Question about Sony KP-57HW40 57" Rear Projection Television
Tv shuts off by itself then flashes a code 8 blinks
When the tv stays on for a long period of time it starts to turn off and then the button for stand by flashes eight times.
    President:
  • 4,402 Answers
Eight blinks means, "High voltage error". The probable cause location listed is "T8005 is faulty (D board). T8005 is the fly-back transformer (FBT). or you can replace the full d-board
You may purchase the D board complete for $185.10
or send in for repair here
if one of the crt is shorted it can also cause this problem.
Posted on Jan 30, 2008
    Genius:
  • 1,694 Answers
Note: eight blinks can be audio problem after hot....
Check IC406 audio amp, PS401,402..........................T.
Posted on Feb 05, 2008
TV turns red,shuts off, stand-by light blinking 8Times
Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board.
Feb 27, 2014 | Sony KP-51HW40 51" Rear Projection...
My Mitsubishi Medallion tv stays on for about 10 minutes and then shuts down and won't turn back on until a period of time has passed. It is a rear projection tv about 9 years old. Can anyone help ex
When it shuts off and the green power light goes off, press both the menu and input buttons on the front of the set (not the remote) and hold both for about five seconds and release.
Power light will blink a two digit error code like 2 blinks and then 3 blinks and repeat it several times.
What is the error code?
Nov 14, 2011 | Mitsubishi WS-55819 55" Rear Projection...
The Screen Turns Green then shuts itself off? Is this the Bulb or something else?
My sony 65Ws500 model about 4 months ago it started turning the screen all blue as soon as I turned it on. it stayed blue for about an hour then come back on normal now when I turn it on it will shut down and I get a small red light flashing 8 time then pauses and does it again 8 time then pauses then again and so on. I took back panel off. I turn on tv The blue bulb gets very bright and the green and red projection bulb goes out and now it shuts off. and the blinking starts it a code flashing but don't know the code to find out whats wrong. would someone help if u can been wife and I laid off from work 3 months now cant afford tech prices on our employment. wife and I has 2 little girls to raise. along with the rest of u parent out there and one getting employment cant offord repairs. Thank U. Adams01220@yahoo.com
Feb 13, 2011 | Sony KP-65WS500 65" Rear Projection...
Sony Wega Kv-36XBR250 screen blinking
I have seen this flashing before, this could be an indication that the picture tube is weak, what happens is that if the white balance is off there is a circuit called akb it monitors the kathode of each gun and if they are not in balance it will attempt to balance it out. if it can't the picture will begin to flash, sometimes in some models the power light will blink 5 times. On some models the power light will only flash if the tv gives up trying to compinsate for white balance and shuts off compeletely. If you see the tv shutting off with 5 blinks then you know for sure it is time for a new set.
Sep 02, 2009 | Sony FD Trinitron WEGA KV-20FS120 20" TV
2004 Sony 52" Wega dont turn onnthe stand by light stays flashing. This TV first started by taking long to turn on and now and then would turn off until one day it just didnt turn on and the standby button...
When that model Sony shuts down the LED starts blinking as you say but it is telling you something because it blinks a certain number of times and then pauses and repeats the number of blinks. Count the number and then I might be able to help you narrow down where the trouble is.
Jun 14, 2009 | Sony KP-51WS520 51" Rear Projection...
Sony KP-65WS500 65 in.
Check your CRT boards on the end of the tubes for burn spots, and burnt components, check the resistors to make sure they are not shorted, burnt, and they read the correct resistance. Check the diodes to make sure they conduct in one direction only and are not shorted or open.
Mar 24, 2017 | Sony KP-65WS500 65" Rear Projection...
Green flashes then tv turns off
or a new lamp. you could first replace the lamp.
the screen might work fine for a couple of seconds, but then it fades away or deteriorates. This means the lamp is going bad.
Aug 23, 2008 | Sony KP-51HW40 51" Rear Projection...
Assistant
is this electricity pocket plugged up to a timer ? or take the tv back to the shop... lost the receit just look for the same tv on computer
Feb 20, 2008 | Toshiba 28N33 28" TV
Screen shuts off
my screen will turn on right after unit is plugged in and stay on for a short period of time, then it shuts off and the red light near the power button blinks and teh tv will not turn back on. there might be problem of loose contact in power supply Thanks
Sep 11, 2007 | Toshiba 32AFX61 32" TV
Tv won't stay on
My tv is a Toshiba. It comes on for a second and then goes off by itself. I use the remote and the power button on tv and the same thing happens. Is there a solution to this?
Jan 24, 2006 | RCA F27450 27" TV
Sony KP-57HW40 57" Rear Projection Television Logo
262 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
