Question about Ovens
Oven keeps tripping when switched on
Hi, recently our electric oven has tripped whenever we switch it on, it doesnt even warm up just trips and trips all other appliances and lights in the kitchen as well even though no other appliances (besides the fridge and freezer) are being used or even switched on.
Im not sure if this is relevant but our suburb has been experiencing regular power outages ( courtesy of our national provider) for the past few months- ould this contribute to the damage of our oven?
I would be grateful for any help you can render on this matter
  • Anonymous Mar 18, 2014
    Have Atlas Mira wall oven installed in house I have just purchased and no manual. Couldn't find an off switch when I viewed the house but made sure all switches were in the marked 'off' position even though the centre switch didn't have an 'off' position. When I shifted in a couple of days later, oven was warm and obviously not switched off. To do so I switched off at the wall. Now of course the oven won't go. Need to know how to set the timer. Also need to know how you swtich oven to off when not in use.
  • Anonymous Mar 26, 2014
    I've returned from holidays to find there's no power to my oven. All other appliances are ok - there was an electrical storm recently and I'm thinking there may be a reset switch somewhere? The breaker is ok in the meter - checked that and reset.
  • 139 Answers
The reason why you oven is tripping is because the oven element is most likely burnt out...
The electricity supply going out should not have affected this... it is easily replaced and is not to costly..
Posted on Jan 31, 2008
Hi my delonghi double oven keeps tripping the electric power supply it trips on the top oven when using the grill and the bottom oven on oven
I would have a electrician look at the breaker switch as being in need of replacement. They do weaken over time and cannot handle the load that they were designed to carry when brand new.
May 13, 2016 | DeLonghi Ovens
Why does it trip breaker?
There probably is an internal short.
Oct 04, 2015 | Neff Ovens
Why does the cooker keep tripping the electric power?
loose wire,shorted switch?(You will receive an answer like this if,you did not include the make or model or serial number or
date of manufacture or complete problem and what needs to be done.)
Jun 08, 2015 | Ovens
I have a Smeg SE 336SS-5 Electric oven, I have recently had problems with the fan motor not working and the electrics tripping out when the cooker has been on for a while. I have replaced the fan motor...
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Jul 07, 2011 | Smeg Ovens
Went to switch oven on fan works when you turn the temp knob it trips the trip switch every time help
HI, Sounds like your from the UK
If you are referring to a trip switch as being equivalent to an American circuit breaker. (Electrical safety device designed to shut down power to an electrical appliance). Then we are on the same page.
Do the following diagnostic procedure:
1 SHUT DOWN THE POWER SUPPLY TO THE OVEN. I.E. THE TRIP SWITCH/CIRCUIT BREAKER.
2 Open the oven door and look very carefully with a flashlight at the heating element. Look at the the entire element. If it blew (similar to when a light bulb blows) you will
find white powder around the hole in it or it will be completely broken, or have bubbles in it. Some indication like that. If so it has failed and must be replaced. It is probably tripping the switch because it is shorting out somewhere. There is also the possibility that the internal wiring connectors to where the element is mounted into the oven walls is broken off and short circuiting against the oven chassis (walls). That being the case, it may be just a wiring repair in which you install new appropriate electrical contacts and re-connect the element.
Hope this helps,
Happy New Year,
Mark
Dec 31, 2010 | AEG B3101-4 Electric Single Oven
Hi can you help me my when i turn it on it reached temperature then triped. Reset the trip switch turned the oven on again and within couple of minuets it happened again. We turned it off and have not used...
Prob your cooling fan...it comes on to keep the appliance at a constant temp and if it doesnt it will trip out. Try turning on ur grill and you should hear the fan come on straight away, if not then you will need to replace it.
Hope that helps.
May 25, 2010 | Baumatic B180 Electric Single Oven
Recently wired a double oven with isolator switch
Hi, there's definitely a electrical problem.
First, use the bottom oven only for about 15 minutes and check if it doesn't trip.
Second, use just the grill (top oven) for about 15 minutes and check if it doesn't trip.
The reason is sometimes grill elements are corroded and only trip after a few minutes.
Also, if both ovens work ok on their own, then it could be your fuse box not strong enough, or the isolator switch fuse be only 13amp. If your oven is more than 3Kw (check the label on the door for info) then you need a 30amp fuse to hold when both ovens are on.
Cheers
Feb 19, 2009 | Zanussi ZDF490 Electric Double Oven
Tricity bendix se211 electric cooker trips all my electrics
The symptoms you describe are a classic example of an oven element heating up, and as it gets hotter, the insulation is breaking down, thereby causing the earth leakage trip to operate.
To confirm this , switch on the oven, and turn all 4 rings on the top to full heat, 2 at a time, let them stay on for at least 10-15 mins, and if it does not trip, then you can be pretty sure it is the oven element(s) that is the problem
It is not likely to be the wall switch, as if it were faulty, i would expect the trip to go right away.
If you want to check further, then turn on the oven again and see if it trips, if it does ,then it is definately the oven element(s) that is the problem.
If it is a fan assisted oven , the element is at the rear of the oven, and possibly one under the base ot the oven. If it is a conventional convection oven, then there is an element at each side of the oven, even if one is faulty, replace both.
Plz rate my solution.
Thanks.
Jan 07, 2009 | Ovens
HI, MY ELECTROLUX SINGLE FAN OVEN EBO5665 DOES NOT HEAT UP TO ANY TEMP. THE OVEN IS ON, FAN ON,AND THE TIMER DIALS ARE SET. DOESNT HEAT UP. IT TRIPPED THE ELECTRIC SWITCH OFF AT THE TIME. ANY SUGGESTIONS!...
You probably have a bad ( or open ) heating element.. With the power removed.. look at the heating element and make sure it is connected properly and if after you check that it looks ok.. plug it in and try again.. if it fails to get hot..its probably bad.. Not sure what you mean when you say ' IT TRIPPED THE ELECTRIC SWITCH OFF AT THE TIME' but if it tripped the switch or circuit breaker .. your heating element may be shorting out to ground.. and would need to be replaced anyway... Hope that helps.
Aug 22, 2008 | Electrolux EOB5600 Ultrafan Electric...
Ovens Logo
397 people viewed this question
Top Ovens Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
