Question about Philips Magnavox 9P6034C 60" Rear Projection Television
Have Parts for 9P6040C101 - 60 inch rear projection TV....
I have had some convergence issues with my Magnavox 60 inch rear projection tv. I replaced my IC's but that did not fix the problem... So, I am going to sell off any parts that are still workable/functional. I am not technical, but i am sure that some of the parts may not be affected by bad electronics. Inquire at 443-255-1892.
  • hammer101 Jan 31, 2008
    Anyone in need of parts?
    President:
  • 4,402 Answers
Try ebay or craiglist...
Posted on Feb 07, 2008
I have aquires a Magnavox rear projection tv. The picture is sharp but is in shades of red and pink. Obviously the green and blue are not working correctly. Any Ideas besides kicking it to the curb?
The tv have a problems known as a convergence pictures problems,the tv convergence board it is dead,that why tv colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?This tv can be repair,by fixing the convergence board,by replacing 2 STK convergence ICS and some or all of it resistors too.Will fix convergence pictures problems.The tvs shops will cost u like $300-350 for parts and labors,to save this tv.
Jul 27, 2011 | Philips Magnavox 51MP392H Rear Projection...
I have a Magnavox 51mp392h/17,that now has double vision (text is double,all images) there is also green, off red colors on the picture. Please help me the tv is 6 years old. should i throw it away or get...
No.Should cost u like $300-350 for parts and labors.Get it fixed any local tv shops can fixed this problems,very common problems for DLP CRTS tubs design projection tvs Tv have a problems known as a convergence problems,it is dead.The tv convergence board it is dead,that why ur tv picture colors lines R,G,B mis alignments,have pictures colors shadow or 3D pictures look alike.The tv convergence board must have it parts replace like 2 STK convergence ICS and some or all of it resistors to fixed the convergence board to solved convergence pictures problems.
Jul 22, 2011 | Philips Magnavox 51MP392H Rear Projection...
Tv has red and green lines
Tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignment,have a colors shadows pictures or 3D pictures look alike.The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors are dead too.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 11, 2010 | Philips Magnavox 51MP392H Rear Projection...
The picture on my phillips rear projection tv is red and I can't change it by adjusting colors. What is wrong and how can I fix it?
Tv have colors lines R,G,B mis alignment any colors,shadows colors, 3D pictures,the tv have a problems known as a convergence problems.The tv convergence board is dead.The 2 STK Convergence ICS and some or all it resistors are dead too.Must replaced these parts to solved convergence problems.The shop will cost $300-350 for parts and labors.
Aug 05, 2010 | Philips Magnavox 51MP392H Rear Projection...
My 60 inch Maganvox tv is blurry and the letters at the bottom are blurry. Can;t hardlt make out the picture now.
Replace STK convergence chips there are two next to the heat sink.Unsolder old and solder in the new.
May 21, 2010 | Philips Magnavox 9P6034C 60" Rear...
My magnavox 51mp392h has a convergence issue. the
Convergence is dead.Know how to solders? Must replaced the 2 convergence ICS and all it resistors.Tries Tv repair World.com,Tvrepairkit.com to buy a convergence kit to repair it ur self.The shop will $300 for the parts and labors.
Feb 03, 2010 | Philips Magnavox 51MP392H Rear Projection...
Convergence point problem on a Philips TV
The 55pp9352 model number uses 2 of the STK-392-120 convergence chips--if it will not adjust in some direction--both chips and any of the 6.8 ohm resistors around them that are bad need to be replaced.
The reason this happens is the chips are about 2 1/2 inches wide X 1 1/2 inches tall with a metal back--they are attached to separate metal heat sinks and a white grease is applied to each to transfer heat quickly---after several years the heat sink grease dries out and one of the chips cannot stay cool enough and fails.
Pretty common problem in ALL rear projection sets--if model is 55pp, it is 55 inch set.
You can buy the chips on Ebay for less than 12 dollars---the resistors if needed are cheap parts.
It depends if you are able to do the repair yourself or need to have someone do it for you--most shops get at least 300 for this kind of repair--considering the parts cost less than 20 dollars if you can do it yourself you can save a lot of money.
Any good tech can do this repair in your home in about 1 hour--I know as I have done hundreds of them.
If you need help or advice let me know--I am here to help people.
Regards, SD TECH
Oct 11, 2009 | Philips Magnavox 51MP392H Rear Projection...
Convergence board swap questions....
You can try to change it out and go to convergence adjustment mode on service mode to setup the template.
But I rather replace couple trans and leaky diode on your old convergence amp board to save my time
Jan 06, 2009 | RCA D61W20 61" Rear Projection Television
Magnavox 55'' Projection - Sides come in and out
sounds like Convergence issue.... I have some pictures of the bowing picture TV on the link below...
I'll post you my general message which is for a similar Philips Magnavox 51 inch TV, you'll need to check the manual verify the correct IC convergence chips and resistors, the manual link is below as well... usally the IC's are STK392-120's or 150's and the resistors are 6.8 ohm 12 of then...
anyway read the general post below it will get you headed in the right direction.
51MP392H/17
Actually I have this TV and you need 2 Convergence IC's STK392-120's (120's and 150's will work) of course order 2 of the same type I'm using replacement 150's they allow for a little higher heat and were cheaper ALSO you need to replace the 12 resistors with 6.8 ohm metal film resistors, make sure they are metal film! don’t skimp out here I did and then they blew and fried my IC's and I had to replace everything again!
Great reference link that I posted
pictures on, check out page 3
http://www.techlore.com/forum/thread/16736/Magnavox-51MP392H-17-51-quot--TV-has-double-vision/
Where I got my parts that worked:
Suburban Electronics
http://www.suburban-elect.com/
Manual Library you should find all you need here:
http://www.techlore.com/group/2/list_downloads
What you need:
(2) STK392-120 OR STK392-150 IC
chips
(12) 6.8 Ohm Metal Film resistors
set of star screw drivers
15 watt pencil solder pencil, DO NOT use a high watt iron you will fry the surface mounted item.
good leaded solder, and flux
Nov 11, 2008 | Philips Magnavox 51MP392H Rear Projection...
60 inch phillips magnavox projection tv
CRT coolant change and advanced convergence - how to
I documented the procedure I did on a Philips 55" rear projection 55p916
http://tinyurl.com/lmp6eu
CRT coolant change procedure
http://tinyurl.com/l7bd7r
basic and advanced convergence
Dec 24, 2007 | Philips Magnavox 51MP392H Rear Projection...
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
119 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
