced it w/ oem mitsubishi part. Some of these arew not accesable by
a consumer. You need a tech to fix this unless its the chasis fan,
thats easy.
tvdoctor
you said you clean it you use vinegar or decalcifier vinegar remove calcium in piece it might block the orifise if you use decalcifier it melt the calcium 1part solution to 1 part water dont forget to rinse very good that stuff is nasty cheers
