Question about Fujitsu Siemens AMILO Pro V2000 Notebook
Problem with power
They try to power on the laptop with other power supply.
Now when you plug it's own charger you hear a noise from a delta electronic component with no sp0134-4r7, 0433w.?. The laptop does not power on or charge at all.
if you please can sent me the power schedule diagram for this model.
please reply to kleanthous1971@gmail.com
  • 66 Answers
I was hopink that u at least looked at th mA on your charge and then compared it to the one u used
if it has a higher voltage as the original as the one it came with now u need to check if the internal capacitor in the laptop has gone
Posted on Jan 31, 2008
What's your problem?toshiba satellite l555 s7916 wil not boot
Try Resetting the CMOS on your Motherboard.
Turn off the Laptop and unplug it
Remove the battery
undo the RAM cover
Remove the RAM
plug the laptop into the power
Turn the PC on and listen for some beeping noises
If you hear the beeping noises turn the laptop back off
Unplug the charger
Replace the RAM into the RAM slots
Replace the the battery
Plug in the laptop and power it up.
if you get video output, that's Great, if not, it's possible that you have a faulty screen
Oct 05, 2012 | Toshiba Satellite L555-S7916 Notebook
No power with adapter or battery no lights on laptop, no noise
More than likely your power supply has failed. Your computer probably ran on the remaining battery power when you noticed it. If you have another power supply to try you could determine that. Also, the plug in on the computer takes a beating on laptops and that could have failed as well.
More than likely your battery is in good shape, it just hasnt been charging due to the poor charger.
Hope this helps.
Feb 23, 2011 | Computers & Internet
Laptop wont start at all. plug in to power supply and battery charging light comes on.still wont start up...
try diconnecting the charger and holding down the power up button for longer, then try plugging in charger- turn on charger at wall then hold down power on button till power button on key lights up, i hope this helps you out ;)
Feb 07, 2011 | Computers & Internet
Nothing comes on picture blank
Ok
A few things to try
1.) Check the laptop on an external monitor, do you get a picture
2.) Is there power to the laptop from the battery and the charger? Try to see if the charger indicator lamp is blinking green rather than steady green
3.) Can you hear hard drive / fan noises and are there any lights on the laptop?
If the charger is blinking, indicates that power is not making the circuit, check tightness of charging port, if tight, assume fault on motherboard / blown main fuse
If picture on external monitor and not on laptop, assume backlight on screen dead or possibly the inverter
If no noises from HDD or Fan and No lights on laptop, then fault with motherboard
If you do get fan noises etc, but get BLINKING lights on laptop, assume possible fault with graphics chip, repost with details of blinking lights / colour and specific model of laptop
Jan 12, 2011 | Samsung Computers & Internet
My Acer Aspire 5100 laptop makes a loud high pitched consistent noise when I try to turn it on. then the noise stops, then a black screen comes up with writing, but when i hit resume, the computer restarts...
The problem might be the power supply charger that plugs into the laptop, unplug the charger and run the laptop on battery power, is the high pitch sound there when you power up? if this solves the problem, it is the power supply charger that is the cause.
Jan 08, 2011 | Acer Aspire 5100 Notebook
Charger was plugged in and working fine, went into
OK unplug power supply from back of laptop, remove battery, insert power supply, if NO light, on laptop, power supply is broken..Replace. IF it is OK, hold power button ON for a while, or until, the PC starts, if/when it starts, shutdown, with power ON key, and then take out power supply, replace battery, replace power supply, turn laptop on, now should be OK.
Mar 01, 2010 | Toshiba Satellite A70-S249 Notebook
My Sceptre TV doesn't turn on.
https://www.adapter-chargers.com/product/delta-adp-180cb-b-ac-adapter-delta-24v-7-5a-180w-4-pin-ac-power-adapter/
Jan 28, 2018 | Dell Dimension 8400 power supply ** FREE...
I have just got a new charger for my gateway and when i plug it in i hear a snap and cracking noise
Are you sure the charger is the correct specs for your model? Check the label on the laptop and on the charger to be sure they match. The voltage and amps should be the same. Most importantly check the polarity which will be a graphic that looks something like this:
o)--->+
What that is telling you is if the center of the plug is positive or negative. The only thing that matters is that the pictures are the same. If you switch your polarity you will almost always blow out your power supply on the system board. Does the laptop power on or has it not worked since you heard the noise?
If it has not powers on odds are the specs are wrong on your charger and you might have damaged the laptop. If the laptop still works then it is possible the charger is providing too much power or malfunctioning. A laptop will work with a more powerful charger sometimes, but it is never recommended as it will create more heat and reduce the life time of the laptop system board.
Aug 22, 2009 | Gateway 7210GX Notebook
Need to get a new charger
You could get a 120 watt (19v * 6.32A) universal laptop power supply on Ebay for £30. Ask the vendor to confirm that it is compaitible this laptop.
Dec 08, 2007 | Evesham Voyager 5700 Notebook
Fujitsu Siemens AMILO Pro V2000 Notebook Logo
199 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
