Question about Audiofonics ADF-243 Car Audio Amplifier
ADF-243 Amp Recieved amp with a car at auction. Need to know how to wire it up. I understand the + - and remote wire. Dont understand the rca or speaker hook ups and what the switches are for.
    Problem Solver:
  • 18 Answers
What you need to do, is also run the rca cable from the back of the deck to the amp. The speakers are already powered by the deck. You can then hook up your subwoofers. The switches are for your own taste.. you adjust them as you go.
Posted on Aug 02, 2009
I wanna put it into my car myself but dont know how and was hoping for a lil instruction
you will need a amp install kit witch comes with a 15 ft patch cable power line for amp and a blue line for remote. these wires run from the radio to the amp. The blue wire is called remote it turns the amp on or off depending on the radio state. the patch cable is rca jacks on both ends the back of the radio should have the female part of the rca jacks hanging from it. The other end goes into the amp. and last but not least the heavy red wire will go from the battery to the amp usually there is a fuse holder that you need to put between the battery and the amp. As far as grounding just ground the amps negative to the car chasis some where.
Good Luck Hope this helps
May 04, 2011 | Visonik Dual Bass Box with Amplifier Car...
How to add amp
If you have all wires to connect your amp.
1st dissconnect your ground on your battery.
2nd connect live to your battery and poke it through the firewall into your car and run it down the door sill of your car to the boot.
3rd. reconnect your ground to your battery.
4th. Connect RCA Cables to back of your head unit inc the remote (thin wire with RCA) The remote needs connecting to a blue and white wire in the connector blocks for your stereo.
5th. Run RCA cables down the opposite side to where the live is running (live on left RCA on right)
6th. You need to sand down spot in your boot of your car, paint and rust free for your ground wire for your amp.
7th Connect ground to a metal screw or bolt nd tighen it to your spot you have sanded. (may need to drill hole)
8th. 1st connect ground to your amp. then live, then remote, then speaker wires.
If you need any further info or have any problems let me know and I'll troubleshoot for you.
Hope this helps you to fit your amp..
Mar 05, 2011 | Sony Car Audio & Video
My amp turns on but stay in protect mode
check your wiring, is it properly grounded? is your remote positive wired to your ignition's positive line?
Jun 10, 2010 | Car Audio & Video
I dont know how to setup my amplifier to MP3 Stereo...
Just like any other stereo. Get a wire harness for your car and match the wire colors together, tape them or cap them, or best yet soder them. Then run rca cables from the output in the back of the stereo to the amp. The run a remote wire (bue with white stripe) from the stereo to the amp remote terminal. Hook up the amp normal. let me know.
Dec 22, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
Sub woofers and amp
first of all is the amp a four way amp? if so then you need to know what the watts of the subs are (you dont want to melt them) wire + and - of channels 1 and 2 to one sub and + and - of channel 3 and 4 to second sub, nice thick lead from battery positive (fused) to positive terminal on amp thick lead from a good earth point to negative terminal on amp run a set of rca leads down the opposte side to the positive wire to prevent interference, run thin wire from remote wire of radio to the remote terminal of amp, rca's are plugged in at stereo and at the am. may need a RCA splitter to be able to power all four channels
Good luck Davelee
Mar 24, 2009 | Car Audio & Video
Alpine sub pre outs
i know people dont like doing it this way but when in doubt, splice wires.
go to walmart and buy a crossover, splice your front or rear door speaker wire and wire in the crossover and also the door speaker. plug your RCA cables in and run them back to the amp.
most people with stock decks do this if they dont have sub out or amp out.
if u need more help let me know
Feb 18, 2009 | Alpine IVA-D310 Car DVD Player
System Remote Control Wire.
Wal Mart generally has 4g wiring kits for ~$40. Some of the kits contain everything you'll need to install your amp (including RCA cables, fuses and fuse holders).
If you want to understand more about car audio installation, read through the following site:
bcae1.com
Read the following pages specifically:
Installation Primer
Wire
Fuses
Amplifiers
Head Unit
Dec 28, 2007 | Pioneer GM-5100T Car Audio Amplifier
I cant instsall the whole system, does anyone have any ideas??
bagman Fat Red wire from batter + to Fuse. Fat Red wire From Fuse to Amp +. Amp- Fat Black wire to body Ground. RCA cable run from Head unit RCA jacks down opposite side opf car from power wires. To Amp RCA inputs. Wire Speaker REd terminal to Plus on Amp. Balck Terminal to Minus on amp. Blue Wire is REmote, and wires to Blue on head Unit. Remote on Amp.
Oct 03, 2007 | Fusion FEW12PK Car Subwoofer
Amlifier not working
connect your remote turn on and your problem will be solved
Sep 23, 2006 | Crunch BlackMaxx BLX2000D Car Audio...
Audiofonics ADF-243 Car Audio Amplifier Logo
195 people viewed this question
Top Audiofonics Car Audio & Video Experts
Mark Skinner
Billy McCain
Billy McCain
Level 1 Expert
Bill Boyd
Are you an Audiofonics Car Audio and Video Expert? Answer questions, earn points and help others
